Thermistor daughterboard beginner question.
M305 P3 X201 ;
M141 H3 S80Firmware is 2.02(RTOS) (2018-12-24b1)
@sd_matt said in Thermistor daughterboard beginner question.:
I pulled the board off altogether and same 2000 temp with fault indicated on the duet interface.
That's completely normal. You will get an error if you configure a sensor to use a PT100 daughter board channel, but the daughter board is not present.
@dc42 It does the same thing when the board is present
if we assume you did everything right then the board isn't working.
if we're open to the possibility that the board is fine a picture or two and the complete config just might help, then again there is a limit to how many times I'll suggest that
@bearer Here's the config.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 12:54:34 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"BD3D Hypercube" ; set printer name
M667 S1 ; select CoreXY mode; Network
M551 P"bdgpyg4c9sqm" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y470 Z650 S0 ; set axis maxima; Endstops
M574 X1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
M574 Y1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
M574 Z1 S2 ; Use zprobe and home to min
M915 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H3 F120 T6000 B1 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
G31 P400 X28 Y0 Z1.150 ; Set Z probe trigger value, offset and trigger height
M557 X15:355 Y15:355 S80 ; Define mesh grid; Heaters
M305 P3 X201 ;
M141 H3 S80; Fans
M106 P7 S1 I0 F500 H2 T15 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P8 S1 I0 F500 H2 T15 ; set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
d the daughterboard and the reading is still the same. I tried putting in a 100ohm resistor in the circuit and then just the resistor in place of the wires. Not sure what is going on. I am just beginning to try to understand the g code.
Are you sure ur not talking about the pt100 daughter board, you cant use a thermistor with it.
@davidvh86
"PT100 RTD Board Revision 1.1a By Duet 3d CERN OHL 1.2"Read right off the board
@bearer Im not sure if Im correct on the config as someone else walked me through it.
This post is deleted! -
now if we only had a picture to show where the board is connected and how the sensor is wired we could correlate it to the config.
but as it seems that is too much to ask I'm afraid we're at the end of what we can assist you with.
@bearer said in Thermistor daughterboard beginner question.:
" ; configure sensor 1 as thermocouple via CS pin spi.cs1
that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
Oh sorry deleted it to avoid confusion lol
[deleted]
@dc42 What info are you missing. I can re post
@davidvh86 Is there anything you want me to post to clear up any confusion?
Post a photo of the sensor and the board.
@Phaedrux
