    Issues with IR Probe offset
    2.3k
    • agent0810undefined
      agent0810 @JoergS5
      @JoergS5 hmmmmm when i untighten the screws the bed goes up, when i tighten its pulled down.
      • JoergS5undefined
        JoergS5 @agent0810
        @agent0810 thats a signal that you bend the bed with the screws.....
        agent0810undefined 1 Reply Last reply Reply Quote 0
          agent0810 @JoergS5
          @JoergS5 soooooo i need a new bed?
          JoergS5undefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5 @agent0810
            @agent0810 not necessarily, you only need to install it even and without force
            The best information I know is https://drmrehorst.blogspot.com/2017/07/3-point-print-bed-leveling-vs-4-point.html?m=1 and other articles on his page.
              Phaedrux Moderator @agent0810
              @agent0810 said in Issues with IR Probe offset:
              @JoergS5 so something like X50:175?
              I think we already established the correct mesh in your previous thread. In your image from your first post you can see that the probe was able to reach those points, and on your resulting image you're limited to just a strip in the middle now.
              I'd try your original M557 values and redo the mesh again. I think the huge offset on your first attempt was an anomaly from running G29 without a fresh homing first.
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @agent0810
                @agent0810 I was not aware of the other thread. If you optimized M557 already, the original value is no problem of course (because the endstop/M208 will not be at the edge of the print bed in your case, I suspect. Just be careful not to touch/damage the sensor with the brackets).
                Your top layer is fiexed by brackets, so this could be the reason for the print area to be wavy. You should think about the design of the print bed according to the mrehorst blogs.
                My recommendations about hair lineal was halfway serious. The idea is that with two unknowns (is the X axis uneven or the print bed?) it's difficult to know what to make better. So a hair angle (to measure perpendiculary also) is a valuable tool.
                I took the best tolerance DIN 875/00. (Best would be 300 mm in your case, but they are expensive) One can measure the angle between X and Y also.
                • jumpedwithbothfeetundefined
                  jumpedwithbothfeet @Phaedrux
                  @Phaedrux @agent0810 just a few thoughts... looking over your config.g and comparing it with mine, the probe offset should be a positive not negative, are you still using your Z end stop switch instead of the probe?
                  Given M29 was sending your probe to front left i would look start looking at motor direction and end stops, my ender 5 homes back right X,Y to 0,0 and my mesh always starts from here
                  i've added an old config of mine but its for the Duet 3 that and few other things have been changed like my X axis direction but still it might help
                  config.g
                  Regards Jim
                  6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                    Phaedrux Moderator @jumpedwithbothfeet
                    @jumpedwithbothfeet said in Issues with IR Probe offset:
                    Your coordinates are reversed, but we've worked through with @agent0810 to place the 0,0 position at the front left and home to the back right to match a right hand coordinate system to match the common 3D printer arrangement. The Ender5 is an aberration in that regards. Hope that explains the difference.
                    jumpedwithbothfeetundefined agent0810undefined 2 Replies Last reply Reply Quote 0
                      @Phaedrux lol nope if anything you’ve just confused me more!, However don’t want to pollute this thread With my lack of understanding so I will go do some research! Either way I hope you get agent0810 printing soon I’ll be watching this thread with interest as I’ve had the same issues!
                      Cheers Jim
                        agent0810 @jumpedwithbothfeet
                        @jumpedwithbothfeet
                        hey guys, sorry for the delay, got sick and was having a down system at work.
                        so i set it back to:
                        M557 X10:175 Y10:215 P8
                        and here is what i get:
                        8/3/2020, 12:02:36 PM M29
                        GCode end-of-file being interpreted.
                          agent0810 @Phaedrux
                          @Phaedrux
                          got it to finally work, but it looks worse lol
                          • JoergS5undefined
                            JoergS5 @agent0810
                            @agent0810 just level the bed along the Y axis, this should make it better a lot.
                              agent0810 @JoergS5
                              @JoergS5
                              i have went around multiple points on the bed and done the paper trick to get the bed as level as i think i possible can. advice on how to get it more accurate? thank you!
                              • JoergS5undefined
                                JoergS5 @agent0810
                                @agent0810 I meant the map shows that one side is higher than the other side in the Y direction, so you only need to make higher or lower the bed a bit on one side. I don't know what you use, screws e.g. Then the map should look a lot better and you can run the procedure again. It's often an iterative process to get a good result.
                                What is important, that you have a stable construction of the bed, otherwise you would have a "moving target". My second 3D printer was Prusa style, and I never finished calibrating the bed. Every time I wanted to print, it was inexact again, probably due to the springs or screws or uneven bed. It was not fun after the 10th calibration anymore, wasted time and filament.
                                  It looks worse than it really is. The visual representation is exaggerated. The real differents is about 1.5mm from end to end. This could be the bed, or it could be the Y axis itself being a bit out of alignment. Do you have a flat edge ruler or machinist's square or even a builder square to check the squareness of the frame?
                                  But you're on your way now if your probe is working.
                                    agent0810 @Phaedrux
                                    @Phaedrux I’m not sure my probe is working correctly, no matter what I do it either eaves the nozzle to far from the bed (this is 85% of the time) or it is way to close and no filament comes out. Should I try moving the probe up a tad bit?
                                    I checked the squareness of the frame when I put it together and thought it was pretty damn good.
                                      Can you post a photo of the probe as it is mounted?
                                        agent0810 @Phaedrux
                                        @Phaedrux
                                        Of course.
                                          Is that mount improved at all over the last time we looked at it?
                                          Have you tried placing a plain white sheet of paper on the bed and testing the probe that way? Perhaps it's picking up (or not picking up, as the case may be) on the bed surface.
                                          But your probe repeatability results look ok, at least for that single point.
                                            agent0810 @Phaedrux
                                            @Phaedrux
                                            I reprinted the mount, this was for the ender 3 but fits okay on my ender 5.
                                            I have taped a white paper and the results were the same as without it.
                                            What you see in the picture is as close as I can get it withought having th nozzle drag on the glass. I can use the baby steps during a print to move it but when I remove that amount in my config it makes no difference.
