    Short to ground on drivers 0123
    63
    2.7k
      A Former User @percyb
      @percyb said in Short to ground on drivers 0123:
      I have a similar issue, getting "Warning: motor phase A may be disconnected reported by driver(s)"
      ref https://forum.duet3d.com/post/100507 and you should probably start your own topic if the error persist after disconnecting your motors (when powered down ofc)
      Touchthebitumundefined 1 Reply Last reply Reply Quote 0
      • Touchthebitumundefined
        Touchthebitum @A Former User
        @bearer said in Short to ground on drivers 0123:
        I think we should think about a warranty process. I don't know what to add to the discussion. I repeat, it is not the first printer I build and I'm aware of risks. Before this Duet3 I used a Duet2 and was perfect (no errors messages) with the same motors. This board never worked and I directly plugged the SAME motors that I plugged to my Duet2. So there is a problem.
        My shop told me to see with this forum, what I did.
        Now, I choosed a Genuine board because I believe in the right intelectual properties and know-how.
        Please, give me a clear answer and we can go on.
        Thanks
        A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          A Former User @Touchthebitum
          @Touchthebitum said in Short to ground on drivers 0123:
          that was not directed at you; I'm sure dc42 is trying to evaluate the information you've provided already
            Thanks 😉
              T3P3Tony administrators @Touchthebitum
              @Touchthebitum
              Thanks for your patience, DC42 is away right now but I can help.
              Looking at your latest M122 report it looks like driver 01 and 1 are damaged. its not completely clear if 2 and 3 are damaged - the motors connected to those ones could have an issue.
              Can you try the following please
              1. check the wiring of one of your stepper with a voltmeter. they should be wired in two pairs, 1-2 and 3-4 (i.e. pin 1 to 2 should read a few Ohms, pin 3 to 4 should read a few ohms but there should be no connection between pin the pairs).
              2. with just that motor you have check tried it plugged into Driver 2, command a movement, send M122 and see what it says, we are looking at this part:
              Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
              Driver 0: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/0
              Driver 1: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/63
              Driver 2: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
              Driver 5: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
              1. Repeat for driver 3 and driver 4.
              Lets see those three excerpts from M122.
                Touchthebitum @T3P3Tony
                @T3P3Tony
                Hello
                I tested pairs and got 2ohms on each pair and nothing between the two pairs
                For the moves of drivers 3-4 I made z move on the duet panel Due
                For the driver 4 , I don't have yet a connected extruder
                Error: short-to-ground reported by driver(s) 2
                28/07/2020 à 12:31:08 m122
                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                Board ID: 08DJM-956L2-G43S8-6J9F4-3S46N-TU2QD
                Used output buffers: 1 of 40 (10 max)
                Static ram: 154604
                Dynamic ram: 162592 of which 44 recycled
                Exception stack ram used: 376
                Never used ram: 75600
                Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,196) MAIN(running,4952) IDLE(ready,76)
                Owned mutexes:
                Last reset 00:01:08 ago, cause: power up
                Last software reset at 2020-07-27 15:14, reason: User, spinning module LinuxInterface, available RAM 75704 bytes (slot 0)
                Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                Error status: 0
                MCU temperature: min 20.6, current 29.8, max 29.9
                Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                Driver 0: standstill, reads 8684, writes 14 timeouts 0, SG min/max 0/0
                Driver 1: standstill, reads 8684, writes 14 timeouts 0, SG min/max 0/0
                Driver 2: short-to-ground standstill, reads 8681, writes 17 timeouts 0, SG min/max 0/8
                Driver 3: standstill, reads 8685, writes 14 timeouts 0, SG min/max 0/0
                Driver 4: standstill, reads 8688, writes 11 timeouts 0, SG min/max 0/0
                Driver 5: standstill, reads 8689, writes 11 timeouts 0, SG min/max 0/0
                28/07/2020 à 12:33:42 M122
                Used output buffers: 1 of 40 (13 max)
                Static ram: 154604
                Exception stack ram used: 360
                Never used ram: 75616
                Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(blocked,68) MAIN(running,4536) IDLE(ready,76)
                Owned mutexes:
                Last reset 00:01:04 ago, cause: power up
                Error status: 0
                MCU temperature: min 32.1, current 32.5, max 32.6
                Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, reads 56891, writes 0 timeouts 0, SG min/max not available
                Driver 1: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
                Driver 2: short-to-ground standstill, reads 56888, writes 2 timeouts 0, SG min/max not available
                Driver 3: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
                Driver 4: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
                Driver 5: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
                Date/time: 2020-07-28 11:33:45
                Slowest loop: 3.63ms; fastest: 0.21ms
                Driver number 4 : there is no extruder tool message
                  Hi @Touchthebitum
                  you will need to update your configuration temporarily to use the test motor on driver 3, and then again on driver 4 - use the M584 command in config.g:
                  (To test driver 3) :
                  M584 X0.0 Y0.1 Z0.3 E0.2 ; Temporary drive mapping to test driver 3 as Z
                  (To test driver 4) :
                  M584 X0.0 Y0.1 Z0.4 E0.2 ; Temporary drive mapping to test driver 4 as Z
                  Touchthebitumundefined 2 Replies Last reply Reply Quote 0
                    This post is deleted!
                      @T3P3Tony said in Short to ground on drivers 0123:
                      Driver 3
                      m122
                      Static ram: 154604
                      Exception stack ram used: 368
                      Never used ram: 75608
                      Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                      Owned mutexes:
                      Last reset 00:00:31 ago, cause: software
                      Last software reset at 2020-07-28 13:51, reason: User, spinning module LinuxInterface, available RAM 75720 bytes (slot 3)
                      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                      Error status: 0
                      MCU temperature: min 33.6, current 34.2, max 34.4
                      Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
                      Driver 1: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
                      Driver 2: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
                      Driver 3: short-to-ground standstill, reads 26011, writes 17 timeouts 0, SG min/max 0/8
                      Driver 4: standstill, reads 26017, writes 11 timeouts 0, SG min/max 0/0
                      Driver 5: standstill, reads 26018, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2020-07-28 13:52:03
                      Slowest loop: 4.13ms; fastest: 0.14ms
                      Driver 4 MOTOR IS MOVING DURING TEST
                      Error: short-to-ground reported by driver(s) 4
                      28/07/2020 à 14:54:51 m122
                      Static ram: 154604
                      Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                      Owned mutexes:
                      Last reset 00:00:50 ago, cause: power up
                      Last software reset at 2020-07-28 13:53, reason: User, spinning module LinuxInterface, available RAM 75608 bytes (slot 0)
                      Error status: 0
                      MCU temperature: min 28.3, current 34.6, max 34.7
                      Driver 0: standstill, reads 53146, writes 14 timeouts 0, SG min/max 0/0
                      Driver 1: standstill, reads 53146, writes 14 timeouts 0, SG min/max 0/0
                      Driver 2: standstill, reads 53147, writes 14 timeouts 0, SG min/max 0/0
                      Driver 3: standstill, reads 53150, writes 11 timeouts 0, SG min/max 0/0
                      Driver 4: short-to-ground standstill, reads 53145, writes 17 timeouts 0, SG min/max 0/160
                      Driver 5: standstill, reads 53151, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2020-07-28 13:54:55
                      Slowest loop: 4.15ms; fastest: 0.13ms
                      It is the first time I see a motor moving on this board
                        OK so it looks like drivers 0-3 are damaged, possibly by the moving pins around earlier but hard to say.
                        That said there is another issue that is causing a working motor to report short to ground (on driver 4). It may be that the damage to the other drivers is effecting them all. DC42 will have a better idea.
                        Because of that I will authorise a warranty return. please use reference this thread in the warranty form that your reseller (3dware.ch) will ask you to complete for us and be sure to fill out the serial number so we can match this board to this thread.
                        When you get your new board please triple check the wiring before powering everything up. I was a little concerned to see the tape holding the crimps on - intermittent disconnection of 1 wire of the 4 driver wires can damage the drivers.
                          @T3P3Tony
                          Ok, thanks for your time and support.
                          I'll 10x check ;), I want to print 😉
                            Touchthebitum
                            Hello
                            I got the second Duet 3 and I'm getting mad with this board.
                            I checked 10 times the phases/continuity on every motor.
                            Before testing movements I made M122 (usb mode) and everything is ok. All drivers are ok.
                            I test y movement with my Panel Due movement button and I get "Error: short-to-ground reported by driver(s) 0 1"
                            After that I made M122 and I get this :
                            m122
                            Board ID: 08DJM-956L2-G43S8-6JKD6-3SJ6L-KA02G
                            Static ram: 154604
                            Exception stack ram used: 200
                            Never used ram: 75776
                            Tasks: NETWORK(ready,1968) HEAT(blocked,1232) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(suspended,252) MAIN(running,5132) IDLE(ready,76)
                            Owned mutexes:
                            Last reset 00:00:49 ago, cause: power up
                            Last software reset at 2020-08-02 08:21, reason: User, spinning module LinuxInterface, available RAM 75776 bytes (slot 1)
                            Error status: 0
                            MCU temperature: min 20.6, current 28.3, max 28.4
                            Supply voltage: min 0.2, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
                            12V rail voltage: min 0.1, current 0.2, max 0.3, under voltage events: 0
                            Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                            Date/time: 2020-08-02 10:44:14
                            Slowest loop: 2.64ms; fastest: 0.14ms
                            === Storage ===
                            Free file entries: 10
                            === MainDDARing ===
                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                            === AuxDDARing ===
                            Segments left: 0
                            Movement lock held by null
                            HTTP* is ready with "M122" in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            SBC is idle in state(s) 0
                            Daemon* is idle in state(s) 0
                            Aux2 is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 0.27ms; fastest: 0.01ms
                            HTTP sessions: 0 of 8
                            • Ethernet -
                              State: disabled
                              Error counts: 0 0 0 0 0
                              === CAN ===
                              Messages sent 104, longest wait 0ms for type 0
                              === Linux interface ===
                              State: 0, failed transfers: 0
                              Last transfer: 12ms ago
                              RX/TX seq numbers: 843/844
                              SPI underruns 0, overruns 0
                              Number of disconnects: 0
                              Buffer RX/TX: 0/0-0
                              === Duet Control Server ===
                              Duet Control Server v3.1.1
                              Code buffer space: 4096
                              Full transfers per second: 11.04
                            Please I don't want to blow something.
                            What am I missing ?
                            I'm starting to regret my WORKING Duet2 Wifi.
                            I'm using the SBC mode with a Raspberry 4 8GB
                            Here is my config file built with the online configurator:
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 12:20:30 GMT+0200 (heure d’été d’Europe centrale)
                            M550 P"Duet 3" ; set printer name
                            M669 K1 ; select CoreXY mode
                            M569 P0 S1 ; physical drive 0.0 goes forwards
                            M569 P1 S1 ; physical drive 0.1 goes forwards
                            M569 P2 S1 ; physical drive 0.2 goes forwards
                            M569 P3 S1 ; physical drive 0.3 goes forwards
                            M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                            M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                            M84 S30 ; Set idle timeout
                            M208 X230 Y210 Z500 S0 ; set axis maxima
                            M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
                            M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
                            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                            M558 P9 C"^io6.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                            M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                            M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
                            M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                            M308 S1 P"temp0" Y"thermistor" T325000 B4138 ; configure sensor 1 as thermistor on pin temp0
                            M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
                            M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                            M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                            M106 P1 S1 H1 T200 ; set fan 1 value. Thermostatic control is turned on
                            ; Custom settings
                            M564 H0
                            M564 H0
                              droftarts administrators @Touchthebitum
                              No 12/24V power reported? PSU connected and turned on? Note wiring order for power is the other way around from Duet 2. I see all previous M122 did have 24V. Check fuse.
                              Otherwise, can you post a picture of your Duet board and wiring, showing where steppers are connected?
                              Please also post the specs of the motors you are trying to connect.
                              Do you know what speed the PanelDue buttons are requesting axis movement?
                                Touchthebitum @droftarts
                                @droftarts
                                Thanks for your reply.
                                I'm afraid to put current in this board ...
                                I tried one movement , one time and got short message on drivers ...
                                Here is the last M122 with the PSU on :
                                m122
                                Static ram: 154604
                                Exception stack ram used: 272
                                Never used ram: 75704
                                Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,192) MAIN(running,4952) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 00:00:48 ago, cause: power up
                                Error status: 0
                                MCU temperature: min 17.1, current 25.4, max 25.5
                                Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                Driver 0: standstill, reads 41634, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: standstill, reads 41634, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: standstill, reads 41635, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: standstill, reads 41635, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: standstill, reads 41639, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 41639, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-08-02 12:46:46
                                Slowest loop: 3.86ms; fastest: 0.14ms
                                === Storage ===
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 1.39ms; fastest: 0.01ms
                                • Ethernet -
                                  State: disabled
                                  === CAN ===
                                  Messages sent 103, longest wait 0ms for type 0
                                  Last transfer: 17ms ago
                                  RX/TX seq numbers: 841/842
                                  Buffer RX/TX: 0/0-0
                                  Full transfers per second: 0.49
                                Motors are Blurolls 17HM19-2004S and was working on the Duet2 Wifi
                                I don't know the speed for movements on the Paneldue.
                                No motor connected , move X and I got this :
                                02/08/2020 à 15:04:23 m122
                                Static ram: 154604
                                Exception stack ram used: 304
                                Never used ram: 75672
                                Owned mutexes:
                                Last reset 00:00:54 ago, cause: power up
                                Error status: 0
                                MCU temperature: min 17.0, current 25.5, max 25.6
                                Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: short-to-ground standstill, reads 3896, writes 17 timeouts 0, SG min/max 0/8
                                Driver 1: short-to-ground standstill, reads 3896, writes 17 timeouts 0, SG min/max 0/8
                                Driver 2: standstill, reads 3900, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: standstill, reads 3900, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: standstill, reads 3904, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 3904, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-08-02 14:04:21
                                Slowest loop: 4.23ms; fastest: 0.14ms
                                === Storage ===
                                Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 38119ms
                                === MainDDARing ===
                                Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 1.82ms; fastest: 0.01ms
                                • Ethernet -
                                  State: disabled
                                  === CAN ===
                                  Messages sent 127, longest wait 0ms for type 0
                                  Last transfer: 16ms ago
                                  RX/TX seq numbers: 1025/1026
                                  Buffer RX/TX: 0/0-0
                                  Full transfers per second: 0.35
                                  @Touchthebitum can you try setting up the Duet in standalone mode, and test? Disconnect the RPi, create a fresh SD card, copy over your config. My theory: your RPi is causing the issue, possibly something on the SPI bus. No real evidence for this, just that I think it unlikely (though possible) that you’d have two broken boards in a row.
                                    @droftarts
                                    same results ... error on driver 0 and 1
                                    It's a nightmare
                                    I can't post anything since I don't have ethernet connection
                                      to the board in stand alone mode?
                                        @bearer
                                        No, I'm far from a router
                                          @bearer
                                          you can do all the tests over usb serial interface, or a direct (ethernet) connection to your computer with static ip addresses on both duet and computer when duet is in stand alone mode.
                                            @bearer
                                            Ok, what do you need as info or tests ?
