Thermistor daughterboard beginner question.
1.9k
    sd_matt @A Former User
    @bearer Same 2000 degree and "fault" problem regardless of channel/ terminal block in config. Also tried plugging daughterboard into extension board. Removing the daughterboard altogether. I also jumpered the terminal with a straight wire and then resistor. Same result.
      A Former User
      Right, well, please wait while we try to tune our chrystal balls in to whatever combination of wiring and configuration you have settled on to see what wrong.
      Meanwhile, please check the settings in your browser as it appears not to be rendering links properly.
      undefined 2 Replies Last reply 1 Aug 2020, 20:06 Reply Quote 0
        @bearer No crystal ball needed. Ive tried every combo of block and channel as per the documentation. Just in case I wasnt clear
          @bearer Is there a way to test if the daughterboard is even functional or DOA?
          undefined 1 Reply Last reply 1 Aug 2020, 20:25 Reply Quote 0
            dc42 administrators @sd_matt
            @sd_matt said in Thermistor daughterboard beginner question.:
            Can you clarify which daughter board you have? We don't manufacture a "thermistor daughterboard", we manufacture a daughter board for PT100 sensors, and another for thermocouples.
            We supply a 100 ohm resistor with the PT100 daughter boards, to help you confirm that the daughter board and your firmware configuration are correct. With the 100 ohm resistor connected in place of a PT100 sensor, the reading should be very close to 0C.
            For the thermocouple daughter boards, if you connect a wire link in place of the thermocouple, you should get a reading close to ambient temperature.
            undefined 2 Replies Last reply 1 Aug 2020, 20:38 Reply Quote 0
              sd_matt
              @dc42 said in Thermistor daughterboard beginner question.:
              Ah bad terminology from seller I guess. Reading off the board "PT100 RTD Board Revision 1.1a By Duet 3d CERN OHL 1.2"
              The intent is to control exhaust fans for heated enclosure.
                sd_matt @dc42
                @dc42 I got a brief reading close to zero with the resistor in place then back 2000 and fault. . I have the connections jumpered with a wire but same thing. I pulled the board off altogether and same 2000 temp with fault indicated on the duet interface. Im using my laptop so no USB connection
                undefined 1 Reply Last reply 1 Aug 2020, 20:45 Reply Quote 0
                  sd_matt @dc42
                  M305 P3 X201 ;
                  M141 H3 S80
                  Firmware is 2.02(RTOS) (2018-12-24b1)
                    That's completely normal. You will get an error if you configure a sensor to use a PT100 daughter board channel, but the daughter board is not present.
                    undefined 1 Reply Last reply 1 Aug 2020, 22:07 Reply Quote 0
                      sd_matt @dc42
                      @dc42 It does the same thing when the board is present
                        A Former User
                        if we assume you did everything right then the board isn't working.
                        if we're open to the possibility that the board is fine a picture or two and the complete config just might help, then again there is a limit to how many times I'll suggest that
                        undefined 2 Replies Last reply 1 Aug 2020, 22:23 Reply Quote 0
                          @bearer Here's the config.g
                          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 12:54:34 GMT-0700 (Pacific Daylight Time)
                          M550 P"BD3D Hypercube" ; set printer name
                          M667 S1 ; select CoreXY mode
                          M551 P"bdgpyg4c9sqm" ; set password
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S1 ; enable FTP
                          M586 P2 S1 ; enable Telnet
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M569 P2 S0 ; physical drive 2 goes backwards
                          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                          M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                          M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X400 Y470 Z650 S0 ; set axis maxima
                          M574 X1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
                          M574 Y1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
                          M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
                          M574 Z1 S2 ; Use zprobe and home to min
                          M915 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
                          M574 Z1 S2 ; Set endstops controlled by probe
                          M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                          M558 P9 H3 F120 T6000 B1 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
                          G31 P400 X28 Y0 Z1.150 ; Set Z probe trigger value, offset and trigger height
                          M557 X15:355 Y15:355 S80 ; Define mesh grid
                          M305 P3 X201 ;
                          M141 H3 S80
                          M106 P7 S1 I0 F500 H2 T15 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P8 S1 I0 F500 H2 T15 ; set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          undefined 1 Reply Last reply 2 Aug 2020, 17:22 Reply Quote 0
                            davidvh86
                            d the daughterboard and the reading is still the same. I tried putting in a 100ohm resistor in the circuit and then just the resistor in place of the wires. Not sure what is going on. I am just beginning to try to understand the g code.
                            Are you sure ur not talking about the pt100 daughter board, you cant use a thermistor with it.
                            undefined 1 Reply Last reply 1 Aug 2020, 23:42 Reply Quote 0
                              sd_matt @davidvh86
                              @davidvh86
                              Read right off the board
                              undefined 1 Reply Last reply 2 Aug 2020, 16:55 Reply Quote 0
                                @bearer Im not sure if Im correct on the config as someone else walked me through it.
                                  Elvis0z
                                  This post is deleted!
                                    A Former User
                                    now if we only had a picture to show where the board is connected and how the sensor is wired we could correlate it to the config.
                                    but as it seems that is too much to ask I'm afraid we're at the end of what we can assist you with.
                                      davidvh86 @sd_matt
                                      ? 1 Reply Last reply 2 Aug 2020, 16:58 Reply Quote 0
                                        A Former User @davidvh86
                                          davidvh86
                                          @bearer said in Thermistor daughterboard beginner question.:
                                          " ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                          that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
                                          Oh sorry deleted it to avoid confusion lol
                                          undefined 1 Reply Last reply 2 Aug 2020, 19:22 Reply Quote 0
                                          18 out of 43
