    Z motor steps calibration
    • Touchthebitumundefined
      Touchthebitum
      Hello
      I'm a bit confused with the Z Motor steps per mm calibration.
      I'm using RRF configurator and when I try to set up the correct steps for the 8mm leadscrew, I only get 1.25mm as pitch possibility.
      If I see the specs of this leadscrew, it is 2mm ....
      What would be the correct setting ?
      Thanks
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
      baird1faundefined 1 Reply Last reply Reply Quote 0
      • baird1faundefined
        baird1fa @Touchthebitum
        @Touchthebitum you will want to take the number of steps per revolution and divide by 2. Since your axis will travel 2mm for every revolution. If you have a 0.9 degree stepper and are not using any microstepping then you would set it to 200 (because 400/2) But I suspect you are using some amount of microsteps the number will be much larger. So take the 400 and multiply it by the microsteps, say for example 64 microsteps then it becomes (400*64)/2 = 12,800.
        Hope that helps.
        Touchthebitumundefined 1 Reply Last reply Reply Quote 0
          Touchthebitum @baird1fa
          @baird1fa
          Thanks
          So if I understand correctly, I would have this ?
            Phaedrux Moderator @Touchthebitum
            @Touchthebitum That looks correct based on the formula for lead screw axis:
            Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
              Touchthebitum @Phaedrux
              @Phaedrux
              Thanks
              Does a leadscrew 8mm (M8) with a 1.25mm pitch exists ?
              I don't see anything like this on the net...
                droftarts administrators @Touchthebitum
                @Touchthebitum standard 8mm threaded rod has a thread pitch of 1.25mm. Was heavily used in the ‘old’ RepRap days!
                  Touchthebitum @droftarts
                  @droftarts
                  Thanks for the info 😉
