    Strange homing behavior
    826
    • Chrissundefined
      Chriss @Chriss
      But I still think that there is a difference between homeall.g and homez.g.
      I have changed the homez.g a bit. I have now a "run 1" with a "G1 H1" and a little lift of that afterwards. Than the "run 2" with the "G30":
      G90
      M300 S800 P100
      G1 Y155 X155 F6000 ; go to first probe point
      M300 S300 P300
      M400
      M600 S800 P500
      G91               ; relative positioning
      ; Run 1
      G1 H1 Z-500 F200 ; move Z down until the endstop is triggered
      G1 H2 Z5 F6000    ; lift Z relative to current position
      M400
      ; Run 2
      M558 F60          ; Chriss - set the down speed
      M600 S800 P2000		; beep
      G30
      M558 F350         ; Change the speed back
      Step one get executed whether I call homez.g or homeall.g, but "step 2" produces a:
      Error: Z probe already triggered at start of probing move
      WHEN I execute it via homeall.g. It works fine when I execute homez.g.
      • JoergS5undefined
        JoergS5 @Chriss
        @Chriss so homeall sets some precondition which is different from when you call only homez. So need "only" shorten homeall until you find the reason...
          How have you wired the probe?
          Please post your full config.g
          Do not use G1 H1. It is for endstop and negates all of the probe settings.
          Chrissundefined 1 Reply Last reply Reply Quote 0
          • Chrissundefined
            Chriss @Phaedrux
            @JoergS5
            Yes, that was my idea too, bit look at it, there is not much to remove without making it completely useless. I need a homed X and Y to move Z.
            @Phaedrux said in Strange homing behavior:
            I connected it to "zprobe.in", VCC and GND from the same connector. The ir-probe is much more user-friendly than the bl-touch. 😉
            I do not expect a problem with the ir-touch itself, it worked more than 99,998% if I use "homez.g"
            You will find it at the end.
            I changed the config a bit this morning. I have now:
            Homez.g
            G90
            M400
            ; Run 1
            M558 F250          ; Chriss - set the down speed
            G30
            ; Run 2
            G30
            And homeall.g
            G1 H1 X-315 Y-315 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000       ; go back a few mm
            G1 H1 X-315 Y-315 F360  ; move slowly to X and Y axis endstops once more (second pass)
            M98 P"0:/sys/homez.g"
            config.g
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 08:05:32 GMT+0200 (Central European Summer Time)
            G90                                            ; send absolute coordinates...
            M83                                            ; ...but relative extruder moves
            M550 P"Homer"                                  ; set printer name
            M552 S1                                        ; enable network
            M586 P0 S1                                     ; enable HTTP
            M586 P1 S1                                     ; enable FTP
            M586 P2 S1                                     ; enable Telnet
            M569 P0 S0                                     ; physical drive 0 goes backward
            M569 P1 S1                                     ; physical drive 1 goes forwards
            M569 P2 S1                                     ; physical drive 2 goes forwards
            M569 P3 S1                                     ; physical drive 3 goes forwards
            M584 X0 Y1 Z2:9 E3                             ; Chriss - set drive mapping two Z motors connected to driver outputs E6(9) and Z(2)
            M671 X-28:330 Y155:155 S5.5                    ; Chriss - leadscrews at left (connected to E6(9)) and right (connected to E2) of X axis (S=MaxCorrection)
            M350 E16 I0                                    ; Chriss - without interpolation
            M350 X16 Y16 Z16 I1                            ; Chriss - configure microstepping with interpolation
            M92 X80.00 Y80.16 Z400.00 E431.06              ; Chriss - set steps per mm 2560     From Bondtech: E409.51   Original: E137.81 Calulator:
                                                           ; https://3d-druck-archiv.de/blog/grundlagen-3d-druck/steps-fuer-x-y-z-achse-einstellen-ueberpruefen-247
                                                           ; https://selbstgedruckt.de/berechnungstools/
            M566 X900.00 Y900.00 Z12.00 E120.00            ; Chriss - set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z800.00 E1200.00        ; Chriss - set maximum speeds (mm/min) Z180
            M201 X500.00 Y500.00 Z20.00 E250.00            ; Chriss - set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                        ; Set idle timeout
            M208 X0:310 Y0:300                             ; Chriss - X carriage moves from 0 to 310, Y bed goes from 0 to 310
            M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
            M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
            ; Z-Probe IR Probe
            M558 P1 C"^zprobe.in" H5 F120 T6000
            G31 P500 X-26.0 Y-9.0 Z1.85					; Z-probe location and offset
            ; M564 S0 to disable axis limits.
            ;https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
            ;M557 X10:270 Y40:270 P10:10                     ; Chriss - define mesh grid
            M557 X10:270 Y40:270 P5:5
            ;M557 X10:270 Y40:270 P2:2
            	     		                               ; https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
            ;; Heaters
            ;BED
            M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
            M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
            M307 H0 A245.4 C400.5 D1.3 S1.00 V24.1 B0	   ; Chriss - Disable bang-bang, tuned with "M303 H0 S80"
            											   ; https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
            M140 H0                                        ; map heated bed to heater 0
            ; Hotend
            M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
            M307 H1 A461.2 C156.1 D3.1 S1.00 V24.0 B0		; Chriss - tuned with "M303 H1 S250"
            ;; Fans
            ; Fan for the printed part:
            M950 F0 C"duex.fan4" Q500                           ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
            ; Fan for the Hotend;
            M950 F1 C"duex.fan3" Q500                      ; F="create fan 1" C="on pin duex.fan3" Q="and set its frequency"
            M106 P1 S1 H1 T45 C"Hotend"                    ; P="set fan 1" S="value" H="Thermostatic control Heater No." T=" is turned on at 45°C"
            ;; Tools
            ; Tool 0
            M563 P0 S"Extruder" D0 H1 F1                   ; define tool 0 (Fan F1  is bonded automatically)
            G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
            G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
            ;; Filament Sensors - https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors
            ; Sensor 0
            M591 D0 P1 C"e0_stop" S1  						; filament monitor connected to E0_stop
            ;; Misc
            ; Configure Port for the PaneDuo
            M575 P1 B57600 S1
            ;; EOF
              Do you have a Duex? M584 X0 Y1 Z2:9 E3 Drive 9?
              If so, you may want to define it here:
              M350 E16 I0 No interpolation for the poor extruder?
              The M140 must come before the M143 for your bed heater.
              ;BED
              M600 isn't a beep. It's a filament change pause.
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M600_Filament_change_pause
              ; Run 2
              G30
              You'd want M300
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M300_Play_beep_sound
              I'm actually wondering if some of your comments are being parsed strangely. The forum code block gets pretty confused by them as you can see, but when I copied and pasted it into a text editor with gcode highlighting it detected the comments ; correctly. Not sure how the Duet gcode parser could be handling it. Might be worth cleaning up your comments to be rather minimal particularly in the area where the URLs are.
              Can you send M558 P1 and G31 and see if it echoes back the same values as in config.g?
              • Chrissundefined
                Chriss @Phaedrux
                Indeed, I have one and it is connected. 😉
                Added
                I had some strange behaviors in the past with the original extruder. That may be different now with the bondtech. Well, I added it. Lets see later how that works now.
                Done!
                You are right, my bad. I wanted to change the frequency, which ended in the "double comand" and not "double frequency". Typo, I removed all of the beeps in the meantime anyway. They where for debug only anyway.
                Indeed, that is a very good idea. I removed all the URLs and removed other things like "°". Just in case, that would not be the first time that I have bombed a parser with unexpected characters. 😉
                Update:
                I tested/played a bit with the setup to understand the behavior better.
                Let me describe it like that: The "homeall.g" seems to work from time to time when "z" is not far away from the bed surface. But sometimes it drives into the bed.
                It seems that it gets triggered in the air only when "z" is more than 10cm away from the bed when I power on the printer. It works or drives into the bed when the head is below 5cm away from the bed.
                Did it make myself clear?
                Does that makes any sense to you?
                Cheers, Chriss
                  I thought we would at elast get something back from M558 P1.
                  Please try sending the full M558 command from your config.g in the console.
                  I can't remember if I asked before, but can you send M98 P"config.g" and see what you get for errors and messages?
                  • Chrissundefined
                    Chriss @Phaedrux
                    I did not fully understand what you mean. 😞 I added "M558 P1" at the end of config.g, without any result. I do not see any output of that, nowhere.
                    I tried telnet:
                    [chriss@leela ~]$ telnet 192.168.1.170
                    Trying 192.168.1.170...
                    Connected to 192.168.1.170.
                    Escape character is '^]'.
                    M558 P1
                    ok
                    I guess that you mean "M98 P"0:/sys/config.g""
                    HTTP is enabled on port 80
                    FTP is enabled on port 21
                    TELNET is enabled on port 23
                    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 270C
                    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 486C
                    ok
                    So no parsing error if you where aiming for that.
                    Cheers, Chriss
                      I mean send this in the console
                      And then try your homing.
                      Though I'm starting to wonder if it's something wrong with the IR probe itself.
                      • Chrissundefined
                        Chriss @Phaedrux
                        Done, with the same result, the probe get triggered in the air.
                        I have to admit that you may be right. I have in total 3 of the ir-probes here. Two for my corexy build and the one in my CR10.
                        I replaced the one at my CR10 now with a other one. That seems not brand new any more, but it seems to work now. :?
                        But it is a bit to early for me to blame the bl-touch. I will play a bit more with the new one before I will confirm that the new one is working.
                        And I will put the suspicious probe into the corexy for some tests.
                        Chrissundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                        • Chrissundefined
                          Chriss @Chriss
                          @Phaedrux
                          Can you explain the homeall.g to me, please?
                          I'm fully confused now. I removed the "M98" so source the homez.g from the homeall.g. So it looks like that now:
                          ; homeall.g
                          ; called to home all axes
                          ;M98 P"0:/sys/homez.g"
                          And you know what? The printer homes Z after it homed X and Y. WTF? I added a "beep" into the homez.g to test whether it get executed and not. And the printer beeped when I executed "G28" right after it homed X and Y.
                          So I think that the homez.g is executed whether I execute it or not.
                          Is that the expected behavior?
                          JoergS5undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • JoergS5undefined
                            JoergS5 @Chriss
                            @Chriss said in Strange homing behavior:
                            Do you mean your "IR probe" is a BLTouch? This would not be an IR probe and is configurated differently.
                            • Chrissundefined
                              Chriss @JoergS5
                              @JoergS5 said in Strange homing behavior:
                              Ahhhh.. no.. it is a IR-Probe! Not a BL-Touch, I replaces the BL-Touch with the IR-Probe.. sorry for the confusion. Forget the BL-Touch please..... My bad. 😞
                              • JoergS5undefined
                                JoergS5 @Chriss
                                @Chriss ok - this would be the easist solution 🙂
                                • JoergS5undefined
                                  JoergS5 @Chriss
                                  @Chriss if you run homeall and the Z is homed unexpectedly: do you have any special files lying around in the sys or macros folder, which could produce this behavior (tool changing, override,...)? To find the reason, you should delete every files and lines which are not needed. (backup all first)
                                  • Chrissundefined
                                    Chriss @JoergS5
                                    @JoergS5
                                    Hmmm... maybe but I do not see it, to be honest. I downloaded the content from the sdcard and grepped a bit in the files. The only files I found, which contain "G30" are:
                                    macros/00_Z-Level:G30 P0 X20 Y155 Z-99999; probe near a leadscrew, half way along Y axis
                                    macros/00_Z-Level:G30 P1 X250 Y155 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                                    sys/bed.g:G30 P0 X20 Y155 Z-99999; probe near a leadscrew, half way along Y axis
                                    sys/bed.g:G30 P1 X250 Y155 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                                    Binary file sys/Duet2CombinedFirmware.bin matches
                                    sys/homez.g:G30
                                    sys/homez.g:;G30               ; home Z by probing the bed
                                    sys/homez.g:;G30
                                    I fully understand your approach but I do not see any unexpected file. Or a file which may have it's bits in the cake.
                                    I'm still very confused that the IR probe, which caused all the problems in the CR10, works very, very well in the corexy. :?
                                    Directory listing of the CR10:
                                    ftp> cd macros
                                    250 Directory successfully changed.
                                    ftp> dir
                                    227 Entering Passive Mode (192,168,1,170,136,148)
                                    150 Here comes the directory listing.
                                    -rw-rw-rw- 1 ftp ftp           641 Mar 12 2019 01-Test_IR_PD_Homing
                                    -rw-rw-rw- 1 ftp ftp           640 May 30 2018 02-Test_Fans
                                    -rw-rw-rw- 1 ftp ftp          1099 May 24 2018 03-Test_Heaters
                                    -rw-rw-rw- 1 ftp ftp          2223 Mar 12 2019 04-Test_motors
                                    -rw-rw-rw- 1 ftp ftp           156 Jul 15 2019 SETNETWORK
                                    -rw-rw-rw- 1 ftp ftp           434 Jun 07 2020 99_Chriss_Beep
                                    -rw-rw-rw- 1 ftp ftp           199 Jul 02 2020 00_Z-Level
                                    -rw-rw-rw- 1 ftp ftp             7 Jun 07 2020 Allow Cold Extrude
                                    226 Transfer complete.
                                    ftp> cd ..
                                    ftp> cd sys
                                    ftp> dir
                                    227 Entering Passive Mode (192,168,1,170,162,76)
                                    -rw-rw-rw- 1 ftp ftp           462 Jul 02 2020 bed.g
                                    -rw-rw-rw- 1 ftp ftp          4782 Jul 03 2020 config.g
                                    -rw-rw-rw- 1 ftp ftp           483 Jun 22 2020 cancel.g
                                    -rw-rw-rw- 1 ftp ftp          1329 Jun 30 2020 stop.g
                                    -rw-rw-rw- 1 ftp ftp          4772 Jul 03 2020 config.g.bak
                                    -rw-rw-rw- 1 ftp ftp        277520 Feb 19 2019 DuetWiFiServer.bin
                                    -rw-rw-rw- 1 ftp ftp          3518 May 10 2020 config.json
                                    -rw-rw-rw- 1 ftp ftp         60164 May 03 2019 iap4e.bin
                                    -rw-rw-rw- 1 ftp ftp           843 Jun 28 2020 pause.g
                                    -rw-rw-rw- 1 ftp ftp           481 Jul 02 2020 start.g
                                    -rw-rw-rw- 1 ftp ftp           406 May 10 2020 resume.g
                                    -rw-rw-rw- 1 ftp ftp           181 May 10 2020 sleep.g
                                    -rw-rw-rw- 1 ftp ftp           716 Jul 02 2020 resurrect.g
                                    -rw-rw-rw- 1 ftp ftp           168 May 10 2020 tfree0.g
                                    -rw-rw-rw- 1 ftp ftp           228 May 10 2020 tpost0.g
                                    -rw-rw-rw- 1 ftp ftp           172 May 10 2020 tpre0.g
                                    -rw-rw-rw- 1 ftp ftp           126 May 17 2020 test1log.txt
                                    -rw-rw-rw- 1 ftp ftp           432 Jun 27 2020 test2log.txt
                                    -rw-rw-rw- 1 ftp ftp           354 May 10 2020 test3log.txt
                                    -rw-rw-rw- 1 ftp ftp            42 Aug 27 2019 test4log.txt
                                    -rw-rw-rw- 1 ftp ftp        506772 May 19 2020 Duet2CombinedFirmware.bin
                                    -rw-rw-rw- 1 ftp ftp        277520 Apr 29 2020 DuetWiFiServer-1.23.bin
                                    -rw-rw-rw- 1 ftp ftp           944 Jul 03 2020 homeall.g
                                    -rw-rw-rw- 1 ftp ftp           567 May 20 2020 homey.g
                                    -rw-rw-rw- 1 ftp ftp           210 May 10 2020 deployprobe.g
                                    -rw-rw-rw- 1 ftp ftp           566 May 20 2020 homex.g
                                    -rw-rw-rw- 1 ftp ftp           983 Jul 03 2020 homez.g
                                    -rw-rw-rw- 1 ftp ftp           432 Jun 28 2020 heightmap.csv
                                    -rw-rw-rw- 1 ftp ftp           213 May 10 2020 retractprobe.g
                                    -rw-rw-rw- 1 ftp ftp           509 Jun 23 2020 config-override.g
                                    -rw-rw-rw- 1 ftp ftp         40804 May 10 2020 Duet2CombinedIAP.bin
                                    -rw-rw-rw- 1 ftp ftp          3279 Jul 03 2020 dwc2settings.json
                                    ftp>
                                    • JoergS5undefined
                                      JoergS5 @Chriss
                                      @Chriss I can explain my approach: you say when you run homeall, your Z is homed. But homeall doesn't contain any Z movement (only Z5), so there must be anything which makes the Z movement to trigger the signal. So I thought, something automatic like a tool change (tfree, tpost), heating up or something other could trigger the Z movement.
                                      Looking at your files, bed.g could be triggered somehow.
                                      Other possibility: if you run homeall and the X and Y are already in their endstop positions, is there something specific so the IR probe triggers immediately? (is the position of the IR probe outside your bed, e.g.? => could be the case, as X is 26 and Y 9 mm off the nozzle. To try you could position X and Y somewhere in the middle of the bed before calling homeall) And if IR triggers if it is outside the bed, it may be that the probe must be inverted with a ! in the M558 C command and maybe reduce sensitivity value G31 P value.
                                        Phaedrux Moderator @Chriss
                                        That's pretty peculiar.
                                        Can you add an M400 before the M98 to call the homez? That should ensure it's finished all the previous X Y homing moves before moving on.
                                        • Chrissundefined
                                          Chriss @Phaedrux
                                          @Phaedrux
                                          Indeed, it is very peculiar. Well, I needed a break, to I used the weekend do work on my fun car, that was bit more promising. 😉
                                          I tested this morning 8-10 times with "G28" and all axes got homed. And this is the homeall.g:
                                          ; homeall.g
                                          M400
                                          Yes, Z got homed and yes, the beep from the homez.g changed every time I changed it. So there can be no other file involved.
                                          I do not know why but the trigger up in the air went completely away. :? All of my test this morning where successful. Do not ask my why, the only change from last week was a very, very long power cycle.
                                          But it is very odd to see the homing of Z but you know that you do not execute it from homeall.g. :?
                                          Anyway, my main problem, the trigger in the air, is magically gone now. I'm not sure if I want to touch that again or not, it is working for now. 😉
                                            Actually I think this is totally normal. Homeall is homing all axis. It completed the homeall.g and the z axis was still unhomed, so it executes home z.
