    Issues with IR Probe offset
    2.3k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @Phaedrux
      @Phaedrux lol nope if anything you’ve just confused me more!, However don’t want to pollute this thread With my lack of understanding so I will go do some research! Either way I hope you get agent0810 printing soon I’ll be watching this thread with interest as I’ve had the same issues!
      Cheers Jim
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      agent0810undefined 1 Reply Last reply Reply Quote 0
      • agent0810undefined
        agent0810 @jumpedwithbothfeet
        @jumpedwithbothfeet
        hey guys, sorry for the delay, got sick and was having a down system at work.
        so i set it back to:
        M557 X10:175 Y10:215 P8
        and here is what i get:
        8/3/2020, 12:02:36 PM M29
        GCode end-of-file being interpreted.
          agent0810 @Phaedrux
          @Phaedrux
          got it to finally work, but it looks worse lol
          • JoergS5undefined
            JoergS5 @agent0810
            @agent0810 just level the bed along the Y axis, this should make it better a lot.
              agent0810 @JoergS5
              @JoergS5
              i have went around multiple points on the bed and done the paper trick to get the bed as level as i think i possible can. advice on how to get it more accurate? thank you!
              • JoergS5undefined
                JoergS5 @agent0810
                @agent0810 I meant the map shows that one side is higher than the other side in the Y direction, so you only need to make higher or lower the bed a bit on one side. I don't know what you use, screws e.g. Then the map should look a lot better and you can run the procedure again. It's often an iterative process to get a good result.
                What is important, that you have a stable construction of the bed, otherwise you would have a "moving target". My second 3D printer was Prusa style, and I never finished calibrating the bed. Every time I wanted to print, it was inexact again, probably due to the springs or screws or uneven bed. It was not fun after the 10th calibration anymore, wasted time and filament.
                  It looks worse than it really is. The visual representation is exaggerated. The real differents is about 1.5mm from end to end. This could be the bed, or it could be the Y axis itself being a bit out of alignment. Do you have a flat edge ruler or machinist's square or even a builder square to check the squareness of the frame?
                  But you're on your way now if your probe is working.
                    agent0810 @Phaedrux
                    @Phaedrux I’m not sure my probe is working correctly, no matter what I do it either eaves the nozzle to far from the bed (this is 85% of the time) or it is way to close and no filament comes out. Should I try moving the probe up a tad bit?
                    I checked the squareness of the frame when I put it together and thought it was pretty damn good.
                      @agent0810 said in Issues with IR Probe offset:
                      Can you post a photo of the probe as it is mounted?
                        agent0810 @Phaedrux
                        @Phaedrux
                        Of course.
                          Is that mount improved at all over the last time we looked at it?
                          Have you tried placing a plain white sheet of paper on the bed and testing the probe that way? Perhaps it's picking up (or not picking up, as the case may be) on the bed surface.
                          But your probe repeatability results look ok, at least for that single point.
                            agent0810 @Phaedrux
                            @Phaedrux
                            I reprinted the mount, this was for the ender 3 but fits okay on my ender 5.
                            I have taped a white paper and the results were the same as without it.
                            What you see in the picture is as close as I can get it withought having th nozzle drag on the glass. I can use the baby steps during a print to move it but when I remove that amount in my config it makes no difference.
                            jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                              Can you perform the G30 S-1 trigger height test at multiple points across the bed? It would be good to know if the repeatability is good across the bed surface and if the trigger height changes.
                              What do you have in your slicer start gcode?
                                jumpedwithbothfeet @agent0810
                                @agent0810 @Phaedrux It might be the picture but is the board to high? The quote below is from the installation instructions, worth double checking?
                                “The bottom edge of the board should be between 1mm and 2mm higher than the tip of the nozzle. This should give you a trigger height between 0.5mm and 1.5mm.”
                                Regards Jim
                                agent0810undefined 1 Reply Last reply Reply Quote 1
                                  @jumpedwithbothfeet
                                  hey guys, so my buddy just put a BLtouch on his non duet board and he had to set the touch to probe before the print then save the points it pulled to get the first layer, here is the gcode he used.
                                  do we need to do something like that?
                                  G28 ; home all axes
                                  G1 Z10 F600 ; raise Z axis
                                  M190 S[bed0_temperature] ; stabilize bed
                                  M109 S[extruder0_temperature] ; stabilize extruder
                                  G1 X5 Y10 Z0.2 F3000 ; move to wait position
                                  G28; Home all axes
                                  G29; bed leveling
                                  M500; Store bed settings
                                  G92 E0 ; reset extrusion distance
                                  G1 E90 F1500 ; load filament
                                  G1 X160 E15 F600 ; prime nozzle
                                  G1 X180 F5000 ; quick wipe
                                  Phaedruxundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @agent0810
                                    @agent0810 no, m500 in reprapfirmware behaves quite differently to boards with an eeprom. It only saves certain things. Check the gcode wiki entry for m500 for specifics. But in RRF as soon as g29 is run the height map is saved and applied.
                                      @agent0810 @Phaedrux must be an ender 5 curse mine is also now playing up! But I have just changed out the hotend for a better one and it’s now reporting a substantial offset, if I find the issue I’ll let you know!
                                      Regards Jim
                                        jumpedwithbothfeet
                                        @agent0810 @Phaedrux its now working again here’s a list of things a changed and checked, bare in mind I’m running duet 3 with sbc.
                                        Firmware update - 79 files to update lol yup it’s been awhile
                                        Bed autopid - has helped in the past but I’ve no idea why!
                                        Reset the trigger height
                                        Levelled bed
                                        Calibrated z probe - trigger height now 3.021
                                        G29 - offset still poor test print failed
                                        Reset trigger height
                                        Adjusted IR probe height higher to about 3-4mm im now getting a trigger height of 1.451mm
                                        G29 carried out - bed now displays on the correct plane and flatter.
                                        First layer is much improved
                                        Hope this helps 🙂
