    hbot homes correctly but prints mirrored ,
    9.1k
      Sure. Post your current config.g and the results of M115 so I know what firmware you're currently on.
      Physical location of endstops is left and rear correct?
      • peter247undefined
        peter247 @tracar
        @tracar
        Do a M122 again , so we can make sure you are on version 3.1 of the firmware.
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        • tracarundefined
          tracar
          @Phaedrux said in hbot homes correctly but prints mirrored ,:
          M115
          currently:
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 12:25:17 GMT-0600 (Mountain Daylight Time)
          G31 X0 Y0 Z0 P25
          M550 P"Duet2" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P5 S1 T5 R1 ; physical drive x axis goes forwards
          M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
          M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
          M569 P8 S1 T5 R1 ; physical drive z2 axis goes forwards
          M584 X5 Y6 Z7:8 E3 ; set drive mapping
          M92 X200.00 Y200.00 Z800.00 E138.2316760023409 ; set steps per mm
          M566 X200.00 Y200.00 Z200.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
          M201 X400.00 Y400.00 Z400.00 E400.00 ; set accelerations (mm/s^2)
          M84 S30 ; Set idle timeout
          M208 X440 Y535 Z900 S0 ; set axis maxima
          M574 X1 Y1 Z1 S0 ; set active high endstops
          M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
          M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
          ;M575 P1 S1 B57600 ; enable support for PanelDue
          peter247undefined 1 Reply Last reply Reply Quote 0
          • peter247undefined
            peter247 @tracar
            @tracar said in hbot homes correctly but prints mirrored ,:
            Still version 2 firmware and running 3.1 config.g
            • peter247undefined
              peter247 @peter247
              @peter247
              To update to RRF3 you need to upload these two zip files as is one at a time to the /sys folder using DWC.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
              DOWNLOAD , BUT DON'T UNZIP.
              Go to the system tab and click update system file , find and select Det2and3Firmware-3.0.zip .
              If it says your our running 3.0 with m122 repeat with the 3.1 file.
              • tracarundefined
                tracar
                m122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                • tracarundefined
                  tracar
                  This post is deleted!
                  • tracarundefined
                    tracar
                    think im getting somewhere.
                    homing works and reports as
                    x0
                    y535
                    z5
                    z moves dow 5 after homing , all good here
                    after homing, when i jog X+ it goes away from the end-stop and moves to the right,
                    and when i give Y+ its travel is reversed, it should be moving towards the sensors , to the back of the machine, y- moves it towards the sensors and the back of the machine.
                    what needs to be changed to correct y motion travel?
                    • peter247undefined
                      peter247 @tracar
                      @tracar
                      X homing to the left and Zero ... correct !!
                      Y homing to the back and 535mm ... correct !!!
                      Z 5mm correct if it is 5mm off the glass , you may need the set the offset
                      • tracarundefined
                        tracar
                        after homing, when i jog X+ it goes away from the end-stop and moves to the right, this is correct!
                        • tracarundefined
                          tracar
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 25 2020 08:01:23 GMT-0600 (Mountain Daylight Time)
                          G31 X0 Y0 Z0 P25
                          M569 P5 S1 T5 R1 ; physical drive x goes forwards
                          M569 P6 S1 T5 R1 ; physical drive y goes forwards
                          M569 P7 S1 T5 R1 ; physical drive z goes forwards
                          M569 P8 S1 T5 R1 ; physical drive z2 goes forwards
                          M569 P3 S1 ; physical drive extruder goes forwards
                          M92 X200.00 Y200.00 Z200.00 E138.23 ; set steps per mm
                          M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
                          M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
                          M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                          M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
                          M557 X50:400 Y50:500 S50 ; define mesh grid
                          • peter247undefined
                            peter247 @tracar
                            @tracar
                            M569 P0 S0 changes the direction ? S0 or S1
                            BUT HAVE YOU CHANGED THIS
                            ; homey.g
                            ; called to home the Y axis
                            M280 P7 S90
                            G91 ; relative positioning
                            G1 H2 Z5 F800 ; lift Z relative to current position
                            G1 H1 Y-540 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                            G1 Y5 F800 ; go back a few mm
                            G1 H1 Y-540 F360 ; move slowly to Y axis endstop once more (second pass)
                            G1 H2 Z-5 F800 ; lower Z again
                            G90 ; absolute positioning
                            The Y should be a positive number not minus.
                            • peter247undefined
                              peter247 @peter247
                              @peter247
                              getting closer !!!!
                              • tracarundefined
                                tracar
                                the homing works as it should,
                                the only issue now is when i manually move it in the x and y coordinates , the x works as it should.. but the y is reversed
                                moving x+ moves it to the right and away from the endstop
                                moving y+ does not move and y- moves it away from the endstop towards the front of the printer.
                                y machine movement needs to be reversed.
                                • peter247undefined
                                  peter247 @tracar
                                  @tracar
                                  You need to change Y homing to a positive and change the direction of the motor .. You must do both !!!!!!
                                  You are back to my first post what's wrong .
                                  end stops are correct.
                                  • tracarundefined
                                    tracar
                                    change y homing in the homeall or the homey
                                    ; homeall.g
                                    ; called to home all axes
                                    M280 P7 S90
                                    G1 H1 X-445 Y-540 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                    G1 H1 X-445 ; home X axis
                                    G1 H1 Y-540 ; home Y axis
                                    G1 X5 Y5 F800 ; go back a few mm
                                    G1 H1 X-445 F200 ; move slowly to X axis endstop (second pass)
                                    G1 H1 Y-540 F200 ; move slowly to Y axis endstop (second pass)
                                    G1 H1 Z-905 F400 ; home Z axis
                                    G1 Z5 F200 F800 ; go back a few mm
                                    G1 H1 Z-905 F100 ; move slowly to Z axis endstop (second pass)
                                    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                    G1 Z5 F800 ; lift Z relative to current position
                                    ; homey.g
                                    M280 P7 S90
                                    • peter247undefined
                                      peter247 @tracar
                                      @tracar
                                      BOTH , Remove ALL the minus sign for Y
                                      eg G1 H1 Y-540 F1800 to just G1 H1 Y540 F1800
                                      I missed a bit , Change all the positive Y to a minus
                                      G1 Y5 F800 to G1 Y-5 F800
                                      So really invert anything use the Y axis , ONLY THE Ys NOT THE X or Zs
                                      • tracarundefined
                                        tracar
                                        changes made. yaxis moves away from the endstops now when homed, all else works as it should
                                        this is a coreXY hbot setup.
                                        i can change the direction of the steppers if needed by a switch on the driver, as they are external.
                                        • peter247undefined
                                          peter247 @tracar
                                          @tracar
                                          So we did it in the end ? .
                                          • tracarundefined
                                            tracar
                                            no
                                            homing x and y travels to the correct corner and has been fixed,
                                            the only thing that is wrong is the y axis movement, ONLY after it has been homed.
