    hbot homes correctly but prints mirrored ,
    9.2k
    • tracarundefined
      tracar @peter247
      @peter247
      i posted some photos of the setup. it homes to the left side, and to the back.
      as for the 13 digits, lol.... old habit just a cut and paste, cant be too accurate hahahaha
      where is the M122 located
      peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
      • peter247undefined
        peter247 @tracar
        @tracar
        where is the M122 located ? top of the screen !!!
        Type M122 in the send code box and click send and post the first few line in the console .
        4/08/2020, 19:35:49 M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-95BLL-N6PSS-6JTD6-3SJ6K-K0UZJ
        Used output buffers: 3 of 24 (16 max)
        I think I know what happening again ... new idea !!!!!
        You have used the version 3 configurator , but you have not upgraded to firmware version 3 and still on version 2 .
        Board: Duet WiFi 1.02 or later
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
        Duet WiFi Server Version: 1.23
        CoreXY
        NOTE THE - WiFi/Ethernet 2.05.1 to my WiFi/Ethernet version 3.1.1
        what are the 4 control boxes at the back ?
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        tracarundefined 1 Reply Last reply Reply Quote 0
        • tracarundefined
          tracar @peter247
          @peter247
          the 4 black boxes are closed loop drivers for the 4 steppers x,y,z1,z2
          i will get back to you on the above when i get home
          peter247undefined 1 Reply Last reply Reply Quote 0
          • peter247undefined
            peter247 @tracar
            @tracar
            This time I think I'm correct , because after looking at your config.g and homing file I could not find a fault.
            Your machine looks a bit of a beast !!!
            I tried to making my own version of the cr10 and over killed it to the point where it just printed so bad , In the end just got a ender 5 plus.
            closed loop drivers ? , do you just connect the wire which was going to the steppers are use external drivers ?.
            • tracarundefined
              tracar @peter247
              @peter247
              closed loop drivers are the ones for steppers with encoders built in.
              the steppers wont skip and loose track of their position even if you push an axis out of position. it will self correct....., its all good but if the belt skips then it will loose position. really good for systems with ball sxrews.
                Phaedrux Moderator @tracar
                @tracar said in hbot homes correctly but prints mirrored ,:
                y+ will move the head towards
                Your Y axis is flipped. +Y should go to the back. -Y to the front. This places 0,0 in the front left corner.
                See this post on what you must set based on your physical printer and then what you need to change to make that work.
                https://forum.duet3d.com/topic/18241/duet-2-wifi-bltouch-issues-on-ender-5-pro/37?_=1598300832742
                • peter247undefined
                  peter247 @Phaedrux
                  @Phaedrux
                  I think he is using the version 3 config.g and still on firmware version 2 , so I think it just ignores parts of the config file and works in a default way.
                    Phaedrux Moderator @peter247
                    @peter247 said in hbot homes correctly but prints mirrored ,:
                    @Phaedrux
                    Yup you're totally right.
                      To update to RRF3 you need to upload these two zip files as is one at a time to the /sys folder using DWC.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                      • tracarundefined
                        tracar @tracar
                        @tracar
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                        Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
                        Used output buffers: 7 of 24 (10 max)
                        • tracarundefined
                          tracar @Phaedrux
                          @Phaedrux
                          i tried v3 but didnt have enough brain power at that time to change all the needed files for it to work.
                          • tracarundefined
                            tracar @Phaedrux
                            @Phaedrux
                            0,0 is in the rear left corner
                            front right corner is x440,y535
                              @Phaedrux
                              Your config files are already using the format for RRF3, so you'll either need new files for RRF2 or update to RRF3.
                                @Phaedrux
                                See my linked post earlier about why you want 0,0 to be the front left corner. At the very least to understand how to get your prints unmirrored.
                                • tracarundefined
                                  tracar @Phaedrux
                                  @Phaedrux
                                  i understand that if i modify my physical layout, i can achieve the goal of the correct homing direction .and thus a non mirrored print
                                  But my original question is Can it be changed in the software as so i dont have to change anything physically.
                                  with every cnc i have built. i can easily tell it what dir to home and what axis. this plastic printer just boggles me . lol
                                    I'm not saying you have to change anything physical. It's all software settings. If you read the post I linked it tells you what had to be set based on your physical printer.
                                    0,0 is just a coordinate. Putting it in the front left matches the slicer and cad software coordinate system.
                                    The endstop position is irrelevant. It can be anywhere you want. The firmware just needs to know where it is based on 0,0 being in the front left.
                                    Your homing moves are set in the homing files. The direction has to move towards the endstop.
                                    The direction the motor actually goes is determined by the direction of rotation which is also defined in software.
                                    • tracarundefined
                                      tracar
                                      its a bit much for me, i did upgrade to 3.11 but then it took me 3 days to figure out how to downgrade and get the wifi part to connect.. im more a hardware kinda guy. this software is a p-i-t-a for me.
                                      so can you show me a visual example of what i need to change in the code ?
                                        Sure. Post your current config.g and the results of M115 so I know what firmware you're currently on.
                                        Physical location of endstops is left and rear correct?
                                        • peter247undefined
                                          peter247 @tracar
                                          @tracar
                                          Do a M122 again , so we can make sure you are on version 3.1 of the firmware.
                                          • tracarundefined
                                            tracar
                                            @Phaedrux said in hbot homes correctly but prints mirrored ,:
                                            M115
                                            currently:
                                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 12:25:17 GMT-0600 (Mountain Daylight Time)
                                            G31 X0 Y0 Z0 P25
                                            M550 P"Duet2" ; set printer name
                                            M669 K1 ; select CoreXY mode
                                            M552 S1 ; enable network
                                            M586 P0 S1 ; enable HTTP
                                            M586 P1 S0 ; disable FTP
                                            M586 P2 S0 ; disable Telnet
                                            M569 P5 S1 T5 R1 ; physical drive x axis goes forwards
                                            M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
                                            M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
                                            M569 P8 S1 T5 R1 ; physical drive z2 axis goes forwards
                                            M584 X5 Y6 Z7:8 E3 ; set drive mapping
                                            M92 X200.00 Y200.00 Z800.00 E138.2316760023409 ; set steps per mm
                                            M566 X200.00 Y200.00 Z200.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                            M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
                                            M201 X400.00 Y400.00 Z400.00 E400.00 ; set accelerations (mm/s^2)
                                            M84 S30 ; Set idle timeout
                                            M208 X440 Y535 Z900 S0 ; set axis maxima
                                            M574 X1 Y1 Z1 S0 ; set active high endstops
                                            M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                            M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                                            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                            G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                                            M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                                            ;M575 P1 S1 B57600 ; enable support for PanelDue
