    bltouch
    1.9k
    • nemecekundefined
      nemecek @Phaedrux
      @Phaedrux said in bltouch:
      G1 H1 X405 Y405 Z405 F1800
      do I write like this? G1 H1 X700 Y700 Z700 F1800
        That should do it.
        • nemecekundefined
          nemecek
          gives me this error
          can I send you a video tomorrow? so you understand me better
            @nemecek said in bltouch:
            G1 X0 Y0 F6000 ; move X+Y to the centre
            https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Homing_the_machine
            See this section
            nemecekundefined 2 Replies Last reply Reply Quote 0
            • nemecekundefined
              nemecek @Phaedrux
              @Phaedrux good morning i read in your opinion should i delete it? G1 X0 Y0 F6000 ; move X+Y to the centre
              • nemecekundefined
                nemecek @Phaedrux
                @Phaedrux ok perfect I solved the problem of the z axis by deleting this G1 X0 Y0 F6000; move X + Y to the center now and only one bltouch problem you can do
                • nemecekundefined
                  nemecek
                  hi I managed to get it working by changing the P9 to the P5 should be P9
                  peche? can you explain it to me?
                  M558 P5 H5 F120 T3000
                    Yes the BLTouch should use P9.
                    I'm curious now what firmware version you are running. Should be 2.05.1.
                    Can you please send M122 and post the results?
                    • nemecekundefined
                      nemecek
                      yes
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                      Board ID: 08DGM-956GU-DJMSN-6J1FL-3SJ6S-T9NVD
                      Used output buffers: 3 of 24 (9 max)
                      Static ram: 25712
                      Dynamic ram: 92604 of which 396 recycled
                      Exception stack ram used: 432
                      Never used ram: 11928
                      Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,348) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 00:40:29 ago, cause: power up
                      Last software reset at 2020-06-28 19:10, reason: User, spinning module GCodes, available RAM 11968 bytes (slot 1)
                      Error status: 0
                      Free file entries: 10
                      SD card longest block write time: 6.1ms, max retries 0
                      MCU temperature: min 29.1, current 40.2, max 40.8
                      Supply voltage: min 11.9, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, SG min/max 0/381
                      Driver 1: standstill, SG min/max 0/371
                      Driver 2: standstill, SG min/max 0/377
                      Date/time: 2020-06-28 20:37:50
                      Slowest loop: 49.05ms; fastest: 0.07ms
                      Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 305348ms
                      === DDARing ===
                      Scheduled moves: 422, completed moves: 422, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 15.44ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is running
                        WiFi firmware version 1.23
                        WiFi MAC address 5c:cf:7f:76:6a:14
                        WiFi Vcc 3.34, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25944
                        WiFi IP address 192.168.1.35
                        WiFi signal strength -63dBm, reconnections 0, sleep mode modem
                        So what exactly happens when you have it set to P9 and do this test?
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_using_the_web_interface
                        • nemecekundefined
                          nemecek
                          it goes down without extracting the pin😭
                          • nemecekundefined
                            nemecek
                            total panic😬
                              And yet using M401 and M402 and G30 works?
                              m401 m402 g30 everything works
                              • nemecekundefined
                                nemecek
                                yes weird
                                • nemecekundefined
                                  nemecek
                                  what can I do? do I stay in P5?
                                    So does g30 cause it to drop the pin or not?
                                    nemecekundefined 1 Reply Last reply Reply Quote 0
                                    • nemecekundefined
                                      nemecek @Phaedrux
                                      @Phaedrux yes
                                        So I'm quite confused now. Is the BLtouch working or not?
                                        Does G32 work to run the auto calibration?
                                        • nemecekundefined
                                          nemecek @Phaedrux
                                          @Phaedrux yes on p5 everything works if instead I switch to p9 the g29 and g32 the probe does not come out
                                            Can you go through this section and perhaps create a new beg.g
                                            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Setting_up_the_auto_calibration_file
