    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    9.0k
    • whopping pochardundefined
      whopping pochard @JamesM
      @JamesM Sweet, I look forward to seeing the result!
      dhusoloundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo @whopping pochard
        @whopping-pochard No links. I just swapped to a Duet 3 but I haven't published my parts. As far as the bed leveling has been once I got the offsets right it's been awesome. My biggest thing was bed stability so I redid my bed carriage. Now mine has 3x 331mm on Y (with one in the middle for extra stability and reduce possibility of twisting) and 2x 400mm on the X. With those dimensions the bed mounts are directly in the center of the 2020 channel so less printed parts needed to mount it.
        It's not the current setup but it's my most current picture I have
        whopping pochardundefined 1 Reply Last reply Reply Quote 1
          whopping pochard @dhusolo
          @dhusolo Looks great!
          • Vetiundefined
            Veti
            If you are willing to beta test.
            https://www.aliexpress.com/item/1005001323175853.html
            MartinNYHCundefined 1 Reply Last reply Reply Quote 0
            • MartinNYHCundefined
              MartinNYHC @Veti
              @Veti said in My BLV MGN cube build/upgrade saga (ongoing):
              I just placed my order. Incredible price 🙂
                whopping pochard
                Wow, that is indeed amazing! I'm tempted to order one myself, even though I'm not sure how many components I could use from it at this point...
                • dhusoloundefined
                  dhusolo
                  Word of warning those metal parts are still in the beta phase. It's entirely possible those parts might need revisions. Personally I won't upgrade to the metal parts until Ben and I work out the details of an official triple or even a quad Z axis with independent leveling.
                  • Vetiundefined
                    Veti @dhusolo
                    @dhusolo
                    i would really like to take part in the beta, but i am not on facebook (and i wont get an account)
                    • dhusoloundefined
                      dhusolo
                      You don't need to have Facebook for it and it's not really an "official" beta. The parts have been released to only one specific supplier on Aliexpress. Anyone can order them. There's no signup to get them. You just buy them
                      • Vetiundefined
                        Veti @dhusolo
                        @dhusolo
                        can you answer some questions?
                        where do the endstops on the x carriage go now? the bottom seems to be different and no space to mount the endstop.
                        are the mounting holes on the x carriage compatible with the hemera?
                        does the original hotend cooling fan cover fit?
                        does the original part cooling fan duct fit?
                        • dhusoloundefined
                          dhusolo @Veti
                          @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
                          However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
                          • I_Jediundefined
                            I_Jedi @MartinNYHC
                            I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
                            • Vetiundefined
                              Veti
                              the metal parts have now been released.
                              https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
                              not sure if i will get them as i like a direct extruder setup, and so far its only bowden
                              whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
                                whopping pochard @Veti
                                @Veti that looks pretty great!
                                • dhusoloundefined
                                  dhusolo @Veti
                                  @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
                                    MartinNYHC @Veti
                                    @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                                    And I'm currently working on a three axis setup 😉
                                    • Vetiundefined
                                      Veti
                                      Ben just posted a video about blind joints
                                      https://www.youtube.com/watch?v=ueniUWrUcjE
                                        MartinNYHC @Veti
                                        @Veti Yes, I'm very interested but I think I can't wait until it's available. I need my kitchen 🙂
                                        • Vetiundefined
                                          Veti @MartinNYHC
                                          @MartinNYHC
                                          not by ben, but for 1204 there is a metal kit
                                          https://de.aliexpress.com/item/4001277526161.html
                                            MartinNYHC @Veti
                                            @Veti Very nice. Did you try it?
                                            Wondering if there every will be a point in time where a build is finished. Don't think so 😂
