    Bltouch setup need help
    Firmware installation
    3.9k
    • JoergS5undefined
      JoergS5 @Elvis0z
      @Elvis0z maybe its the
      M203 X6000.00 Y6000.00 Z180.00 E6000.00
      setting, because Z moves with maximum 3 mm/second, which will take forever at this distance on the video. Please set higher and try again.
      PS the video was very helpful, this was a good idea!!
      • Elvis0zundefined
        Elvis0z
        should I put the same as x and y?
        • JoergS5undefined
          JoergS5 @Elvis0z
          @Elvis0z you have trapezoid at Z, the stepper turns 5 rotations per second, your trapezoid has 2 mm for every rotation, so 10 mm/s, the value for Z should be 600 mm/min. The stepper could run 16 rotations/s maximum, but better be on the safe side.
          • Elvis0zundefined
            Elvis0z
            Thanks for your help.
            • Elvis0zundefined
              Elvis0z
              So just to make sure I have to home z before I can do anything else?
              • Elvis0zundefined
                Elvis0z
                Ahhhhh gets to the same point and deploys probe then nothing like in the video
                • JoergS5undefined
                  JoergS5 @Elvis0z
                  @Elvis0z please see above, take 600. 6000 ist too much for the stepper.
                  • JoergS5undefined
                    JoergS5 @Elvis0z
                    @Elvis0z said in Bltouch setup need help:
                    the printer want to have homed all axes before it proceeds.
                    • Elvis0zundefined
                      Elvis0z
                      G28
                      Error: Z probe was not triggered during probing move
                      Error: Homing failed
                      Just keep getting this error
                      • JoergS5undefined
                        JoergS5 @Elvis0z
                        @Elvis0z can you make a M122 after the G28 test please and show?
                        An does G1 Z10 and G1 Z-10 move as expected when you run this commands directly?
                        • Elvis0zundefined
                          Elvis0z
                          @JoergS5 said in Bltouch setup need help:
                          G1 Z-10
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                          Board ID: 08DGM-9T6BU-FG3SD-6J9D0-3S86Q-1AMBF
                          Used output buffers: 3 of 24 (10 max)
                          Static ram: 27980
                          Dynamic ram: 93712 of which 44 recycled
                          Exception stack ram used: 264
                          Never used ram: 9072
                          Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                          Owned mutexes:
                          Last reset 00:00:35 ago, cause: software
                          Last software reset at 2020-07-09 19:59, reason: User, spinning module GCodes, available RAM 8584 bytes (slot 1)
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                          Error status: 0
                          MCU temperature: min 30.6, current 31.7, max 32.0
                          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          Date/time: 2020-07-09 19:59:45
                          Cache data hit count 60372819
                          Slowest loop: 4.74ms; fastest: 0.13ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                          === MainDDARing ===
                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 41.57ms; fastest: 0.00ms
                          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is active
                            WiFi firmware version 1.23
                            WiFi MAC address ec:fa:bc:2d:b3:11
                            WiFi Vcc 3.36, reset reason Unknown
                            WiFi flash size 4194304, free heap 20056
                            WiFi IP address 192.168.50.68
                            WiFi signal strength -46dBm, reconnections 0, sleep mode modem
                          09/07/2020, 20:00:48 G1 Z10
                          Error: G0/G1: insufficient axes homed
                          09/07/2020, 20:01:17 G1 Z-10
                          • Elvis0zundefined
                            Elvis0z
                            When I do a G28 command once z probe deploys the console just spins around and I can't put any commands in till I restart control board
                            • JoergS5undefined
                              JoergS5 @Elvis0z
                              @Elvis0z first sorry for my G1 Z-10 and G1 Z10. This will not work because Z is not homed. The correct commands are G1 H2 Z-10 and H1 H2 Z10 to move even when the Z is not homed. Just to check Z can move at all at this position.
                              I was searching what this fast white LED blinking means, but I can only find fast red blinking (which would be eg white and black cables switched).
                              Can you please make an image of the wiring of the Duet Wifi and the cables at the 5-pin connector of the BLTouch?
                              • Elvis0zundefined
                                Elvis0z
                                G1 H2 Z-10
                                Yep moves up and down with new commands
                                • JoergS5undefined
                                  JoergS5 @Elvis0z
                                  @Elvis0z I have no more ideas.
                                  Two things I found in my research:
                                  • often it was a wiring problem. Wrong wiring, wiring or connector broke or disturbance by heat or magnets
                                  • on reddit was a report of a damaged charge of BLtouch 3.1. But you tried 2 BLtouch, I think probability is low for this reason
                                  I have only one idea left: please recheck wiring and connections. And the other idea to find out the reason for the error message of M98 P"config.g".
                                  If I have a new idea, I'll tell you.
                                  • Elvis0zundefined
                                    Elvis0z
                                    Wiring for bltouch
                                    • Elvis0zundefined
                                      Elvis0z
                                      Black wire is connected to white
                                      Blue wire is connected to black
                                      JoergS5undefined 2 Replies Last reply Reply Quote 0
                                      • JoergS5undefined
                                        JoergS5 @Elvis0z
                                        @Elvis0z looks all ok.
                                        • JoergS5undefined
                                          JoergS5 @Elvis0z
                                          @Elvis0z what you can try is the G30 has some options:
                                          https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                                          e.g. you could try the
                                          G30 P0 X20 Y50 Z-99999
                                          or
                                          G30 S-1
                                          etc.
                                          and try to find out why Z is not moving with the G30 without parameters.
                                          I would run homeall to home X and Y and position in the middle of the bed, comment out the rest of homall and make the tests with G30 from the console input field.
                                          • Elvis0zundefined
                                            Elvis0z
                                            Thanks for your help so far. Bit of a mystery
