Bltouch setup need help
Firmware installation
3.9k
    Elvis0z
    @JoergS5 said in Bltouch setup need help:
    G1 Z-10
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3SD-6J9D0-3S86Q-1AMBF
    Used output buffers: 3 of 24 (10 max)
    Static ram: 27980
    Dynamic ram: 93712 of which 44 recycled
    Exception stack ram used: 264
    Never used ram: 9072
    Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:00:35 ago, cause: software
    Last software reset at 2020-07-09 19:59, reason: User, spinning module GCodes, available RAM 8584 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 30.6, current 31.7, max 32.0
    Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-07-09 19:59:45
    Cache data hit count 60372819
    Slowest loop: 4.74ms; fastest: 0.13ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.1ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 41.57ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:2d:b3:11
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 20056
      WiFi IP address 192.168.50.68
      WiFi signal strength -46dBm, reconnections 0, sleep mode modem
    09/07/2020, 20:00:48 G1 Z10
    Error: G0/G1: insufficient axes homed
    09/07/2020, 20:01:17 G1 Z-10
      Elvis0z
      When I do a G28 command once z probe deploys the console just spins around and I can't put any commands in till I restart control board
      undefined 1 Reply Last reply 9 Jul 2020, 12:12 Reply Quote 0
        JoergS5 @Elvis0z
        @Elvis0z first sorry for my G1 Z-10 and G1 Z10. This will not work because Z is not homed. The correct commands are G1 H2 Z-10 and H1 H2 Z10 to move even when the Z is not homed. Just to check Z can move at all at this position.
        I was searching what this fast white LED blinking means, but I can only find fast red blinking (which would be eg white and black cables switched).
        Can you please make an image of the wiring of the Duet Wifi and the cables at the 5-pin connector of the BLTouch?
          Elvis0z
          G1 H2 Z-10
          Yep moves up and down with new commands
          undefined 1 Reply Last reply 9 Jul 2020, 12:25 Reply Quote 0
            JoergS5 @Elvis0z
            @Elvis0z I have no more ideas.
            Two things I found in my research:
            • often it was a wiring problem. Wrong wiring, wiring or connector broke or disturbance by heat or magnets
            • on reddit was a report of a damaged charge of BLtouch 3.1. But you tried 2 BLtouch, I think probability is low for this reason
            I have only one idea left: please recheck wiring and connections. And the other idea to find out the reason for the error message of M98 P"config.g".
            If I have a new idea, I'll tell you.
              Elvis0z
              Wiring for bltouch
                Elvis0z
                Black wire is connected to white
                Blue wire is connected to black
                undefined 2 Replies Last reply 9 Jul 2020, 12:42 Reply Quote 0
                  JoergS5 @Elvis0z
                  @Elvis0z looks all ok.
                    JoergS5 @Elvis0z
                    @Elvis0z what you can try is the G30 has some options:
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                    e.g. you could try the
                    G30 P0 X20 Y50 Z-99999
                    or
                    G30 S-1
                    etc.
                    and try to find out why Z is not moving with the G30 without parameters.
                    I would run homeall to home X and Y and position in the middle of the bed, comment out the rest of homall and make the tests with G30 from the console input field.
                      Elvis0z
                      Thanks for your help so far. Bit of a mystery
                        Does your Z axis move at all? Does it raise and lower slightly when you do home all?
                        If you send G92 Z100 to mark it as homed and at position 100mm, then send G91 for relative moves, and then G1 Z10 it should move up 10mm.
                          Elvis0z
                          @Phaedrux said in Bltouch setup need help:
                          G1 Z10
                          Yep moved up 10mm
                            Elvis0z
                            Once I did those commands it said that z was homed. But when I did home all it does the same thing as in the video.
                              Elvis0z
                              Woohoo don't know what I did but it homed z when I did home all. As the command G92 z100 homed the z, I was able to calibrate the Zprobe trigger hight in the centre of the bed. Then there where a few errors
                              G28
                              Error: Z probe was not triggered during probing move
                              Error: Homing failed
                              Same stuff.
                              Then the bltouch was just blinking red led. I raised up the bed another 10mm and restarted the printer and the blinking stopped.
                              Tried G30 said that not enoght axis homed so homed x and y. Then did G30 and it deployed the probe and when down and retracted when touching the bed did this again and homed.
                              Then I did a home all and woohoo it worked.
                              so I have not idea what went on but hey its working
                              Thanks for all the help getting my printer working. I really appreciate all the help you guys have given me. Next is to do bed leveling.
                              undefined 1 Reply Last reply 10 Jul 2020, 07:12 Reply Quote 0
                                I have no idea what happened either, but glad it's working.
                                  JoergS5 @Elvis0z
                                  @Elvis0z I expect it will remain a mystery... but I am happy that it works for you now!
                                  87 out of 93
