    BL-Touch - multiple problems -
    Firmware installation
    2.2k
    • duttiundefined
      dutti
      This post is deleted!
        Phaedrux Moderator @dutti
        @barbarossa-cologne said in BL-Touch - multiple problems -:
        short describtion for update firmware?
        with pi 4
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
        M401 / M402 are not working. The web control shows the normal green button on rigth bottom screen but no moving.
        When I connect the BL the test move happens.......
        M280 P0 S120
        green button on screen, no moving or something else.
        It sounds like a wiring issue. The probe is getting power and ground, but no signal. Triple check your wiring and crimps. A good test is to connect the short leads from the BLtouch directly to the board to eliminate the extension wires.
        duttiundefined 2 Replies Last reply Reply Quote 0
        • duttiundefined
          dutti @Phaedrux
          @barbarossa-cologne
          I saw this settings made in the configuration tool. I tried to change the settings manual. Maybe I made somethig wrong there?
            That all looks ok as long as you're actually wired up to the io7 in and out pins.
            duttiundefined 1 Reply Last reply Reply Quote 0
            • duttiundefined
              dutti @Phaedrux
              @Phaedrux
              ok. I´ll check everything-
              • duttiundefined
                dutti @Phaedrux
                @Phaedrux
                What do you mean with ´´actually wired up to the ioin and out pins´´?
                  I mean that your config looks ok, now the wiring must be correct for the config to work.
                  • duttiundefined
                    dutti @Phaedrux
                    @Phaedrux
                    ok sry.
                    I tested the wiring. Its not the problem....
                    this is the last problem I have to solve before starting. Thats really bad.
                      If that's the case and the wiring is good please update your firmware (as linked above for the Duet + SBC). Send M115 after to verify.
                      Then please send M98 Pconfig.g and report any errors.
                      • duttiundefined
                        dutti @Phaedrux
                        @Phaedrux
                        M98 Error: Non-empty string expected
                        firmware is updated
                          That's a weird error. You're sending this exactly?
                          M98 Pconfig.g
                          • duttiundefined
                            dutti @Phaedrux
                            @Phaedrux said in BL-Touch - multiple problems -:
                            M98 Pconfig.g
                            yes
                              try M98 P"config.g"
                              • duttiundefined
                                dutti @Phaedrux
                                M98 Pconfig.g
                                ´´´Response to long, see console´´.
                                I havent connected the expansion board, yet. Is this a problem?
                                  Are you in the DWC gcode console when you send that?
                                  • duttiundefined
                                    dutti @Phaedrux
                                    @Phaedrux yes
                                    • duttiundefined
                                      dutti
                                      I homed z again. It's homing without triggering manual the BL.
                                      Also when I go down with the z axis... doesn't care which amount and then homing z, the z motors are turning back always the same amount and it stops.
                                      --> I hope that helps
                                        I'm not exactly sure what you mean.
                                        Looking back over your config.g I notice two things on your M558 command that we can try changing.
                                        M558 P9 C"^io7.in" H15 F120 1400
                                        First, you're missing the T in front of the 1400 to define the travel speed between probe points.
                                        Second, try removing the ^ from in front of io7.in. I think it's only zprobe.in that requires the pullup.
                                        I'd still like to see what the gcode console output is from sending M98 P"config.g" It should echo SOMETHING back.
                                        • duttiundefined
                                          dutti
                                          M558 P9 C"io7.in" H15 F120 T1400 ----> doesn´t work
                                          M98 P"config.g"
                                          --> response to long, see console
                                          Should I buy a other sensor?
                                          My motivation after a few days is down.....
                                          • JoergS5undefined
                                            JoergS5 @dutti
                                            @barbarossa-cologne what does the console say? If you cannot read it, you can download it into a file:
                                            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_G_Code_Console
