    how to deal with old filament
    3D Printing General Chat
    10
    29
    2.6k
    • oliofundefined
      oliof
      I think the parts on the Ormerod v1 I procured are printed in PLA (@droftarts will be able to correct me) and they are without an exception suffering from tension creep from the bolts used or outright cracked (probably because the original owner treated them pretty roughly). The original roll of PLA was included and also just disintegrated into tiny scraps after I dried it in an eBox overnight when being fed through the extruder. So, sadly, I had to discard it because printing with it was impossible for me.
        deckingman @mrehorstdmd
        @mrehorstdmd Ahh OK centuries maybe instead of decades 🙂 That's another urban myth about PLA being busted then.
        • arhiundefined
          arhi @deckingman
          @deckingman said in how to deal with old filament:
          @arhi I read somewhere that light - especially UV light plays a role in making filament brittle. With PLA, more so than moisture. I believe someone once sent me a link to some testing that somebody once did which adds a lot of weight to that theory, but I am unable to find that link.
          Heard the same thing. But for example, the filament in question (what I'm dealing with right now) was in a vacuum foil, inside a cardboard box inside a closed wooden closet, so there is no way UV could access the filament (or any other light) for the 5 years it was "shelved"
          Anecdotally, since I moved my printer from my spare bedroom which has windows, to my (insulated) garage which has no windows, I can leave filment on the machine for weeks or even months and it does not become brittle. Whereas, when the machine was in the bedroom, I would have to pull a few metres of filament off the reels and re-load the hot end because it had become brittle to the extent that it would snap away from the hot end and be no longer connected.
          interesting!
          • arhiundefined
            arhi @mrehorstdmd
            @mrehorstdmd said in how to deal with old filament:
            The prints are another matter. No one is going to store them "properly" and they will/do get brittle. I don't know if it's because of moisture absorption or evaporation of some of the chemicals in the plastic. PLA is all but useless for anything except starwars toys and other stuff that will end up in the trash within a few hours of printing.
            I have PLA parts I printed 10 years ago that are still in function!!! and are performing like they did on day one
            I've never seen problems of any kind with TPU. I have the remnant of a spool that I bought about 5 years ago and use it to print small stuff once in a while, and it still prints like new.
            tpu soaks water and can also become crumbly after 3-4 years, seen it few times
            I've seen ABS get brittle, but usually just a few cm on the free end of the spool. ABS adsorbs moisture, which means it sticks to the surface, but doesn't absorb it. I've never seen an ABS print with a bad surface caused by moisture problems, even if the filament wasn't stored properly. I normally store filament in dry boxes with CaCl2 desiccant, but occasionally leave a spool of ABS on my printer for weeks at a time with no problems.
            I'v seen ABS / PETG / HIPS get brittle and/or print bad but you dry it out overnight in a dryer and they behaves like new ... PLA that gone bad does not work ok after drying
            • arhiundefined
              arhi @deckingman
              I thought PLA was supposed to "bio-degrade" but there is no sign of that happening ye
              requires 60C + and acidic envirnonment iirc .. so it's "possible" to "biodegrade" PLA but it will not happen in regular compost
              • mrehorstdmdundefined
                mrehorstdmd @oliof
                @oliof I've seen forum posts from people who left their printers in parked cars for a few hours and came back to discover the PLA parts melted, essentially destroying the printer. If you want to keep something around for a long time, don't take a chance on printing it with PLA. How may objects can you guarantee won't be left in a hot car at some point in their lifetime?
                A Former User? arhiundefined oliofundefined 3 Replies Last reply Reply Quote 0
                  A Former User @mrehorstdmd
                  @mrehorstdmd that might not be a problem for everyone (welcome to the (other) frozen shi***le of hoth, to qoute ave) but I get what you're saying
                  • arhiundefined
                    arhi @mrehorstdmd
                    PLA has a bad vibe about temperature but really it's not that worse than other plastic we use. If we talk hot beverages PETG/ABS/HIPS deform too at 90C. IIRC mithbusters shown well over 100C in a car during summer, so again PETG/ABS/HIPS will not do much better. I have PETG from Dasfilament (and I heard from others on this forum with other brands of PETG too) that prints ok at 190C so again not much better than PLA. There's a lot of talk about how PLA is crap and I fell into that trap myself and did not use PLA for many years but in reality, for many purposes PLA is IDEAL material to print with.
                      mrehorstdmd @arhi
                      @arhi I don't know about mythbusters, but I lived in Phoenix for a few years and the plastic parts of my car, primarily ABS (maybe a different formulation than we print with), never melted, and neither did the bracket for holding my GPS unit or the GPS unit's housing. OK, no boiling water in printed plastic cups, that's easily avoided, since prints are usually not watertight anyway. I'd worry more about boiling water leaking on my hands and burning me more than I'd worry about the cup melting. I have put ABS prints in my dishwasher for a few cycles and they came out unscathed.
                      I'm not sure how well PETG holds up in a hot car. Maybe not much different than PLA. I'll go put a print out in my car now and see how it goes.
                      • arhiundefined
                        arhi @mrehorstdmd
                        @mrehorstdmd I lived in LA for a year, ABS holder for a nokia phone (not printed but injection m.) was bent beyond recognition. HDPE cup colder too (not the factory one). Here in Belgrade we have 43-45C days during summer, never measured temperature inside the car but have PLA parts that survived years (I did not expect them to), I often mention my PLA holder for external thermometer sitting outside for 7th year now, direct sunlight, easily over 60C during summer, easily -20 during winter (not every winter, not every day but) and is still going strong like day1, it is not colored any more, color is gone, but the part itself changed less than the plastic casing of the wireless sensor itself. You need 180+ for PLA to really make a mess, it will lose strength and bend at high temps but so will most other thermoplastics, that's why most of the stuff in your car is made from PC or better; pet, abs, hips... not that much
                        Anyhow PLA is not that "pure" material, there is PLA and there is PLA so...
                        What's much more important than temperature resistance of thermoplasts is this difference in aging of filament vs printed parts. It's different - A LOT different and I don't see a reason why
                        • oliofundefined
                          oliof @mrehorstdmd
                          @mrehorstdmd I am not printing printer parts in PLA -- sorry if I was being unclear. I am reasonably fine with PETG parts, but I'm gravitating towards ASA more and more.
                          • TypQxQundefined
                            TypQxQ
                            I also have problems with the PLA becoming brittle inside a PTFE tube. It's different between different brands. EasyPrint from 3D Prima is worst I have, It's enough for it to be left half a day inside PTFE and it's broken in several places.
                            Generally all materials get brittle when they absorb moisture and I dry even my PLA for better end results.
                            • arhiundefined
                              arhi
                              problems again, opened 7+ year old box of ABS ... behaves like crap .. does not crumble like PLA but it's rather unprintable ... 24h in dehumidifier at 70C, did not help, still unprintable.... I don't get it, was never exposed to UV, in original vacuum bag with desicant, no water... also does not print like wet filament it just behaves weird - poor layer adhesion, mega warping, curling out of the nozzle...
                              • DaBitundefined
                                DaBit
                                At the start of the covid-19 pandemic I used several old rolls of eSun ABS that were never stored properly to print faceshields. I did dry them before using as insurance policy, and had no single issue with them. Printed like new.
                                The advantage of ABS was that I was able to heat all the faceshields I printed to 80C, making sure that no virus was alive on the shipped parts.
                                • arhiundefined
                                  arhi @DaBit
                                  @DaBit this was also eSUN and also ABS ... only around 8 years old I think and it was in the pile with PC and PA so that's why it was unnoticed for a while
                                  • DigiDundefined
                                    DigiD
                                    This looks similar to a problem experienced in the UV ink print industry when printing older new media vs fresh new media ( both never used and in sealed bags) plastizers in the older media migrate to the print surface causing unexpected print results .
                                    Turns out PLA uses all kinds of plastizers as well and they also can change wildly over time depending on what plastizer is actually used , which may explain what your experiencing
                                    I went down a rabbit hole of info , this one was an interesting read
                                    Printability, Mechanical and Thermal Properties of Poly(3-Hydroxybutyrate)-Poly(Lactic Acid)-Plasticizer Blends for Three-Dimensional (3D) Printing
                                    mendenmhundefined 1 Reply Last reply Reply Quote 1
                                    • mendenmhundefined
                                      mendenmh @DigiD
                                      @DigiD said in how to deal with old filament:
                                      The article you point to seems to indicate the plasticizers were needed in the PHB/PLA mixes, which are extra-biodegradable mixes. In those mixes, they behaved badly without plasticizers. I didn't see anything in there saying pure PLA has plasticizers. As far as I know it doesn't. Anyone an expert on this?
                                      On the other had, I have had a few spools of PLA go completely brittle. It's been more a problem with 3mm diameter filament, which is already very stiff, and I think a bit of differential embrittlement of the outer shell makes it useless.
                                        Phaedrux Moderator @mendenmh
                                        @mendenmh I would bet the PLA+ blends have more plasticizer.
                                        • arhiundefined
                                          arhi
                                          I have some 11 year old natural PLA from bitsfrombytes, 3mm dia, that you can't unspool 😄 .. it does not crack as easy as some modern old PLA but is hardened so much you can't uncoil and straighten it .. I did manage to print with it using a heat gun to heat it up while unspooling but is a manual process acceptable for test only, not for actual printing; it's only total of maybe 500g so not really a big deal (when I remember how much I paid for it it hurts) ... but this last issue was with ABS. Not sure why this happens. I seen few times in videos of ppl like Tomas or Joel that they mention "these are old spools of filament that is unprintable" so they too have the issue of - after some time on the shell filament is unusable, but why ?!
                                          Also, what's weird, as I already mentioned, I have pieces printed out of PLA that are 10 years old and still are totally ok, never became brittle?! Why does filament becomes extra brittle and week while printed part does not ?!
