    Thermistor daughterboard beginner question.
    1.9k
      A Former User
      if we assume you did everything right then the board isn't working.
      if we're open to the possibility that the board is fine a picture or two and the complete config just might help, then again there is a limit to how many times I'll suggest that
      sd_mattundefined 2 Replies Last reply Reply Quote 0
      • sd_mattundefined
        sd_matt @A Former User
        @bearer Here's the config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 12:54:34 GMT-0700 (Pacific Daylight Time)
        M550 P"BD3D Hypercube" ; set printer name
        M667 S1 ; select CoreXY mode
        M551 P"bdgpyg4c9sqm" ; set password
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S1 ; enable FTP
        M586 P2 S1 ; enable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P2 S0 ; physical drive 2 goes backwards
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
        M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X400 Y470 Z650 S0 ; set axis maxima
        M574 X1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
        M574 Y1 S3 F0 R0 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
        M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
        M574 Z1 S2 ; Use zprobe and home to min
        M915 X Y S7 R0 F0 ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
        M574 Z1 S2 ; Set endstops controlled by probe
        M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
        M558 P9 H3 F120 T6000 B1 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
        G31 P400 X28 Y0 Z1.150 ; Set Z probe trigger value, offset and trigger height
        M557 X15:355 Y15:355 S80 ; Define mesh grid
        M305 P3 X201 ;
        M141 H3 S80
        M106 P7 S1 I0 F500 H2 T15 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P8 S1 I0 F500 H2 T15 ; set fan 4 value, PWM signal inversion and frequency. Thermostatic control is turned on
        • davidvh86undefined
          davidvh86
          @sd_matt said in Thermistor daughterboard beginner question.:
          d the daughterboard and the reading is still the same. I tried putting in a 100ohm resistor in the circuit and then just the resistor in place of the wires. Not sure what is going on. I am just beginning to try to understand the g code.
          Are you sure ur not talking about the pt100 daughter board, you cant use a thermistor with it.
          sd_mattundefined 1 Reply Last reply Reply Quote 0
          • sd_mattundefined
            sd_matt @davidvh86
            @davidvh86
            "PT100 RTD Board Revision 1.1a By Duet 3d CERN OHL 1.2"
            Read right off the board
            davidvh86undefined 1 Reply Last reply Reply Quote 0
            • sd_mattundefined
              @bearer Im not sure if Im correct on the config as someone else walked me through it.
              • Elvis0zundefined
                Elvis0z
                This post is deleted!
                  A Former User
                  now if we only had a picture to show where the board is connected and how the sensor is wired we could correlate it to the config.
                  but as it seems that is too much to ask I'm afraid we're at the end of what we can assist you with.
                    davidvh86 @sd_matt
                      A Former User @davidvh86
                        davidvh86
                        @bearer said in Thermistor daughterboard beginner question.:
                        " ; configure sensor 1 as thermocouple via CS pin spi.cs1
                        that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
                        Oh sorry deleted it to avoid confusion lol
                          dc42 administrators @sd_matt
                          [deleted]
                            A Former User
                            • sd_mattundefined
                              sd_matt @dc42
                              @dc42 What info are you missing. I can re post
                              • sd_mattundefined
                                sd_matt @davidvh86
                                @davidvh86 Is there anything you want me to post to clear up any confusion?
                                  Post a photo of the sensor and the board.
                                  sd_mattundefined 3 Replies Last reply Reply Quote 0
                                  • sd_mattundefined
                                    sd_matt @Phaedrux
                                    @Phaedrux 20200802_121400.jpg ![0_1596401451712_20200802_134550.jpg](Uploading 100%) ![0_1596401481981_20200802_134550.jpg](Uploading 100%)
                                    • sd_mattundefined
                                      sd_matt @Phaedrux
                                      • sd_mattundefined
                                        sd_matt @Phaedrux
                                        @Phaedrux With the wire, or a 100 ohm resistor, or simply with the "daughterboard" removed I get the same result.......2000 and faultScreenshot (27).png
                                          Use the 100 ohm resistor. A wire will give you a 2000 reading.
                                          If you send the M305 P3 X201 command from the console, does it respond with an error message?
                                          What is the response if you send M305 P3 X200?
                                            Phaedrux Moderator @sd_matt
                                            That is a thermistor, not a PT100 sensor.
                                            Either connect the thermistor directly to the thermistor inout on the Duet board, or get a PT100 sensor like this to use with the daughterboard.
                                            https://e3d-online.com/products/pt100-temperature-sensor
