    bltouch 3.1duet 2 wifi duex5 firmware version v3.1.3
    604
    • konte1978undefined
      konte1978
      Good morning I need help, I can't configure my bltouch 3.1 on my 3d print, mount duet2 wifi v1.04 and duex5 v 0.10, you could compile the attached file for me.
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jul 08 2020 12:06:30 GMT+0200 (CEST)
      M550 P"cube pro duo" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P9 S1 ; physical drive 9 goes forwards
      M584 X0 Y1 Z2 E3:4:9 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X87.35 Y86.69 Z1076.77 E82.09:82.09:82.09 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z1200.00 E600.00:600.00:600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z800 E800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X290 Y298 Z210 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M308 S1 P"e0temp" Y"thermistor" T100000 B5500 ; configure sensor 1 as thermistor on pin e0temp
      M308 S2 P"e1temp" Y"thermistor" T100000 B5500 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M308 S3 P"duex.e2temp" Y"thermistor" T100000 B5500 ; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
      M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limi
      M106 P0 C"ESTRUSORI" S0 H3:2:1 T120 ; set fan 0 name and value. Thermostatic control is turned on
      M106 P1 C"NOZZLE" S0 H1:2:3 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 C"LUCI LED" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
      M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
      M106 P3 C"VENTOLA 6" S0 H-1 ; set fan 3 name and value. Thermostatic control is turned off
      M950 F4 C"duex.fan7" Q500 ; create fan 4 on pin duex.fan7 and set its frequency
      M106 P4 C"VENTOLA 7" S0 H-1 ; set fan 4 name and value. Thermostatic control is turned off
      M563 P0 S"estrusero 1" D0 H1 F0:1 ; define tool 0
      M563 P1 S"estrusero 2" D1 H2 F0:1 ; define tool 1
      M563 P2 S"estrusero 3" D2 H3 F0:1 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      • baird1faundefined
        baird1fa
        You don’t have a z probe configured. You should follow the guides for duet z probes. Google duet zprobes. There is a good guide that will help.
          konte1978
          hi I tried with this configuration but nothing, I can help where I went wrong
          M307 H7 A-1 C-1 D-1 ; disabilita uscita del riscaldatore estrusore 7 che è in comune con pwm5
          M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          aidarundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
          • aidarundefined
            aidar @konte1978
            @konte1978 said in bltouch 3.1duet 2 wifi duex5 firmware version v3.1.3:
            M307 - you dont need to use it as you didnt define heater on those pins
            G31 P500 - it is recommended to use P25 with BLTouch, instead of 500
            What is in your deployprobe.g and extractprobe.g files ?
            konte1978undefined 1 Reply Last reply Reply Quote 0
            • DIY-O-Sphereundefined
              DIY-O-Sphere @konte1978
              General preferences
              M669 kinematic typ is missing
              (UTC+1)
                konte1978 @aidar
                @aidar
                deployprobe.g
                M280 P0 S10 ; deploy BLTouch
                retractprobe.g
                M280 P0 S90 ; retract BLTouch
                  konte1978
                  @aidar said in bltouch 3.1duet 2 wifi duex5 firmware version v3.1.3:
                  in addition with this configuration when I run home all it returns me as error "g28 error failed to anable endstop" and z axis does not move.
                  • aidarundefined
                    aidar
                    Well you dont have Z endstop defined, you have probe for homing z. So you should use G30 for homing Z, but i think you have some G1 moves in your homing files for that. Please post your homing files here.
                    Also, have you done that yet? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_of_the_Z_probe
                    konte1978undefined 1 Reply Last reply Reply Quote 1
                      konte1978 @aidar
                      @aidar negative if I write the command M401 P7 the probe does not move.
                      • aidarundefined
                        aidar
                        Dont use P parameter with M401. It is probe index, you have only one probe, so you dont have to specify probe index. M401 runs macro deployprobe.g and thats it. So as you deployprobe.g already exists with right parameters, M401 will just deploy your probe if all is connected correctly.
                          konte1978
                          I'm desperate it still doesn't work, you could modify the file to insert for me.
                          • aidarundefined
                            aidar
                            Just check that all is in that order https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                            Also be sure you dont have any M307 H7 command in config.override.g file.
                              konte1978
                              I managed to make it work, this is my configuration ,I hope it helps someone.
                              config.g
                              M950 S0 C"duex.pwm5" ; creare il servo pin 0 per BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
                              G31 P25 X82 Y-50.5 Z2.6 ; impostare il valore del trigger della sonda Z, l'offset e l'altezza del trigger
                              M557 X0: 209 Y80: 298 S20 ; definire la griglia mesh
                              deployprobe.g
                              etractprobe.g
                              homeall.g
                              G91 ; posizione relativa
                              G1 Z10 F6000 S2 ; Alzo di 10 mm
                              G90 ; Posizione assoluta
                              G1 X141.5 Y110 F6000 ; Posiziono la sonda al centro del piatto
                              G30 ; Sondo il piatto con il BLTouch
                              • JoergS5undefined
                                JoergS5 @konte1978
                                @konte1978
                                the M307 H7 A-1 C-1 D-1 is not used any more in RRF3. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parameters in section "Notes - RepRapFirmware 3".
