    Issues with print quality, wall surface rough.
    138
    14.9k
    • CorvoDewittV2undefined
      CorvoDewittV2 @mwolter
      @mwolter I'll try a temp tower, Ill have to look up how to do that in idea maker. Yeah I'll have to do something with the fans. That might take me awhile lol. I tried printing a cube at 220 and 107% flow, just to show I guess? Anyway:
      • mwolterundefined
        mwolter
        To me, the 220 107% print is bulging and looks melted. Like a marshmallow.
        CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
        • PDBealundefined
          PDBeal
          I had a similar issue on a machine that showed vertical walls like in your picture. In my case, my extruder current was my issue. I increased my current from 600mA to 800mA in config.g and that took care of the weird striping issues. I'm assuming the backpressure inside the nozzle caused it to over/under extrude on a regular basis creating the bulging.
          It's an easy test to increase your extruder motor current and then print again. Just something I've experienced with similar results as in your picture.
          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 2
            Have you PID tuned the bed and hot end heaters?
              CorvoDewittV2 @PDBeal
              @PDBeal I will try that when I get home!
                CorvoDewittV2 @Phaedrux
                @Phaedrux Yep, temp is very stable, about +/-0.6c
                  @mwolter not as tasty tho haha, I'm probably printing too hot then. I'll go down to 205? 195 felt a bit weak to me.
                    I might try swapping out the backlash nuts for regular nuts and seeing if it's a binding issue.
                      @Phaedrux Can I just back off the backlash adjustors? They are this style nut :
                      https://openbuildspartstore.com/anti-backlash-nut-block-for-8mm-metric-acme-lead-screw/
                        CorvoDewittV2
                        Well here is 950mA on the extruder, temp 205. Really starting to think it's an extruder problem again:
                          CorvoDewittV2
                          Or... It's a z problem... Backed off the antibacklash nuts, same setting as last posts
                          • Corexyundefined
                            Corexy
                            I think it's a mechanical issue relating to the Z axis.
                            You are certainly over extruding in most of these pics, but 0.93-0.95 has always been the right extrusion multiplier for PLA for me....IF the esteps are set correctly. I always set my esteps through a nozzle at the temp I intend to print at. Usually at 195-205 deg for PLA, maybe just try a round number of 200. Set your esteps using a full 100mm extrude @ 5mm/sec, not just 20mm.
                            I didn't read what slicer you used, but for direct drive in S3D I just use 1mm retraction @30mm/sec, 1mm coast and 5mm wipe. Nice and simple.
                            In the V-core, I'd loosen all the mounts for the backlash nuts, Z steppers and even the rails, then push the bed up and down by hand to align it all. Keep doing that as you nip things up tighter, a look for any binding at all. I'd level the bed mechanically using a 0.2mm feeler gauge under the nozzle, with the bed and nozzle at temp (200 noz/ 50 bed) and check the backlash nuts are very lightly/evenly tensioned, as well as lubricated.
                            If you can get the bed pretty level mechanically, maybe disable the bed leveling mesh map and just set a nozzle height/offset at the start of the print. If you're using the triple Z motors that might be giving you some sort of trouble.
                            In short, there are some extrusion rate/slicer setting issues there, but that Z banding looks mechanical to me.
                            Hope that helps.
                              CorvoDewittV2 @Corexy
                              @Corexy Thank you for the info, I will try that tonight after work. I really don't like the design of the Z axis on the V-Core, leaves a lot to be desired in my mind. Also not a huge fan of lead screws. Do you use wipe and coast with linear advance? I heard that they do not play well. My bed is a bit of a banana, but flat enough to do a 20x20 cube, so I could try no bed leveling. If you have any design suggestions for a better Z, please let me know! What do you think is causing the bulging right above and below the X and Y? Cooling? Or still Z related.
                              OH could it be bad idle pulleys? It's the only thing I haven't changed in the XY system.
                              Corexyundefined Scachiundefined 2 Replies Last reply Reply Quote 0
                              • Corexyundefined
                                Corexy @CorvoDewittV2
                                @CorvoDewittV2 said in Issues with print quality, wall surface rough.:
                                I don't use linear advance, just the settings I've described above. I really focus on esteps, and set extrusion multiplier by watching actual prints I'm doing, not measuring thin walls etc.
                                I don't like the way they set up the z axis on the V-core's either, and have already taken steps to do mine differently, including a conversion to single Z motor with a belt driving all 3 screws.
                                My bed is a banana too, which is why I'll probably convert to a cast aluminium plate.
                                I think the bulging is from the issues I mentioned, best start there. If you can switch off the bed leveling and print this little model on a flat bit, you can try those old school setting first. You could have a look at the current setting for your extruder motor. Sometimes too high a current there can cause print issues, but it's usually a wavy looking pattern on the surface.
                                1. Do the loosening/tightening of Z components mentioned above.
                                2. Set extruder current.
                                3. Poke a correct size cleaning wire into the hot nozzle, just to be sure.
                                4. Set esteps carefully using 100mm extrusion @ 5mm/sec
                                5. Set slicer at 0.94 extrusion multiplier, 30mm/sec print speed, 1mm retraction, 1mm coast.
                                6. First layer 205/55, zero fan. Second layer 195/50 20% fan.
                                Don't buy new parts, it's most likely assembly and slicer settings. Try that first.
                                Hope that helps again
                                • Scachiundefined
                                  Scachi @CorvoDewittV2
                                  @CorvoDewittV2 Did you buy it as a kit ? Did you ask them (where you bought it from or the guys who designed it) if the have experience with this issues ? Perhaps it is a common issue and they know the most common cause in their design that can cause it.
                                    @Corexy Thank you for the advice! I went through the Z axis very carefully, and made no change to the print quality 😞 I will try those setting tomorrow! I will also try a lower extruder current, cause why not at this point lol. You said you have a V-Core, how did you set it up so it works as intended???? I've been at this for 2 months and have made little change!!! Thanks again!
                                    Corexyundefined 1 Reply Last reply Reply Quote 0
                                      CorvoDewittV2 @Scachi
                                      @Scachi They have a Facebook group I have been posting in, with no help from the mods. One guy has actually been helping a lot, we are still chit-chatting about this thing. I really don't understand why I am having such an issue. It's so frustrating.
                                      • Corexyundefined
                                        Mine's still new in the box, untouched. Been to busy with work and a house reno job to start it.
                                        I have preemptively ordered some bits to do the Z axis and bed how I want though, and will start a build thread when I kick it off.
                                        • Corexyundefined
                                          It's certainly not a kit to learn on, moreso a base on which to start an advanced build I'd say.
                                          I must say it's smart of them to stick with selling the mechanical bits rather than a finished printer, as it removes a lot of responsibility for print quality etc.
                                          You might try posting in the reprap forums "corexy" section, as there's a few experts available there too.
                                          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
                                            Worn nozzle or PTFE tube perhaps?
