BL-Touch - multiple problems -
If that's the case and the wiring is good please update your firmware (as linked above for the Duet + SBC). Send M115 after to verify.
Then please send M98 Pconfig.g and report any errors.
@Phaedrux
M98 Error: Non-empty string expected
firmware is updated -
That's a weird error. You're sending this exactly?
M98 Pconfig.g
try M98 P"config.g"
@Phaedrux said in BL-Touch - multiple problems -:
M98 Pconfig.g
´´´Response to long, see console´´.
I havent connected the expansion board, yet. Is this a problem? -
Are you in the DWC gcode console when you send that?
@Phaedrux yes
I homed z again. It's homing without triggering manual the BL.
Also when I go down with the z axis... doesn't care which amount and then homing z, the z motors are turning back always the same amount and it stops.
--> I hope that helps -
I'm not exactly sure what you mean.
Looking back over your config.g I notice two things on your M558 command that we can try changing.
M558 P9 C"^io7.in" H15 F120 1400
First, you're missing the T in front of the 1400 to define the travel speed between probe points.
Second, try removing the
from in front of io7.in. I think it's only zprobe.in that requires the pullup.I'd still like to see what the gcode console output is from sending M98 P"config.g" It should echo SOMETHING back.
M558 P9 C"io7.in" H15 F120 T1400 ----> doesn´t work
M98 P"config.g"
--> response to long, see consoleShould I buy a other sensor?
My motivation after a few days is down..... -
@barbarossa-cologne what does the console say? If you cannot read it, you can download it into a file:
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_G_Code_Console -
M98 P"config.g"
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=108
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=109
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=110
Error: M350: Response timeout: CAN addr 1, req type 6021, RID=111
Response timeout: CAN addr 1, req type 6021, RID=112
Response timeout: CAN addr 1, req type 6021, RID=113
Error: M906: Response timeout: CAN addr 1, req type 6017, RID=114
Response timeout: CAN addr 1, req type 6017, RID=115
Response timeout: CAN addr 1, req type 6017, RID=116
Error: M557: bad grid definition: Too many grid points; suggest increase spacing to 31.8mm
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 404C -
@barbarossa-cologne said in BL-Touch - multiple problems -:
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H15 F120 1400 ; set Z probe type to bltouch and the dive height + speedsIf this is from your current config.g, you need to swap the lines round. M558 before M950
HTH
Paul
Mine from a DUET2 for comparison
M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02 ;BLTouch connected to Z probe IN pin M950 S0 C"duex.pwm1" ;BLTouch Servo (S0) on duet pwm1 G31 X2 Y42 Z0.513 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
I checked it, from 15 to 650 are 21.16 points, so if it is rounded down to 21 it would reach the 441 limit of Duet 2 (limit of Duet 3 is not known to me). So reducing 650 a bit or S bigger than 30 would be the safe side.
The software is homing Z without triggering anything. That´s really confusing for me..
@PaulHew
Like this?
M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in; Z-Probe
M558 P9 C"^io7.in" H15 F120 T1400 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:650 Y15:650 S30 ; define mesh grid -
@barbarossa-cologne the CAN errors mean your Duet misses the expansion board.
You should set X and Y offsets for BLTouch in G31. This is described with an example in https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s231
G31 Z value means trigger height, 2.5 mm seens too low, please try a higher value.
