    My corexy hbot configurations and build pictures
    Example setups and prints
    2.1k
    • tracarundefined
      tracar
      i really did not know much about the sys folder and its contents , but a week later i got my printer working with a bit of help from a couple of smart moderators here : thanks
      this is a work in progress, if you see any thing i need to pay attention to please let me know , i can test it out and see if it fits my build. and i will update as necessary .
      Printer is a custom made Hbot. 500mm x 500mm x 950mm
      dual independent Z axis steppers with each their own endstop
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      capable of homing the z axis (Z and U) separately and independently
      to get the bed fairly level
      it also can use G32 bed leveling to get it really level.
      my X/Y endstops are in the rear left corner
      my z endstops are on the left and the right sides of the x axis in the middle of the y axis.
      X0 and Y0 are in the front left corner
      im using external closed loop stepper drivers
      x and y are (5) and (6), z and U are (7) and (8), in the config.g M584
      my endstops are 24v proximity sensors, with schottky bat43 diodes
      my config files are below and are the only files i changed, all else are original
      G31 X0 Y0 Z0 P25
      M550 P"Duet2" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P5 S0 T5 R1 ; physical drive x axis goes forwards
      M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
      M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
      M569 P8 S1 T5 R1 ; physical drive U axis goes forwards
      M569 P3 S1 ; physical drive Extruder goes forwards
      M584 X6 Y5 Z7:8 U8 E3 P3 ; set drive mapping
      M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
      M350 X16 Y16 Z16 U16 E16 I1 ; configure micro stepping with interpolation
      M92 X200.00 Y200.00 Z800.00 U800.00 E138.23 ; set steps per mm
      M566 X200.00 Y200.00 Z12.00 U12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X25000.00 Y25000.00 Z1000.00 U1000.00 E2400.00 ; set maximum speeds (mm/min)
      M201 X400.00 Y400.00 Z20.00 U20.00 E400.00 ; set accelerations (mm/s^2)
      M906 X300 Y300 Z300 U300 E800 I30 ; set motor currents (mA)
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1 ; set axis minima
      M208 X440 Y535 Z900 U900 S0 ; set axis maxima
      M574 X1 Y2 Z1 U1 S0 ; set active high endstops 1= minimum 2=maximum, S1 = normally closed and S2 = normally open
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z4.247 ; set Z probe trigger value, offset and trigger height
      M557 X70:400 Y180:500 S100 ; define mesh grid x70:400 starts at 50, ends at 400 SXX moves by what its set to between points
      ;M575 P1 S1 B57600 ; enable support for PanelDue
      ; deployprobe.g
      ;deployprobe.g
      M280 P7 S10 ;deploy bltouch
      ;retractprobe.g
      M280 P7 S90 I1 ; retract BLtouch pin
      ; homeall.g
      ; called to home all axes
      M280 P7 S160
      G91 ; relative positioning
      G1 S2 H2 Z5 F800 ; lift Z relative to current position
      G1 H1 X-445 Y540 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-445 ; home X axis
      G1 H1 Y540 ; home Y axis
      G1 X5 Y-5 F800 ; go back a few mm
      G1 H1 X-445 F200 ; move slowly to X axis endstop (second pass)
      G1 H1 Y540 F200 ; move slowly to Y axis endstop (second pass)
      M584 Z7 U8 P4 ; split Z motor control to Z and U
      G1 S1 H1 Z-900 U-900 F400 ; home Z and U axis
      G1 Z5 U5 F200 ; go back a few mm
      G1 H1 Z-900 U-900 F100 ; move slowly to Z and U axis endstop (second pass)
      M584 Z7:8 P3 ; back to combined axes and hidden U
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      G1 Z10 F800 ; lift Z relative to current position
      ; homex.g
      ; called to home the X axis
      M280 P7 S160 ; Alarm Release and Push-Pin UP
      G1 H2 Z5 F800 ; lift Z relative to current position
      G1 H1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F800 ; go back a few mm
      G1 H1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F800 ; lower Z again
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y540 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y-5 F800 ; go back a few mm
      G1 H1 Y540 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z-900 U-900 F100 ; move slowly to Z axis endstop (second pass)
      G1 Z5 F400 ; lift Z relative to current position
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 02 2020 19:54:07
      M280 P7 S90
      M561 ; clear all bed compensation
      G28 ; home all axis
      G1 X220 Y330 Z25 ; move probe to center of the bed
      G30 ; set Z0 position with the probe
      G1 Z25 ; return to 25mm height
      G30 P0 X440 Y330 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X0 Y330 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M280 P7 S90
      i hope by leaving this as an example for others it can be a good visual aide.
      pictures of pin connections and printer layout to come.
      • Vetiundefined
        Veti
        @tracar said in My corexy hbot configurations and build pictures:
        your thermistor settings are not configured properly. 4138 is the default and most likely wrong for your thermistors.
        tracarundefined 1 Reply Last reply Reply Quote 0
        • tracarundefined
          tracar @Veti
          @Veti
          this i had no clue i needed to fix. what do i need to do to fix this ?
          • Vetiundefined
            Veti @tracar
            @tracar
            find out what thermistors you have and look in the spec sheet and find the beta value.
            • tracarundefined
              tracar @Veti
              @Veti
              ahhhh , i had to configer these in marlin as a 6 on the old prusa
              i think that was a 100k
              • Vetiundefined
                Veti
                nearly all thermistors used today are 100k
                marlin 6 is
                • 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
                not a good starting point.
                where did you buy the thermistors?
                • tracarundefined
                  tracar @Veti
                  @Veti
                  think it came with the prusa, i3 clone from folgertech a few tears ago!!
                  • Vetiundefined
                    Veti
                    the prusa i3 clone comes with a mk8 hotend. are you still using that?
                    • tracarundefined
                      tracar @Veti
                      @Veti has been parted out long ago.
                      after reading up on this thermister stuff, i see what you are trying to get after.
                      i dont think i have the info, but can find out by using a temp probe . Or just ordering some from amazon that the values are known.
                      • Vetiundefined
                        Veti
                        if you can establish the resistance at certain temperatures, then that would be perfect.
                        measure the resistance at something like 25, 120 and 240.
                        then use the https://configtool.reprapfirmware.org/Heaters click on the Beta value, select custom and enter those values.
                        It will calculate B and C for you. That would be more accurate as thermistors have variations that can lead to +/- 10 C.
                        Failing to do that you can buy a thermistor.
                        Preferable a Semitec 104-GT2.
                        I personally use a PT1000 (no daughter board necessary) for hotend and bed.
                        • tracarundefined
                          tracar
                          @Veti said in My corexy hbot configurations and build pictures:
                          i understand, even with my current setup, i notice, its always overshooting the temp around 10 degrees, but then adjusts it to where it needs to be.
                          • Vetiundefined
                            Veti @tracar
                            @tracar
                            that is an indication that you need to adjust the pid tuning.
                            see
                            https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                            If during initial heating the temperature undershoots the target, reduce the A parameter. If it overshoots the target, increase the A parameter. Try increasing/decreasing it by 5% or 10%.
                            • tracarundefined
                              tracar
                              so 3724.2 would be a good starting point
                              • tracarundefined
                                tracar @Veti
                                what about
                                M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
                                M303 ; report the auto-tune status or last result
                                • Vetiundefined
                                  Veti
                                  yes and save those values in your config.g
                                  • tracarundefined
                                    tracar
                                    the results of the M303 H1 S240
                                    M307 H1 was used to get this info after the M303 H1 S240:
                                    Heater 1 model: gain 869.9, time constant 308.4, dead time 3.1, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
                                    Computed PID parameters for setpoint change: P20.7, I0.672, D44.3
                                    Computed PID parameters for load change: P20.
                                    does it auto save this info? or how and where do i add this
                                    • mrehorstdmdundefined
                                      mrehorstdmd
                                      Is it H-bot or corexy? AFAIK, it can't be both...
                                      tracarundefined 2 Replies Last reply Reply Quote 0
                                      • tracarundefined
                                        tracar @mrehorstdmd
                                        @mrehorstdmd hbot
                                        • tracarundefined
                                          tracar @mrehorstdmd
                                          @mrehorstdmd
                                          so after auto tuning and creating this :
                                          M307 H1 A869.9 C308.4 D3.1 V24.2 B0
                                          where in the config.g do i place it?
                                          what is the B0? for
                                          • Vetiundefined
                                            Veti @tracar
                                            after the
                                            M950 H1
                                            command
                                            B0 Disables Bang Bang and enables PID mode.
