    Duet 2 Pro 4 U
    Hardware wishlist
    10
    38
    4.1k
      droftarts administrators @oliof
      @oliof Yes, I am aware of this! Though while the firmware implementation is working, the hardware still has to be modified at present, so an updated Duet 2 may have a dedicated header.
      But using an SBC is not on @Edgars-Batna 's wishlist! I was really pointing out that any updated Duet 2 might be closer to Duet 3, and have features that he would not use. So perhaps Duet 3 is not as great a jump as he was thinking it might be, especially as Duet 3 does not NEED an SBC to run.
      Edgars Batnaundefined 1 Reply Last reply Reply Quote 1
      • Edgars Batnaundefined
        Edgars Batna @droftarts
        @droftarts @oliof
        I've got 8 steppers connected, running Duet 2 Wifi + Duex 5 currently.
        Switching the printer to Duet 3 would mean £185.00 + £85.00 and I've got 2 leftover boards and loads of cabling changes.
        If there was a Duet 2 Pro, then I suppose that'd be closer to Duet 2: £120.00 and I'd just swap the main board, staying compatible.
        For me the SBC does not add that much. It's an interesting addition, for sure, but it theoretically just adds cost.
        • botundefined
          bot
          If there was a board made as a direct "drop in" replacement for the Duet 2, but which had better specifications to allow faster print speeds/pulse generation/etc., I would buy it, even if it cost twice what the duet 2 does now.
          *not actually a robot
            A Former User @bot
            @bot said in Duet 2 Pro 4 U:
            no rumours about the cpu yet, but seems unlikey to be a major upgrade as it might require dc42 to release yet another build config. maybe the man himself has something to add?
              I can release a little more information about the new board.
              When we designed the Duet WiFi and Duet Ethernet, our aim was to make one board that would be suitable for nearly everyone. So it needed a lot of expandability and high current stepper drivers.
              We now have Duet 3, which covers situations requiring high expandability and/or high current stepper drivers and/or increased processing power. So the new board does not need to offer those things. Instead it will provide features that the Duet WiFi/Ethernet lack, such as more modern stepper drivers, simplified wiring for BLTouch, a 5V output for laser devices and VFDs, on-board 12V supply for fans, Neopixel support, and a Raspberry Pi connector. The processor will have about the same power as Duet 2 but more flash memory and RAM to make room for firmware improvements. Like Duet 3 it will be capable of running either with a Raspberry Pi, or standalone using on-board Ethernet, with a WiFi version too. There will be no expansion connector like the one on the Duet 2, but there will be an optional daughter board to carry additional stepper drivers, similar to the one for the Maestro. We will likely offer an alternative daughter board to provide 5V signals for up to three external stepper drivers. Other expansion will be via I/O connectors similar to the 5-pin ones that we use on Duet 3.
              NitroFreakundefined Edgars Batnaundefined pixelpieperundefined 3 Replies Last reply Reply Quote 7
              • NitroFreakundefined
                NitroFreak @dc42
                @dc42 said in Duet 2 Pro 4 U:
                Please just make a high CPU powered version with no internal stepper drivers and integrated 5V signals for external servo (or stepper) drivers. They can make use of the CPU speed. If that board is cheaper it can aid in the adoption of servos.
                  A Former User @NitroFreak
                  @NitroFreak said in Duet 2 Pro 4 U:
                  that sounds like the cnc version of the duet3 (not sure about the 5v)?
                    Edgars Batna @dc42
                    Is there a significant reason to not upgrade the CPU further? It's better to have the power and not need it. Also, you know this better than I do, but more features / bigger code usually means longer critical path.
                    I've also seen Atmel offering dual core SAMs. That would be quite fun having some tasks not blocking each other so much.
                    Just brainstorm/-farting here.
                      dc42 administrators @Edgars Batna
                      @Edgars-Batna said in Duet 2 Pro 4 U:
                      It's a matter of getting the price vs performance right. The faster processors from Microchip are a lot more expensive; whereas we are aiming to price this board at significantly less than the Duet WiFi and Duet Ethernet (although if the £ plummets in December then that may not be possible). For this board it would have been possible to switch to a non-Microchip processor because it doesn't need to support CAN-FD, but that would have increased the software development cost and time substantially.
                      The additional features we have added to RRF recently do not put a significant additional load on the CPU. They are mostly alternative options (e.g. different kinematics, and 12864 LCD support as an alternative to PanelDue support) or features that are used only occasionally (e.g. conditional GCode, and probing in directions other than Z). So we don't need increased processor power yet.
                      botundefined lepetitnicolasundefined 2 Replies Last reply Reply Quote 0
                      • botundefined
                        bot @dc42
                        @dc42 Would faster CPU clock speeds and/or increased memory allow for faster printing of GCode with many small segments?
                        I think Edgars is interested in having very fine mesh/segment/toolpath resolution while printing at increased speeds. I'm interested in this too, but I'm happy enough with the current Duet that I wouldn't be bothered if it never comes. Just a casual wish of mine to experiment and push the envelope.
                        That said, I know you have ideas about motion planning, electronics, etc. that are far beyond my understanding. So, I'm just trying to convey the reason why we think we want faster CPUs. Perhaps you have a better way of achieving it which is even potentially currently possible on Duet hardware.
                        • pixelpieperundefined
                          pixelpieper @dc42
                          @dc42 why go the extension board route for the extra steppers? I would prefer to have them all on the board, gives a better thermal performance and you do not have to stock an extra board. I assume you look into 2209s, the additional cost for three more is not that high. You still could have a lite version of the same board where you only populate 5...
                          Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                          Voron V0.250 / Duet 2 Maestro
                          • lepetitnicolasundefined
                            lepetitnicolas @dc42
                            When do you release this new card ?
                            Currently, i used raspberry with klipper and the support for raspberry like duet3 is a good thing
                            Thanks
                              A Former User @lepetitnicolas
                              @lepetitnicolas said in Duet 2 Pro 4 U:
                              this is the latest news https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement/1?_=1593996217004
                              not sure if that was the board in question?
                                dc42 administrators @pixelpieper
                                @pixelpieper said in Duet 2 Pro 4 U:
                                A board with 8 drivers populated would need to be significantly larger. It would no longer be possible to keep it the same form factor as the existing Duet WiFi/Ethernet/Maestro, and the large PCB would add to the cost. Also, having an 8-driver board and offering a lite version with only 5 drivers populated is not a good option either for us (because we would have to get the production balance right and hold stocks of both types) or our users (because the 5-driver version would not be easily upgradable).
                                  Here are the prototypes, both WiFi and Ethernet versions.
                                    A Former User @dc42
                                    two different pcb's or just for the prototypes?
                                      Two different PCBs.
                                        jay_s_uk
                                        Is that a ESP-WROOM-02U wifi module?
                                          A Former User @jay_s_uk
                                          @jay_s_uk said in Duet 2 Pro 4 U:
                                          ESP-WROOM-02U
                                          it was more legible on another photo, but yes.
                                            pixelpieper
                                            Neat! I really like where this is going... Do I spot a CAN-FD-Connector in the left top?
