    ender 5 plus
    1.5k
      dropbox, or google drive, box, onedrive, youtube, vimeo, something like that.
      • Kevinundefined
        Kevin
        oke i go try
        • Kevinundefined
          Kevin
          https://youtu.be/RuRSe_RKp9U
          https://youtu.be/aUn8AIXxMeU
          1 movie is home and then g32 several times
            Are you using a macro called G32 HOME? Or are you using just G32 (which calls bed.g)?
            • Kevinundefined
              Kevin
              i tried both normal G32 (bed.g) and macro G32 same settings as bed.g
                It's hard to really see any movement in the video. I can't tell if it's actually making an adjustment or not. Is it?
                If you purposely introduce an exaggerated tilt, does it try to correct it?
                peter247undefined 1 Reply Last reply Reply Quote 0
                • peter247undefined
                  peter247 @Phaedrux
                  @Phaedrux Sorry don't want to hijack this post , but I'm thinking I may finish up doing the same thing with the bltouch and the ender 5 +
                  What does bed level do ? probe the centre of the bed and set both corner to this level ?.
                  Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                  • Kevinundefined
                    Kevin
                    he only adjusts the lowest side and always down not flat.
                    when I raise right goes left after bottom,
                    when I raise left goes right after bottom
                    https://youtu.be/XKS44LAiNmA
                      ; Bed adjustment screw locations
                      M671 X-20:370 Y0:0 S2 ; leadscrew-locaties
                      I don't think your Y coordinate is correct. Your lead screws are in the middle of the bed along the Y axis, not at the front. According to your bed.g it should be Y165:165
                      I don't think that matters in this case, but it's something I noticed.
                      Your driver order looks correct to match your lead screw positions. Can you double check that the left motor is connected to driver 2 and the right to driver 4? The behaviour seems to indicate it's doing the reverse of what it should, and having the drivers reversed would do that.
                      The only other thing I can think of is maybe the IR probe not liking your build plate surface. Can you show a photo of the bed surface? Can you try putting a piece of plain white paper under where the probe samples?
                      • peter247undefined
                        peter247 @Kevin
                        @Kevin Hi , have you tried using ruler and not used someone else's setting for a different printer ?
                        on my ender 5 plus it is about 40mm from the nozzle to the centre of the leadscrew left and only 20mm right.
                        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                        Note: If you are experiencing the Z axis compensating in the opposite direction needed, that means your Z motors are swapped. You can either swap the X values in the M671 command, or swap the stepper motors plugged into the Duet.
                        your bed.g , shouldn't you home all axis first not after
                        ; bed.g
                        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 20:35:09 GMT+0200 (Midden-Europese zomertijd)
                        ;G29  ; probe the bed and enable compensation
                        G30 P0 X5 Y165 Z-99999  ; probe near a leadscrew left
                        G30 P1 X325 Y165 Z-99999 S2; probe near a leadscrew right
                        G28 XY: HOME
                        G32
                        Leadscrew adjustments made: 0.051 -0.017, points used 2, (mean, deviation) before (0.016, 0.021) after (-0.000, 0.000)
                        WORKED FOR ME
                        • peter247undefined
                          peter247 @Phaedrux
                          @Phaedrux
                          Recommendations
                          If you have just 2 Z motors, one at each end of the X axis, then set the Y coordinates of the leadscrews in the M671 command to be equal (the value doesn't matter, so you can use zero). Use at least two probe points, one at each end of the X axis. All your probe points should have the same Y coordinate, which should be at or near the middle of the printable range.
                          • peter247undefined
                            peter247
                            it works for me , but had to run G32 twice .
                            The first go was near ,not sure if was due to my .5mm limit .
                            19/08/2020, 18:29:16 G29
                            25 points probed, min error -0.024, max error 0.038, mean 0.007, deviation 0.016
                            Height map saved to file 0:/sys/heightmap.csv
                            19/08/2020, 18:27:02 G32
                            Leadscrew adjustments made: 0.079 -0.038, points used 2, (mean, deviation) before (0.021, 0.036) after (-0.000, 0.000)
                            19/08/2020, 18:25:43 G29
                            25 points probed, min error -0.043, max error 0.061, mean 0.002, deviation 0.030
                            19/08/2020, 18:23:33 G32
                            Leadscrew adjustments made: 0.341 -0.295, points used 2, (mean, deviation) before (0.023, 0.194) after (-0.000, 0.000)
                            • Kevinundefined
                              Kevin
                              @peter247
                              I had measured but I don't have an original hotend.
                              i have switched the connection on the stepper motors and it works.
                              not perfect yet because I have different values ​​every time
                              how do you use it? first mesh G29 then G32 or first G32 then G29
                              Aantekening 2020-08-19 220337.png these are 3 repetitions in a row and then done mesh
                                Normally you'd use G28 > G32 > G29 but it really depends on how you have things configured. Usually G28 would home the Axis. G32 would execute whatever you have in bed.g which might be tilt correction, and then you'd use G29 after the tilt correction to map out the surface details.
                                • Kevinundefined
                                  Kevin
                                  thanks for response
                                  i am using combined macros with G28> G32> G29
                                  • peter247undefined
                                    peter247 @Kevin
                                    @Kevin I did a z home , g32 then a g29 , then a z home.
                                    Mine a have a nice little ripple , but not red spots .
