    hbot homes correctly but prints mirrored ,
    9.0k
    • tracarundefined
      tracar
      so from looking from the front of the printer, my x/y endstops are in the rear left corner,
      this is the only place i want them to be due to wiring ease.
      now im not the best on programming, but over the past month have been able to get , for the most part, everything to work sorta. thru trial and error, so i may have repeated a few lines here and there....... Z axis works as it should
      Board: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
      Duet WiFi Server Version: 1.23
      CoreXY
      after homing to the left rear corner......., x+ and y+ will move the head towards and to the right of the printer (right front corner)
      i also can not figgure out how to get the second z axis to be separate from the first. to use as bed leveling.
      i have an expansion board so i can use a closed loop setup,
      prints are mirrored, they look good but all are mirrored from the stl.
      So basically i like the way it is set up with the homing in the back left corner, but need to get it to print non mirrored, can this be done ?
      The printer is a bit messy. but its still in the design steps, once i have the thing printing right , it will be taken apart completely and rebuilt all squared nicely, with a few new parts added.
      feel free to make any changes to the code, so i can see how this related to motion.
      G31 X0 Y0 Z0 P25
      M550 P"Duet2" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P5 S1 T5 R1 ; physical drive x axis goes forwards
      M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
      M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
      M569 P8 S1 T5 R1 ; physical drive z2 axis goes forwards
      M569 P3 S1 ; physical drive 3 goes forwards extruder
      M584 X5 Y6 Z7:8 E3 ; set drive mapping
      M92 X200.00 Y200.00 Z800.00 E138.2316760023409 ; set steps per mm
      M566 X200.00 Y200.00 Z200.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
      M201 X400.00 Y400.00 Z400.00 E400.00 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeout
      M208 X440 Y535 Z900 S0 ; set axis maxima
      M574 X1 Y1 Z1 S0 ; set active high endstops
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
      M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
      ;M575 P1 S1 B57600 ; enable support for PanelDue
      ; homeall.g
      ; called to home all axes
      M280 P7 S90
      G91 ; relative positioning
      G1 H2 Z5 F800 ; lift Z relative to current position
      G1 H1 X-445 Y-540 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-445 ; home X axis
      G1 H1 Y-540 ; home Y axis
      G1 X5 Y5 F800 ; go back a few mm
      G1 H1 X-445 F200 ; move slowly to X axis endstop (second pass)
      G1 H1 Y-540 F200 ; move slowly to Y axis endstop (second pass)
      G1 H1 Z-905 F400 ; home Z axis
      G1 Z5 F200 F800 ; go back a few mm
      G1 H1 Z-905 F100 ; move slowly to Z axis endstop (second pass)
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      G1 Z5 F800 ; lift Z relative to current position
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 12:25:17 GMT-0600 (Mountain Daylight Time)
      M280 P7 S90
      G1 H1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F800 ; go back a few mm
      G1 H1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F800 ; lower Z again
      ; homey.g
      ; called to home the Y axis
      M280 P7 S90
      G1 H1 Y-540 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F800 ; go back a few mm
      G1 H1 Y-540 F360 ; move slowly to Y axis endstop once more (second pass)
      thanks in advance for any help.![alt text](image url20200824_110843.jpg )
      peter247undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • peter247undefined
        peter247 @tracar
        @tracar
        This my guess what happening :-
        You have set high end homing ( right ) in your config.g , But your machine uses low end homing .
        Your homing files say G1 H2 X300 , which is correct for high end homing , but you have the motor direction wrong too.
        So it goes left think it's going right and hit the end stop on the left thinking it's the right end stop.
        Two wrong making a right .. and so you have mirror !!!
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        tracarundefined 1 Reply Last reply Reply Quote 0
        • tracarundefined
          tracar @peter247
          @peter247
          so which lines do i change to to reverse the direction it homes ?
          peter247undefined 1 Reply Last reply Reply Quote 0
          • peter247undefined
            peter247 @tracar
            @tracar
            So does your machine home to the left or right , front or back.
            I think I may be wrong what is the first few line of M122
            are you sure your extruder shouldn't be E138.2316760023408 step per mm , never seen anyone set the Esteps to 13 digits before.
            • tracarundefined
              tracar @peter247
              @peter247
              i posted some photos of the setup. it homes to the left side, and to the back.
              as for the 13 digits, lol.... old habit just a cut and paste, cant be too accurate hahahaha
              where is the M122 located
              peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
              • peter247undefined
                peter247 @tracar
                @tracar
                where is the M122 located ? top of the screen !!!
                Type M122 in the send code box and click send and post the first few line in the console .
                4/08/2020, 19:35:49 M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-95BLL-N6PSS-6JTD6-3SJ6K-K0UZJ
                Used output buffers: 3 of 24 (16 max)
                I think I know what happening again ... new idea !!!!!
                You have used the version 3 configurator , but you have not upgraded to firmware version 3 and still on version 2 .
                CoreXY
                NOTE THE - WiFi/Ethernet 2.05.1 to my WiFi/Ethernet version 3.1.1
                what are the 4 control boxes at the back ?
                • tracarundefined
                  tracar @peter247
                  @peter247
                  the 4 black boxes are closed loop drivers for the 4 steppers x,y,z1,z2
                  i will get back to you on the above when i get home
                  • peter247undefined
                    peter247 @tracar
                    @tracar
                    This time I think I'm correct , because after looking at your config.g and homing file I could not find a fault.
                    Your machine looks a bit of a beast !!!
                    I tried to making my own version of the cr10 and over killed it to the point where it just printed so bad , In the end just got a ender 5 plus.
                    closed loop drivers ? , do you just connect the wire which was going to the steppers are use external drivers ?.
                    • tracarundefined
                      tracar @peter247
                      @peter247
                      closed loop drivers are the ones for steppers with encoders built in.
                      the steppers wont skip and loose track of their position even if you push an axis out of position. it will self correct....., its all good but if the belt skips then it will loose position. really good for systems with ball sxrews.
                        Phaedrux Moderator @tracar
                        @tracar said in hbot homes correctly but prints mirrored ,:
                        Your Y axis is flipped. +Y should go to the back. -Y to the front. This places 0,0 in the front left corner.
                        See this post on what you must set based on your physical printer and then what you need to change to make that work.
                        https://forum.duet3d.com/topic/18241/duet-2-wifi-bltouch-issues-on-ender-5-pro/37?_=1598300832742
                        • peter247undefined
                          peter247 @Phaedrux
                          @Phaedrux
                          I think he is using the version 3 config.g and still on firmware version 2 , so I think it just ignores parts of the config file and works in a default way.
                            Phaedrux Moderator @peter247
                            @peter247 said in hbot homes correctly but prints mirrored ,:
                            @Phaedrux
                            Yup you're totally right.
                              To update to RRF3 you need to upload these two zip files as is one at a time to the /sys folder using DWC.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                              • tracarundefined
                                tracar @tracar
                                @tracar
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                                Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
                                Used output buffers: 7 of 24 (10 max)
                                • tracarundefined
                                  tracar @Phaedrux
                                  @Phaedrux
                                  i tried v3 but didnt have enough brain power at that time to change all the needed files for it to work.
                                  • tracarundefined
                                    tracar @Phaedrux
                                    @Phaedrux
                                    0,0 is in the rear left corner
                                    front right corner is x440,y535
                                      @Phaedrux
                                      Your config files are already using the format for RRF3, so you'll either need new files for RRF2 or update to RRF3.
                                        @Phaedrux
                                        See my linked post earlier about why you want 0,0 to be the front left corner. At the very least to understand how to get your prints unmirrored.
                                        • tracarundefined
                                          tracar @Phaedrux
                                          @Phaedrux
                                          i understand that if i modify my physical layout, i can achieve the goal of the correct homing direction .and thus a non mirrored print
                                          But my original question is Can it be changed in the software as so i dont have to change anything physically.
                                          with every cnc i have built. i can easily tell it what dir to home and what axis. this plastic printer just boggles me . lol
                                            I'm not saying you have to change anything physical. It's all software settings. If you read the post I linked it tells you what had to be set based on your physical printer.
                                            0,0 is just a coordinate. Putting it in the front left matches the slicer and cad software coordinate system.
                                            The endstop position is irrelevant. It can be anywhere you want. The firmware just needs to know where it is based on 0,0 being in the front left.
                                            Your homing moves are set in the homing files. The direction has to move towards the endstop.
                                            The direction the motor actually goes is determined by the direction of rotation which is also defined in software.
