    Duet 3 with SBC and 5V fan
    620
    • Carloundefined
      Carlo @MartinNYHC
      @MartinNYHC
      Fan Shim ? under the cable
      MartinNYHCundefined 1 Reply Last reply Reply Quote 0
      • MartinNYHCundefined
        MartinNYHC @Carlo
        @Carlo said in Duet 3 with SBC and 5V fan:
        @MartinNYHC
        In general yes, but then my RPI case doesn't fit anymore because the height of the ribbon connector increases. My printer is currently running 24x7 and I just want to avoid printing the case again. Need to finish all the other printer parts.
          A Former User
          it also means no heat sinks so increased cooling need when idle?
          Carloundefined 1 Reply Last reply Reply Quote 0
          • Carloundefined
            Carlo @A Former User
            @bearer
            I don't run mine with heat sinks had no issues with temps?
            Only covers the cpu so heat sinks can be placed on the other chips
            • madmattcoundefined
              madmattco
              You can always do what I did.
                A Former User @madmattco
                @madmattco said in Duet 3 with SBC and 5V fan:
                product link would be handy for the uninitiated?
                madmattcoundefined 1 Reply Last reply Reply Quote 0
                  madmattco @A Former User
                  @bearer
                  https://www.amazon.com/gp/product/B07R45W1LN this is the top board
                  https://www.amazon.com/gp/product/B07MCW4KCM this is the right angle pin adapter
                  And if you're interested, this is the nvme adapter im using
                  https://www.amazon.com/gp/product/B085HG7ZLJ
                    this one might be interesting for quite a few people here! 👍
                    (was tempted to get one in order to de-jankify the PoE / Duet mix, but realized it won't fly without extending the 4 PoE pins as well. will have a think, or ask jlcpcb to send something similar:))
                      madmattco
                      I am using one of these to power it all.
                      https://www.amazon.com/gp/product/B07ZQB6S3L
                      5v feed to the duet3 is also disabled
                      • baird1faundefined
                        baird1fa
                        For what it’s worth the DOSTAR LED connection works to give 5V as someone else already mentioned. I use that to power a pi touch screen.
