    Thermistor daughterboard beginner question.
    1.9k
      A Former User @davidvh86
      This post is deleted!
      • davidvh86undefined
        davidvh86
        @bearer said in Thermistor daughterboard beginner question.:
        " ; configure sensor 1 as thermocouple via CS pin spi.cs1
        that is for firmware 3.x OP is using 2.02(RTOS) (2018-12-2
        Oh sorry deleted it to avoid confusion lol
        sd_mattundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @sd_matt
          [deleted]
            A Former User
            • sd_mattundefined
              sd_matt @dc42
              @dc42 What info are you missing. I can re post
              • sd_mattundefined
                sd_matt @davidvh86
                @davidvh86 Is there anything you want me to post to clear up any confusion?
                  Post a photo of the sensor and the board.
                  sd_mattundefined 3 Replies Last reply Reply Quote 0
                  • sd_mattundefined
                    sd_matt @Phaedrux
                    @Phaedrux 20200802_121400.jpg ![0_1596401451712_20200802_134550.jpg](Uploading 100%) ![0_1596401481981_20200802_134550.jpg](Uploading 100%)
                    • sd_mattundefined
                      sd_matt @Phaedrux
                      • sd_mattundefined
                        sd_matt @Phaedrux
                        @Phaedrux With the wire, or a 100 ohm resistor, or simply with the "daughterboard" removed I get the same result.......2000 and faultScreenshot (27).png
                          Use the 100 ohm resistor. A wire will give you a 2000 reading.
                          If you send the M305 P3 X201 command from the console, does it respond with an error message?
                          What is the response if you send M305 P3 X200?
                            Phaedrux Moderator @sd_matt
                            @sd_matt said in Thermistor daughterboard beginner question.:
                            That is a thermistor, not a PT100 sensor.
                            Either connect the thermistor directly to the thermistor inout on the Duet board, or get a PT100 sensor like this to use with the daughterboard.
                            https://e3d-online.com/products/pt100-temperature-sensor
                            • sd_mattundefined
                              sd_matt @dc42
                              @dc42 said in Thermistor daughterboard beginner question.:
                              No
                              M305 P3 X200
                              Error: Failed to initialise RTD: bad response from sensor
                              • sd_mattundefined
                                sd_matt @Phaedrux
                                @Phaedrux Ordered the part
                                  No
                                  M305 P3 X200
                                  You can also try sending just M305 P3. The response should include a description of the last error.
                                  • Kayjayundefined
                                    Kayjay
                                    @sd_matt it would appear that you are trying to connect a thermistor to the daughterboard. The daughterboard you have is for use with a PT100, there are links above taking you to a page that shows very clearly how to connect it.
                                    If you connect the PT100 to the connector you have the wire linked in the photo then use M305 P3 X201, if you use the other connector then select channel 200 instead of 201.
                                    If you want to use the thermistor then it will need to be connected to the appropriate terminal on the Duet motherboard not the daughterboard.
                                      Great. In the meantime, you should try using the resistor that came with the daughterboard to check that the daughterboard and your configuration is working, so that when the sensor arrives you can connect it and be up and running quickly.
                                      https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
                                      https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
