    hbot homes correctly but prints mirrored ,
    9.2k
      To update to RRF3 you need to upload these two zip files as is one at a time to the /sys folder using DWC.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
      tracarundefined 1 Reply Last reply Reply Quote 0
      • tracarundefined
        tracar @tracar
        @tracar
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
        Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
        Used output buffers: 7 of 24 (10 max)
        • tracarundefined
          tracar @Phaedrux
          @Phaedrux
          i tried v3 but didnt have enough brain power at that time to change all the needed files for it to work.
          • tracarundefined
            tracar @Phaedrux
            @Phaedrux
            0,0 is in the rear left corner
            front right corner is x440,y535
              Phaedrux Moderator @tracar
              @tracar said in hbot homes correctly but prints mirrored ,:
              @Phaedrux
              Your config files are already using the format for RRF3, so you'll either need new files for RRF2 or update to RRF3.
                @Phaedrux
                See my linked post earlier about why you want 0,0 to be the front left corner. At the very least to understand how to get your prints unmirrored.
                • tracarundefined
                  tracar @Phaedrux
                  @Phaedrux
                  i understand that if i modify my physical layout, i can achieve the goal of the correct homing direction .and thus a non mirrored print
                  But my original question is Can it be changed in the software as so i dont have to change anything physically.
                  with every cnc i have built. i can easily tell it what dir to home and what axis. this plastic printer just boggles me . lol
                    I'm not saying you have to change anything physical. It's all software settings. If you read the post I linked it tells you what had to be set based on your physical printer.
                    0,0 is just a coordinate. Putting it in the front left matches the slicer and cad software coordinate system.
                    The endstop position is irrelevant. It can be anywhere you want. The firmware just needs to know where it is based on 0,0 being in the front left.
                    Your homing moves are set in the homing files. The direction has to move towards the endstop.
                    The direction the motor actually goes is determined by the direction of rotation which is also defined in software.
                    • tracarundefined
                      tracar
                      its a bit much for me, i did upgrade to 3.11 but then it took me 3 days to figure out how to downgrade and get the wifi part to connect.. im more a hardware kinda guy. this software is a p-i-t-a for me.
                      so can you show me a visual example of what i need to change in the code ?
                      peter247undefined 1 Reply Last reply Reply Quote 0
                        Sure. Post your current config.g and the results of M115 so I know what firmware you're currently on.
                        Physical location of endstops is left and rear correct?
                        • peter247undefined
                          peter247 @tracar
                          @tracar
                          Do a M122 again , so we can make sure you are on version 3.1 of the firmware.
                          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                          • tracarundefined
                            tracar
                            @Phaedrux said in hbot homes correctly but prints mirrored ,:
                            M115
                            currently:
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 12:25:17 GMT-0600 (Mountain Daylight Time)
                            G31 X0 Y0 Z0 P25
                            M550 P"Duet2" ; set printer name
                            M669 K1 ; select CoreXY mode
                            M552 S1 ; enable network
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P5 S1 T5 R1 ; physical drive x axis goes forwards
                            M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
                            M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
                            M569 P8 S1 T5 R1 ; physical drive z2 axis goes forwards
                            M584 X5 Y6 Z7:8 E3 ; set drive mapping
                            M92 X200.00 Y200.00 Z800.00 E138.2316760023409 ; set steps per mm
                            M566 X200.00 Y200.00 Z200.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
                            M201 X400.00 Y400.00 Z400.00 E400.00 ; set accelerations (mm/s^2)
                            M84 S30 ; Set idle timeout
                            M208 X440 Y535 Z900 S0 ; set axis maxima
                            M574 X1 Y1 Z1 S0 ; set active high endstops
                            M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                            M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                            M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                            ;M575 P1 S1 B57600 ; enable support for PanelDue
                            • peter247undefined
                              peter247 @tracar
                              Still version 2 firmware and running 3.1 config.g
                              • peter247undefined
                                peter247 @peter247
                                @peter247
                                DOWNLOAD , BUT DON'T UNZIP.
                                Go to the system tab and click update system file , find and select Det2and3Firmware-3.0.zip .
                                If it says your our running 3.0 with m122 repeat with the 3.1 file.
                                • tracarundefined
                                  tracar
                                  m122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                  • tracarundefined
                                    tracar
                                    This post is deleted!
                                    • tracarundefined
                                      tracar
                                      think im getting somewhere.
                                      homing works and reports as
                                      x0
                                      y535
                                      z5
                                      z moves dow 5 after homing , all good here
                                      after homing, when i jog X+ it goes away from the end-stop and moves to the right,
                                      and when i give Y+ its travel is reversed, it should be moving towards the sensors , to the back of the machine, y- moves it towards the sensors and the back of the machine.
                                      what needs to be changed to correct y motion travel?
                                      • peter247undefined
                                        peter247 @tracar
                                        @tracar
                                        X homing to the left and Zero ... correct !!
                                        Y homing to the back and 535mm ... correct !!!
                                        Z 5mm correct if it is 5mm off the glass , you may need the set the offset
                                        • tracarundefined
                                          tracar
                                          after homing, when i jog X+ it goes away from the end-stop and moves to the right, this is correct!
                                          • tracarundefined
                                            tracar
                                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 25 2020 08:01:23 GMT-0600 (Mountain Daylight Time)
                                            G31 X0 Y0 Z0 P25
                                            M569 P5 S1 T5 R1 ; physical drive x goes forwards
                                            M569 P6 S1 T5 R1 ; physical drive y goes forwards
                                            M569 P7 S1 T5 R1 ; physical drive z goes forwards
                                            M569 P8 S1 T5 R1 ; physical drive z2 goes forwards
                                            M569 P3 S1 ; physical drive extruder goes forwards
                                            M92 X200.00 Y200.00 Z200.00 E138.23 ; set steps per mm
                                            M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                            M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
                                            M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
                                            M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                                            M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
                                            G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
                                            M557 X50:400 Y50:500 S50 ; define mesh grid
