    Smart effector first layer issues
    4.7k
    • Carloundefined
      Carlo @Carlo
      @Carlo
      If they are fine
      Heat bed to 60c 130c hotend home then calibrate Z0.1 see if it goes to that position after calibration.
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @Carlo
        @Carlo
        Not my creation thanks to another user
        macro name Prime nozzle also you can add to your start gcode for pla or change the temps for any filament S70 S220 in slicer
        So home then delta calibrate first, then run the this macro
        G90
        M83
        M207
        T0
        M116
        G29 S1
        M190 S70
        M104 S220
        M109 S220
        ; Draw arc to prime the nozzle between 6PM and 9PM on the bed edge
        G1 X0 Y-175 Z0.25 F6000
        G2 X-175 Y0 I0 J175 E30 F1500
        G1 X-174.52
        G3 X0 Y-174.52 I174.52 J0 E28 F1500
        G1 Z1 E-0.25 F6000
        • Lakemanundefined
          Lakeman
          Measured the spacing on the carriages and on the effector: Effector 64.6mm carriges 64.1mm
          So there is room for improvement..
            droftarts administrators @Lakeman
            @Lakeman On my delta, I've always had issues with mesh calibration. I only use it to check the bed level, then turn it off for printing. When you're doing the delta calibration, is it turned off? Check there's an M561 and G29 S2 at the beginning of bed.g (assuming that's where you delta calibration is), then if you do a mesh calibration afterwards, cancel it before trying to print.
            • Carloundefined
              Carlo @Lakeman
              @Lakeman
              Did you change your belts? or tighten them as adjuster is touching the pulley plate so no more adjustment available mine have 15mm ish between them
              • Lakemanundefined
                Lakeman
                It seems to be making the same mistake with or without mesh, I just tried a very fine mesh and without after with no succes
                But maybe I have to fix the 0.5 mm in the spacing...
                • Carloundefined
                  Carlo @Lakeman
                  @Lakeman
                  would be good to rule it out .5mm when your talking 0.12 -0.3mm layers?
                  • Lakemanundefined
                    Lakeman
                    I think ruling it out is the best plan, just not entirely sure if it will work if I just scale the printed parts a bit and hopefully end up exactly 0.5mm wider 😛
                    • Lakemanundefined
                      Lakeman
                      I am printing a 0.2mm first layer by the way and I do not know how much effect spacing between the balls has on the height,
                      • Carloundefined
                        Carlo @Lakeman
                        @Lakeman
                        have you got the link to the ones you printed as there are afew and I found these to be best
                        Used with the PCB ball mount supplied with the smart effector
                        anycubic_predator_carriage_SE-PCB_withoutFE.stl
                        • Carloundefined
                          Carlo @Carlo
                          @Carlo
                          Link here for flying extruder version also
                          https://www.thingiverse.com/thing:356764
                          using the pcb supplied guarantees perfect spacing
                          • Lakemanundefined
                            Lakeman
                            Haydn_Carriage_Adapter_Remix_v4.stl
                            This is what I used, I will try the stl file you send me, probebly the safest option to use the pcb's. Your second link goes to a tray, not sure what to do with that 😉
                            Carloundefined 2 Replies Last reply Reply Quote 0
                            • Carloundefined
                              Carlo @Lakeman
                              @Lakeman
                              Make sure that the spacing between each pair of towers is the same at the top, the bottom, and half way between top and bottom from duets website
                              The spacing between the bearings at the top of a pair of rods must be exactly the same as the spacing between the bearings at the bottom
                              • Carloundefined
                                Carlo @Lakeman
                                @Lakeman
                                get the linked version with the flying extruder mounting holes easier to mount the extruder
                                • Lakemanundefined
                                  Lakeman
                                  Thanks, I print those and try again
                                  • Carloundefined
                                    Carlo @Lakeman
                                    @Lakeman
                                    One thing I did change on my bed was the standoffs under it the blue discs if you take 2 off and measure them mine were way way off in size each to each I replaced them with springs but that was after getting my setup sorted
                                    • Carloundefined
                                      Carlo @Carlo
                                      @Carlo
                                      New link no idea why it went to a tray
                                      https://www.thingiverse.com/thing:3567642
                                      • Lakemanundefined
                                        Lakeman
                                        Hello, I tried printing the parts yesterday (small parts usually work after some fiddling) and halfway a belt snapt, thats what you get after to much tensioning for more precision... But anyway, I changed all the belts to new ones with a metal core which I had as spare, tensioned the same and printed the small parts again, which went easy somehow. So I tried to print the big part to be sure. Perfect first layer without a mesh, just after a quick delta calibration.
                                        No idea what was wrong with the other belts, could not find any problems on them and the were installed correcly and tried several amounts of tension over the last year.
                                        I will install the new mounts for the arms anyway to remove the 0.5mm, but they do not couse the first layer issue.
                                        Thanks a lot for al the help, It was a hardware foult afterall, altough I am still not sure what was wrong with them.
                                        The support on the forum is great, really thanks a lot.
                                        Should I close the thread somehow to show it is fixed?
                                        • Vetiundefined
                                          Veti @Lakeman
                                          @Lakeman said in Smart effector first layer issues:
                                          thats a big no no. steel belts do not like sharp turns like you have in a delta. they will break and cause problems.
                                          here are some good belts
                                          https://de.aliexpress.com/item/32853559638.html
                                          • Lakemanundefined
                                            Lakeman
                                            Interesting, I had to replace a belt on the original predator and I thing it has more then a 1000 hours with a metal belt in 1 tower... No problems
