    Thermistor daughterboard beginner question.
    1.9k
      dc42 administrators @sd_matt
      @sd_matt said in Thermistor daughterboard beginner question.:
      @bearer Is there a way to test if the daughterboard is even functional or DOA?
      Can you clarify which daughter board you have? We don't manufacture a "thermistor daughterboard", we manufacture a daughter board for PT100 sensors, and another for thermocouples.
      We supply a 100 ohm resistor with the PT100 daughter boards, to help you confirm that the daughter board and your firmware configuration are correct. With the 100 ohm resistor connected in place of a PT100 sensor, the reading should be very close to 0C.
      For the thermocouple daughter boards, if you connect a wire link in place of the thermocouple, you should get a reading close to ambient temperature.
      sd_mattundefined 2 Replies Last reply Reply Quote 0
      • sd_mattundefined
        sd_matt
        @dc42 said in Thermistor daughterboard beginner question.:
        Ah bad terminology from seller I guess. Reading off the board "PT100 RTD Board Revision 1.1a By Duet 3d CERN OHL 1.2"
        The intent is to control exhaust fans for heated enclosure.
        • sd_mattundefined
          sd_matt @dc42
          @dc42 I got a brief reading close to zero with the resistor in place then back 2000 and fault. . I have the connections jumpered with a wire but same thing. I pulled the board off altogether and same 2000 temp with fault indicated on the duet interface. Im using my laptop so no USB connection
          • sd_mattundefined
            sd_matt @dc42
            M305 P3 X201 ;
            M141 H3 S80
            Firmware is 2.02(RTOS) (2018-12-24b1)
              That's completely normal. You will get an error if you configure a sensor to use a PT100 daughter board channel, but the daughter board is not present.
              sd_mattundefined 1 Reply Last reply Reply Quote 0
              • sd_mattundefined
                sd_matt @dc42
                @dc42 It does the same thing when the board is present
                  A Former User
                  if we assume you did everything right then the board isn't working.
                  if we're open to the possibility that the board is fine a picture or two and the complete config just might help, then again there is a limit to how many times I'll suggest that
                  • sd_mattundefined
                    sd_matt @A Former User
                    @bearer Here's the config.g
                    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 12:54:34 GMT-0700 (Pacific Daylight Time)
                    M550 P"BD3D Hypercube" ; set printer name
                    M667 S1 ; select CoreXY mode
                    M551 P"bdgpyg4c9sqm" ; set password
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S1 ; enable FTP
                    M586 P2 S1 ; enable Telnet
                    M569 P0 S0 ; physical drive 0 goes backwards
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                    M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                    M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X400 Y470 Z650 S0 ; set axis maxima
                    M574 X1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
                    M574 Y1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
                    M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
                    M574 Z1 S2 ; Use zprobe and home to min
                    M915 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
                    M574 Z1 S2 ; Set endstops controlled by probe
                    M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                    M558 P9 H3 F120 T6000 B1 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
                    G31 P400 X28 Y0 Z1.150 ; Set Z probe trigger value, offset and trigger height
                    M557 X15:355 Y15:355 S80 ; Define mesh grid
                    M305 P3 X201 ;
                    M141 H3 S80
                    M106 P7 S1 I0 F500 H2 T15 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P8 S1 I0 F500 H2 T15 ; set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    • davidvh86undefined
                      davidvh86
                      d the daughterboard and the reading is still the same. I tried putting in a 100ohm resistor in the circuit and then just the resistor in place of the wires. Not sure what is going on. I am just beginning to try to understand the g code.
                      Are you sure ur not talking about the pt100 daughter board, you cant use a thermistor with it.
                      • sd_mattundefined
                        sd_matt @davidvh86
                        @davidvh86
                        Read right off the board
                        davidvh86undefined 1 Reply Last reply Reply Quote 0
                        • sd_mattundefined
                          @bearer Im not sure if Im correct on the config as someone else walked me through it.
                          • Elvis0zundefined
                            Elvis0z
                            This post is deleted!
                              A Former User
                              now if we only had a picture to show where the board is connected and how the sensor is wired we could correlate it to the config.
                              but as it seems that is too much to ask I'm afraid we're at the end of what we can assist you with.
                                davidvh86 @sd_matt
                                  A Former User @davidvh86
                                    davidvh86
                                    @bearer said in Thermistor daughterboard beginner question.:
                                    " ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                    that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
                                    Oh sorry deleted it to avoid confusion lol
                                      [deleted]
                                        A Former User
                                        • sd_mattundefined
                                          sd_matt @dc42
                                          @dc42 What info are you missing. I can re post
                                          • sd_mattundefined
                                            sd_matt @davidvh86
                                            @davidvh86 Is there anything you want me to post to clear up any confusion?
