    To rigidify or not to rigidify? - vibration issues
    My Duet controlled machine
    15
    70
    5.5k
    • Nxt-1undefined
      Nxt-1 @engikeneer
      @engikeneer said in To rigidify or not to rigidify? - vibration issues:
      @Nxt-1 Not sure how much help it is to you, but I had a go at calculating the first mode of vibration for your towers. Assuming they are individual simply supported beams (ie only looking at one tower, held at both ends) 1.5m long, and the same cross section as the ones I found on google. That gives you a first mode in bending of 1600Hz. Given how yours are mounted at either end, I'd say yours would have a shorter effective length (so a slightly higher natural frequency).
      Still, it's within the same ballpark which I thought was interesting.
      Not to downplay your calculations, especially with limited information available, but 1600Hz is quite a bit from the measured 800Hz no?
      I'm guessing that because your belts also run the length of the towers, the excitation from the motors can also travel down those so excite it from both ends?
      I have have wondered about this as well. The belt certainly do vibrate, so I figure they are a source noise themselves. However I doubt they can really carry the vibrations from the top pulley shaft to the bottom pulley shaft. I would think that they are far from rigid enough do do that?
      Have you tried just bolting a length of metal to the outer side of the extrusions? (so they effectively become 60-150 at one point). You could even do this with the rubber sandwiching to get extra damping?
      Adding mass tends to drop natural frequencies (as well as dampen them because exytra joints), but you might find you just shift it to a lower frequency that you still excite. You might be better adding stiffness to increase the frequency to a less audible range.
      With "so they effectively become 60-150 at one point", do you mean bolting a slab of 30x150x1500mm of steel to the side? Because those would weigh 50-60kg a piece. And I am already struggling with the weight of the concrete slabs at it is 🙂 . Furthermore 30mm of thickness will not add significant stiffness to the frame, I would be better of bolting a piece of square hollow structural steel tubing to the towers. They could be much larger and thus much stiffer for the same total weight.
      This leads us to the start of this thread though, will increasing stiffness cause the vibrations to lessen? The consensus seems to be I wont really. Now the weight of all that steel would still be as effective as the concrete would be, with the caveat that steel is not as effective at damping vibrations as concrete. So it might become more of a resonator itself.
      Either way, the blue concrete is ingenious and looks brilliant so fingers crossed it works for you! 🙂
      Thanks, I use all the finger crossing I can get 🙂
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • engikeneerundefined
        engikeneer
        @Nxt-1 I was meaning bolting another aluminium extrusion, either a full 30150 or even just a single 3030 to keep it nice and light. More thinking it might be a lighter weight solution!
        One other thing to consider is to do all of the towers slightly differently. That way you'll get some separation of the resonant frequencies so the towers don't interact and further excite each other. I'm guessing you'll get this a bit for free with the concrete though
        i3 clone with a bunch of mods
        • JoergS5undefined
          JoergS5
          I know from CNC machines that mixing materials is a good idea. They mix steel with aluminium, so the eigenfrequencies are different. One has to think of the different material expansion with different temperatures however (even between the different aluminium alloys), otherwise you bent your aluminium extrusions!
          • Nxt-1undefined
            Nxt-1
            We have arrived at the moment of truth.
            Friday I assembled the molds with, as you can see, the white pieces in there to make bolt holes and a piece of rebar in the center. Saturday I mixed up another 3 bags of concrete mix and did the pour. Then finally on Tuesday, I demolded the slabs and attached them to the printer. Before I go over the results, I'll share some more of my experiences and remarks.
            Removing the wood mold pieces went very very easy just like last time. The white inserts for molding the bolt holes were not. From the 40 spread over the two slabs, just four came out with gentle percussive action. I did have a 1,5° taper angle on the pieces, but I ended up needing to use a drill to get rid of most of the plastic. The last cleanup was done using a hot air station at 200°C. The holes are not perfectly smooth around the edges, but no major issues.
            Last time I noticed that the sides touching the mold wood were quite dusty and remained quite dusty no matter what I did. I did a quick google and assumed bad mixing was to blame for that. On the two new slabs I notice the same however, yet that could be due to me using the same mixing ratios. But actually I now believe it is due to the wood absorbing moisture from the concrete while it is still wet, thus effectively causing localized bad mixing. I figured this as I poured the excess concrete in a plastic bucket and after drying is was completely dust free. The wood absorbing moisture also explains why the top surface did not show the same issue.
            I decided to add a piece of rebar in the center to give some added strength as the piece is quite thin compared to its length and did not want it cracking in half while working with it. The picture below shows how I suspended the rebar with some metal wire between the printed pieces. After demolding I noticed something interesting. In both slabs I can feel something moving quite distinctly when I jiggle a little with the slab upright. It really feels like the rebars are loosey goosey in there 🙂 Don't ask my why, and I guess at this point it doesn't really matter that much either.
            While playing with the first slab, I became clear that it did not sit perfectly straight against the tower. I got a piece of ~3mm rubber matting from a local home improvement store that sold it by the meter. I cut six pieces sized and holed correctly for the slab so I could double up on the thickness if needed. In the end I did end up just using one piece per tower, but oh well.
            Now it is finally time for the moment of truth, attaching the slabs to the towers. At a little of 30kg a piece it was not trivial but I managed to get them one there. Some bolt holes are left open as one or two holes are badly located and do not line up well enough, or the t-nut fell down while playing with the bolt and I did not feel like removing the slab to put a t-nut back 🙂 . Once I attached the first slab and even the second I did some test moves and was not really impressed with what I heard. But the third was the charm I guess, definitely an improvement. I can no longer feel any vibrations with my hands on the towers.
            I must nuance the results a bit sadly. While the difference is certainly there and is quite noticeable, it's not perfect and not really acceptable even. I went from being able to hear the printer form all areas of the house to only audible in the next room. To combat the last noise I have some proper nema 23 dampers on order and I am most likely going to construct some sort of enclosure for the entire printer, that I line with sound dampening material.
            Congrats to the people that made it this far down the wall of text, enjoy the pictures and drop an upvote if you think these longer post as worth the time 🙂 Many thanks to all that pitched in with ideas and suggestions.
            Just for the curious among us, this ended up costing my about €165, of which almost half went to the M8 t-nuts and the blue pigment.
            JoergS5undefined TLASundefined A Former User? theruttmeisterundefined 4 Replies Last reply Reply Quote 6
            • JoergS5undefined
              JoergS5 @Nxt-1
              @Nxt-1 thank you for the interesting report. You wrote that you still hear something. Is it still 800 Hz or did the frequency change?
              Nxt-1undefined 1 Reply Last reply Reply Quote 0
              • TLASundefined
                TLAS @Nxt-1
                @Nxt-1
                Think I replied before with an evaluation of what you should do to improve stiffness. I think it still applies. You need to focus on your joints and the thickness of your plates the columns are mounted to. Stiffness is much better to improve over mass to eliminate frequency issues.
                Focus on joint preload, moment of area, and do the hand calcs for Beam stiffness yourself. You’ll learn a lot by evaluating it so you can make the correct upgrades.
                  A Former User @Nxt-1
                  @Nxt-1 said in To rigidify or not to rigidify? - vibration issues:
                  I thought we weren't gonna talk about it again:P Anyways I think I would have opted for something hollow to be left in place, maybe - i definitively will now.
                  Anyawys, thanks for sharing the ups and downs in great length, much appreciated.
                  • Nxt-1undefined
                    Nxt-1 @JoergS5
                    @JoergS5 said in To rigidify or not to rigidify? - vibration issues:
                    I just did a measurement again at bang on, the same 833Hz, albeit about half as intense. Though I did not control the distance from the frame to the mic, so take the reported intensity for what it's worth.
                    @TLAS said in To rigidify or not to rigidify? - vibration issues:
                    @Nxt-1
                    I don't seem to be able to find you posting in this thread before. That aside I doubt I can make the printer as silent as I want/need with increasing stiffness. Unless I completely rebuild the machine from scratch and maybe make it out of epoxy granite entirely. But more of a rebuild then what I did in the V2 upgrade (what started this whole thread as well) is really not on the agenda sadly.
                      A Former User
                      Instead of (or in adittion to) the massive rebar, did you consider using fiberglass, as in chopped strands something like https://www.amazon.com/32-500-4-Inch-Anti-Crak-Concrete-Fibers/dp/B000CODWAE ?
                      • Nxt-1undefined
                        Nxt-1 @A Former User
                        @bearer said in To rigidify or not to rigidify? - vibration issues:
                        I did not, GFRC might very well have been a better option compared to the rebar yeah. Especially knowing how the rebar worked out.
                        • theruttmeisterundefined
                          theruttmeister @Nxt-1
                          I think that's a fairly dramatic improvement, although what measure of intensity are you using? Do you mean its down 3dB?... I'm a bit shocked it was as loud as you describe though.
                          Can you feel much vibration in the aluminium plates across the top? That's what I would try next...
                          Isolate, substitute, verify.
                          • Nxt-1undefined
                            Nxt-1 @theruttmeister
                            @theruttmeister said in To rigidify or not to rigidify? - vibration issues:
                            I was quite loud when doing fast all axis moved yes 🙂 . Yes I do mean it's down 3dB, actually the 833Hz frequency bin is down 3dB if you look at the frequency spectrum. So it's not entirely fair the say all of it is down 3dB, yet the resonant tone was so dominant that most of the energy in there. Though again I did not perform accurate measurements, with controlled distance and orientation of the mic so don't give to much attention to these values.
                            Yeah, there is some vibration in the plate that hold the bed at the bottom and the one that holds the motors at the top. I am thinking of drilling and tapping some M12 bolt holes so I can attach the top top plate to the plate that hold the motors in the center. This should make it stiffer and is not expensive, nor that much work.
                            • QuintBrandundefined
                              QuintBrand
                              Interesting experiment; your name and having written some dutch words makes me think you work in Veldhoven ;-). I visit there regularly.
                              Anyways, just to add some remarks:
                              • I'm not sure you can "feel" 833Hz with your hands. That's typically lower frequent. I would imagine the concrete drastically changed the vibration part right?
                              • changing the system "that much" with the frequency remaining about the same is quite strange. It makes me believe it's something else then the frame
                              • with the probkem being audible, I indeed think that acoustic measures (enclosure('s)) will now help you a lot!
                              You could also perhaps look at Tune Mass Damper principle. Make one as and test it at different places ;-).
                              But overall, really nice job man! Cool and it sure was worth reading to the end ;-).
                              Nxt-1undefined 1 Reply Last reply Reply Quote 1
                              • Nxt-1undefined
                                Nxt-1 @QuintBrand
                                @QuintBrand said in To rigidify or not to rigidify? - vibration issues:
                                Veldhoven is not to far from me, but I am not from the Nederlands, furthermore, I don't think I have ever been there 🙂
                                On topic, to be honest I have no idea, but I would not be surprised if you were right that 833Hz to to high a frequency to feel. Maybe I felt a lower harmonic of that, not sure. To explain what is happening in reality, there are a number of guesses I can make, but not none can really verify, not does why really matter that much to me anymore 🙂
                                Yeah I really hope the acoustic enclosure I am planning to build will be the final chapter of this story.
                                I have started a new thread specifically to discuss the enclosure plans here: https://forum.duet3d.com/topic/17725/building-a-sound-dampening-enclosure
                                • Nxt-1undefined
                                  Nxt-1
                                  A couple of weeks ago now, I received an installed the proper nema 23 decoupling motor mounts. While the motor is certainly decoupled nicely, the end can jiggle around if you push it. Sadly not really a noticeable noise reduction.
                                  At this point I really think the majority of the vibrations must be coupled via the pulley shaft and bearings, trough the 3D printed mount and into the frame.
                                  I am thinking this will be more or less the end of this thread, as my focus has changed from tackling the source to mitigating the results. You can follow the progress of the enclosure here.
                                  • zemlinundefined
                                    zemlin
                                    Going to throw out one more idea - I didn't read all the prior posts as the discussion was all over the place.
                                    If the vertical frame members are resonating, it might be a pretty simple matter to kill the resonance by making them asymmetrical.
                                    What if you were to take three 1 lb (or whatever) pieces of steel and some tee nuts - secure the steel weights to the legs at different heights. That will change the resonant frequencies, and if they are at different heights on each leg, that will kill the symmetry of the vibrations.
                                    Can't promise that it will work out, but it seems like it might be worth trying.
                                    • Nxt-1undefined
                                      Nxt-1 @zemlin
                                      @zemlin Yeah the thread has gotten lengthy and some parts are not exactly a fun read. However, have a look at post 54. There you can see that I casted concrete slabs and bolted them to the towers, effectively eliminating the vibration in just the towers.
                                      • BigMoff96undefined
                                        BigMoff96 @dgrat
                                        @dgrat what delta printers kit is that? I’m looking to trash my Rostock because the frame is crappy and that looks to be right up my alley
                                        Nxt-1undefined MikeSundefined 2 Replies Last reply Reply Quote 0
                                        • Nxt-1undefined
                                          Nxt-1 @BigMoff96
                                          @BigMoff96 said in To rigidify or not to rigidify? - vibration issues:
                                          I don't know how else to put it but this beast is unique. The design and fabrication is all done by me (and still progressing).
                                          • MikeSundefined
                                            MikeS @BigMoff96
                                            @BigMoff96 i feel you bro. Also swtiched from a rostock delta too. If you accept suggestion leave deltas and buy/make something more stable. Delta is very nice to look at, but i switched to a corexy (voron 2) and i would never come back. Now i started printing, with deltas i've only played 😃 just my 2 cents
