RRF Config Mapping
1.8k
    printthatthing
    Hi, running 3.1.1 on Duet 2 Wifi with BL-Touch, no Duex addon.
    How do I setup this?
    Thank you
    undefined 1 Reply Last reply 7 Jul 2020, 21:02 Reply Quote 0
      DIY-O-Sphere @printthatthing
      @printthatthing
      Leave it as it is....
      You can edit that later on in the config.g
      M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
      You have to change that to
      M950 S0 C"!duex.pwm5"
      or rename to
      M950 S0 C"exp.heater7"
      You will find the full list of heater pin names here
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
      (UTC+1)
        There's currently a bug in the configurator that doesn't present the correct pin choices. So you'll have to rename the pin to match what you're using as @DIY-O-Sphere says. This will hopefully be corrected soon.
          printthatthing
          Thank you, I can now deploy and retract bltouch pin manually by
          M280 P0 S10 I1
          M280 P0 S90 I1
          When running home all X & Y homes okay and Z starts moving down to bed without deploying pin so I have to kill the power before it hits the bed.
          If I deploy the pin manually before home all it stop Z when pin detect surface but it does not raise Z to do a second messurement.
          M550 P"Formbot Raptor 2" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z640.00 E415.00 ; set steps per mm
          M84 S30 ; Set idle timeout
          M208 X400 Y400 Z500 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
          M950 S0 C"!duex.pwm5" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X66 Y33 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X35:215 Y35:195 S20 ; define mesh grid
          undefined 1 Reply Last reply 8 Jul 2020, 21:20 Reply Quote 0
            JoergS5 @printthatthing
            @printthatthing please use M558 first, then M950 for the zprobe. If this is not sufficient, please show homeall.g
            And there is something wrong, you dont need I1 with rrf3. https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3 last section.
            undefined 1 Reply Last reply 8 Jul 2020, 21:34 Reply Quote 0
              printthatthing @JoergS5
              Thank you, here is my homeall.g
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jul 08 2020 20:58:26 GMT+0200 (centraleuropeisk sommartid)
              G91 ; relative positioning
              G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G1 H1 Z-355 F360 ; move Z down stopping at the endstop
              G90 ; absolute positioning
              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
              ;G91 ; relative positioning
              ;G90 ; absolute positioning
              undefined 1 Reply Last reply 8 Jul 2020, 21:38 Reply Quote 0
                @printthatthing the printer doesnt know where z 0 is, a G30 is missing. G30 uses the bltouch to set it. Call G30 after x and y endstop setting, but before G1 Z0
                After the G90 in most cases x and y are moved to the middle of the bed, then G30
                undefined 1 Reply Last reply 8 Jul 2020, 21:40 Reply Quote 0
                  @JoergS5 I get it a try tomorrow. Thank you for all help.
                  undefined 1 Reply Last reply 8 Jul 2020, 21:52 Reply Quote 0
                    @printthatthing the
                    G1 H1 Z-355 F360
                    should be a replacement for what I proposed (the G30 proposal), but 355 is less than the 500 height of M208, so 0 may not be reached, I would set it higher to Z-600.
                    And the G92 Z0 is not needed, because the G1 H1 Z... already sets Z to the M208 minimum for Z, ie 0.
                    The sensitivity setting G31 P is probably wrong, please set P25 instead.
                      G31 P25 X66 Y33 Z2.5 ; set Z probe trigger value, offset and trigger height
                      Remove the ! from duex.pwm5
                      Change G31 P500 to P25
                      in homeall change
                      To
                      G1 X150 Y150 F6000 ; move Z down stopping at the endstop
                      G30 ; probe the bed
                        printthatthing
                        Thank you all again. I think I have it running now.
                        I had to keep ! for duex.pwm5 else it does not probe.
                        config.g
                        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jul 08 2020 21:18:31 GMT+0200 (centraleuropeisk sommartid)
                        M208 X400 Y400 Z350 S0 ; set axis maxima
                        G31 P25 X-25 Y-5 Z0.489 ; set Z probe trigger value, offset and trigger height
                        M557 X5:380 Y5:380 S20 ; define mesh grid
                        homeall.g
                        ; homeall.g
                        Is the heatmap very bad or ok to use without adjustments?
                        undefined 1 Reply Last reply 9 Jul 2020, 22:27 Reply Quote 0
                          As you have no DueX, you are not connecting the servo pin of the BLTouch duex.pwm5, so you should not use that selection in configtool or config.g. Use the name of the actual pin that you have connected it to, which is exp.heater7, and don't invert it. Although as it happens, using duex.pwm5 and inverting it will work.
                          undefined undefined 2 Replies Last reply 9 Jul 2020, 10:52 Reply Quote 0
                            printthatthing @dc42
                            @dc42 Aha, okay that make sense.
                              Phaedrux Moderator @dc42
                              @dc42 said in RRF Config Mapping:
                              Unfortunately the config tool currently doesn't show the expansion pins right now, just duex pins.
                                Phaedrux Moderator @printthatthing
                                @printthatthing said in RRF Config Mapping:
                                That's a bit of a saddle shape for sure. You may or may not be able to fix that physically. You can test the effect of the compensation by printing a bed test like this: bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                                undefined 1 Reply Last reply 10 Jul 2020, 19:57 Reply Quote 0
                                  printthatthing @Phaedrux
                                  @Phaedrux Ok thanks.
                                    printthatthing
                                    Now I'm stuck with error at bed heating.
                                    Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                                    Duet 2 Wifi power a solid state relay for a 220v heater.
                                    I executed M307 H0 S90
                                    M307 H0 results in below.
                                    Heater 0 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.00, calibration voltage 0.0, mode bang-bang
                                    Then I tried to save the value
                                    M307 H0 A340 C140 D5.5 V0 B0
                                    But it result in
                                    Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                      That's expected. The warning is letting you know what the max uncontrolled temp could be.
                                      undefined 1 Reply Last reply 10 Jul 2020, 20:29 Reply Quote 0
                                        @Phaedrux Ok, but I still not able to heat the bed. It start heating but halt after few seconds. Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                                          Are you sure you saved the PID tuning results with M500? Do you also have an M501 at the end of config.g to load the saved results?
                                          undefined 1 Reply Last reply 10 Jul 2020, 21:08 Reply Quote 0
                                          6 out of 26
