    Duet 2 Pro 4 U
    Hardware wishlist
    10
    38
    4.1k
      A Former User @NitroFreak
      @NitroFreak said in Duet 2 Pro 4 U:
      Please just make a high CPU powered version with no internal stepper drivers and integrated 5V signals for external servo (or stepper) drivers.
      that sounds like the cnc version of the duet3 (not sure about the 5v)?
      • Edgars Batnaundefined
        Edgars Batna @dc42
        @dc42 said in Duet 2 Pro 4 U:
        The processor will have about the same power as Duet 2 but more flash memory and RAM to make room for firmware improvements.
        Is there a significant reason to not upgrade the CPU further? It's better to have the power and not need it. Also, you know this better than I do, but more features / bigger code usually means longer critical path.
        I've also seen Atmel offering dual core SAMs. That would be quite fun having some tasks not blocking each other so much.
        Just brainstorm/-farting here.
          dc42 administrators @Edgars Batna
          @Edgars-Batna said in Duet 2 Pro 4 U:
          It's a matter of getting the price vs performance right. The faster processors from Microchip are a lot more expensive; whereas we are aiming to price this board at significantly less than the Duet WiFi and Duet Ethernet (although if the £ plummets in December then that may not be possible). For this board it would have been possible to switch to a non-Microchip processor because it doesn't need to support CAN-FD, but that would have increased the software development cost and time substantially.
          The additional features we have added to RRF recently do not put a significant additional load on the CPU. They are mostly alternative options (e.g. different kinematics, and 12864 LCD support as an alternative to PanelDue support) or features that are used only occasionally (e.g. conditional GCode, and probing in directions other than Z). So we don't need increased processor power yet.
          botundefined lepetitnicolasundefined 2 Replies Last reply Reply Quote 0
          • botundefined
            bot @dc42
            @dc42 Would faster CPU clock speeds and/or increased memory allow for faster printing of GCode with many small segments?
            I think Edgars is interested in having very fine mesh/segment/toolpath resolution while printing at increased speeds. I'm interested in this too, but I'm happy enough with the current Duet that I wouldn't be bothered if it never comes. Just a casual wish of mine to experiment and push the envelope.
            That said, I know you have ideas about motion planning, electronics, etc. that are far beyond my understanding. So, I'm just trying to convey the reason why we think we want faster CPUs. Perhaps you have a better way of achieving it which is even potentially currently possible on Duet hardware.
            *not actually a robot
            • pixelpieperundefined
              pixelpieper @dc42
              @dc42 why go the extension board route for the extra steppers? I would prefer to have them all on the board, gives a better thermal performance and you do not have to stock an extra board. I assume you look into 2209s, the additional cost for three more is not that high. You still could have a lite version of the same board where you only populate 5...
              Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
              Voron V0.250 / Duet 2 Maestro
              • lepetitnicolasundefined
                lepetitnicolas @dc42
                When do you release this new card ?
                Currently, i used raspberry with klipper and the support for raspberry like duet3 is a good thing
                Thanks
                  A Former User @lepetitnicolas
                  @lepetitnicolas said in Duet 2 Pro 4 U:
                  this is the latest news https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement/1?_=1593996217004
                  not sure if that was the board in question?
                    dc42 administrators @pixelpieper
                    @pixelpieper said in Duet 2 Pro 4 U:
                    A board with 8 drivers populated would need to be significantly larger. It would no longer be possible to keep it the same form factor as the existing Duet WiFi/Ethernet/Maestro, and the large PCB would add to the cost. Also, having an 8-driver board and offering a lite version with only 5 drivers populated is not a good option either for us (because we would have to get the production balance right and hold stocks of both types) or our users (because the 5-driver version would not be easily upgradable).
                      Here are the prototypes, both WiFi and Ethernet versions.
                        A Former User @dc42
                        two different pcb's or just for the prototypes?
                          Two different PCBs.
                            jay_s_uk
                            Is that a ESP-WROOM-02U wifi module?
                              A Former User @jay_s_uk
                              @jay_s_uk said in Duet 2 Pro 4 U:
                              ESP-WROOM-02U
                              it was more legible on another photo, but yes.
                                pixelpieper
                                Neat! I really like where this is going... Do I spot a CAN-FD-Connector in the left top?
                                  No, that's the SWD connector.
                                  • botundefined
                                    bot
                                    Did I miss where the types of drivers were announced? 5160? 2209?
                                    Never mind, saw the other thread.
                                    What would be the differentiation between this and the Duet2 Eth/Wifi?
                                    pixelpieperundefined A Former User? 2 Replies Last reply Reply Quote 0
                                      pixelpieper @bot
                                      @bot Modern drivers with Stealthchop, more Memory, Raspberry-Pi interface, Neopixel-Support
                                      • botundefined
                                        bot @pixelpieper
                                        Hmmm, more memory sounds good. How much more?
                                        I don't really care about the sound of the drivers. The 2260s in the Duet 2 work fine for me. Do the 2209's provide a slight reduction in the max amperage the drivers can push?
                                        dc42undefined pixelpieperundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @bot
                                          @bot said in Duet 2 Pro 4 U:
                                          Yes, they will probably be limited to about 2.0A peak. For users needing higher motor current, we have Duet 3.
                                          pixelpieperundefined A Former User? 2 Replies Last reply Reply Quote 1
                                            pixelpieper @bot
                                            @bot AFAIK double the flash, don' know about SRAM. The 2209s are rated up to 2A, so yes a downgrade from the Duet2 but an update from the Maestro.
