    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    9.1k
    • Vetiundefined
      Veti @dhusolo
      @dhusolo
      i would really like to take part in the beta, but i am not on facebook (and i wont get an account)
      • dhusoloundefined
        dhusolo
        You don't need to have Facebook for it and it's not really an "official" beta. The parts have been released to only one specific supplier on Aliexpress. Anyone can order them. There's no signup to get them. You just buy them
        • Vetiundefined
          Veti @dhusolo
          @dhusolo
          can you answer some questions?
          where do the endstops on the x carriage go now? the bottom seems to be different and no space to mount the endstop.
          are the mounting holes on the x carriage compatible with the hemera?
          does the original hotend cooling fan cover fit?
          does the original part cooling fan duct fit?
          dhusoloundefined 1 Reply Last reply Reply Quote 0
          • dhusoloundefined
            dhusolo @Veti
            @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
            However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
            • I_Jediundefined
              I_Jedi @MartinNYHC
              I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
              • Vetiundefined
                Veti
                the metal parts have now been released.
                https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
                not sure if i will get them as i like a direct extruder setup, and so far its only bowden
                whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
                • whopping pochardundefined
                  whopping pochard @Veti
                  @Veti that looks pretty great!
                  • dhusoloundefined
                    dhusolo @Veti
                    @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
                    • MartinNYHCundefined
                      MartinNYHC @Veti
                      @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                      And I'm currently working on a three axis setup 😉
                      • Vetiundefined
                        Veti
                        Ben just posted a video about blind joints
                        https://www.youtube.com/watch?v=ueniUWrUcjE
                        MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                          MartinNYHC @Veti
                          @Veti Yes, I'm very interested but I think I can't wait until it's available. I need my kitchen 🙂
                          • Vetiundefined
                            Veti @MartinNYHC
                            @MartinNYHC
                            not by ben, but for 1204 there is a metal kit
                            https://de.aliexpress.com/item/4001277526161.html
                              MartinNYHC @Veti
                              @Veti Very nice. Did you try it?
                              Wondering if there every will be a point in time where a build is finished. Don't think so 😂
                              • Vetiundefined
                                Veti @MartinNYHC
                                @MartinNYHC
                                no i made my own 1204 mounting with metal parts.
                                  whopping pochard
                                  Very cool! Love to see the ballscrews.
                                  Looking forward to seeing the finished product!
                                  • Vetiundefined
                                    Veti
                                    the bed is rock solid and does not move under pressure.
                                      MartinNYHC
                                      @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
                                      • Vetiundefined
                                        Veti @MartinNYHC
                                        @MartinNYHC
                                        4x 8mm linear rods (had them from an old printer)
                                        8x SK8
                                        https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
                                        4 SCS8LUU (screwed into 2020 profile with m3 t nut)
                                        https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
                                        2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
                                        https://www.aliexpress.com/item/32892098907.html
                                        2 SFU1204
                                        the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
                                        https://www.aliexpress.com/item/4001120210864.html
                                          MartinNYHC
                                          Thanks @Veti
                                          • fcwiltundefined
                                            fcwilt
                                            Simple can work as well.
                                            The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                                            I like seeing the wide variety of solutions to common issues.
