    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    9.0k
    • whopping pochardundefined
      whopping pochard @dhusolo
      @dhusolo I'm not on Facebook, unfortunately -- definitely bums me out that the BLV community nexus seems to be there!
      I would love to see your build! Any links? Also, how has it worked out for you? Would love to know more! 😄
      • Vetiundefined
        Veti
        ben is working on all metal parts for the blv.
        https://www.blvprojects.com/post/the-metal-parts-are-finally-here
        • JamesMundefined
          JamesM
          I'm actually re-doing my bed mounts after seeing you using the extrusion pieces. It gave me an idea and I'll see how it works. Have to design and print a few things first 🙂
          whopping pochardundefined 1 Reply Last reply Reply Quote 0
            whopping pochard @JamesM
            @JamesM Sweet, I look forward to seeing the result!
            dhusoloundefined 1 Reply Last reply Reply Quote 0
            • dhusoloundefined
              dhusolo @whopping pochard
              @whopping-pochard No links. I just swapped to a Duet 3 but I haven't published my parts. As far as the bed leveling has been once I got the offsets right it's been awesome. My biggest thing was bed stability so I redid my bed carriage. Now mine has 3x 331mm on Y (with one in the middle for extra stability and reduce possibility of twisting) and 2x 400mm on the X. With those dimensions the bed mounts are directly in the center of the 2020 channel so less printed parts needed to mount it.
              It's not the current setup but it's my most current picture I have
              whopping pochardundefined 1 Reply Last reply Reply Quote 1
                @dhusolo Looks great!
                • Vetiundefined
                  Veti
                  If you are willing to beta test.
                  https://www.aliexpress.com/item/1005001323175853.html
                  MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                  • MartinNYHCundefined
                    MartinNYHC @Veti
                    @Veti said in My BLV MGN cube build/upgrade saga (ongoing):
                    I just placed my order. Incredible price 🙂
                      whopping pochard
                      Wow, that is indeed amazing! I'm tempted to order one myself, even though I'm not sure how many components I could use from it at this point...
                      • dhusoloundefined
                        dhusolo
                        Word of warning those metal parts are still in the beta phase. It's entirely possible those parts might need revisions. Personally I won't upgrade to the metal parts until Ben and I work out the details of an official triple or even a quad Z axis with independent leveling.
                        • Vetiundefined
                          Veti @dhusolo
                          @dhusolo
                          i would really like to take part in the beta, but i am not on facebook (and i wont get an account)
                          • dhusoloundefined
                            dhusolo
                            You don't need to have Facebook for it and it's not really an "official" beta. The parts have been released to only one specific supplier on Aliexpress. Anyone can order them. There's no signup to get them. You just buy them
                            • Vetiundefined
                              Veti @dhusolo
                              @dhusolo
                              can you answer some questions?
                              where do the endstops on the x carriage go now? the bottom seems to be different and no space to mount the endstop.
                              are the mounting holes on the x carriage compatible with the hemera?
                              does the original hotend cooling fan cover fit?
                              does the original part cooling fan duct fit?
                              • dhusoloundefined
                                dhusolo @Veti
                                @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
                                However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
                                • I_Jediundefined
                                  I_Jedi @MartinNYHC
                                  I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
                                  • Vetiundefined
                                    Veti
                                    the metal parts have now been released.
                                    https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
                                    not sure if i will get them as i like a direct extruder setup, and so far its only bowden
                                    whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
                                      whopping pochard @Veti
                                      @Veti that looks pretty great!
                                      • dhusoloundefined
                                        dhusolo @Veti
                                        @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
                                          MartinNYHC @Veti
                                          @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                                          And I'm currently working on a three axis setup 😉
                                          • Vetiundefined
                                            Veti
                                            Ben just posted a video about blind joints
                                            https://www.youtube.com/watch?v=ueniUWrUcjE
