My corexy hbot configurations and build pictures
Example setups and prints
2.1k
    Veti
    @tracar said in My corexy hbot configurations and build pictures:
    your thermistor settings are not configured properly. 4138 is the default and most likely wrong for your thermistors.
    undefined 1 Reply Last reply 29 Aug 2020, 06:51 Reply Quote 0
      tracar @Veti
      @Veti
      this i had no clue i needed to fix. what do i need to do to fix this ?
      undefined 1 Reply Last reply 29 Aug 2020, 06:55 Reply Quote 0
        Veti @tracar
        @tracar
        find out what thermistors you have and look in the spec sheet and find the beta value.
        undefined 1 Reply Last reply 29 Aug 2020, 06:58 Reply Quote 0
          tracar @Veti
          @Veti
          ahhhh , i had to configer these in marlin as a 6 on the old prusa
          i think that was a 100k
            Veti
            nearly all thermistors used today are 100k
            marlin 6 is
            • 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
            not a good starting point.
            where did you buy the thermistors?
            undefined 1 Reply Last reply 29 Aug 2020, 07:11 Reply Quote 0
              tracar @Veti
              @Veti
              think it came with the prusa, i3 clone from folgertech a few tears ago!!
                Veti
                the prusa i3 clone comes with a mk8 hotend. are you still using that?
                undefined 1 Reply Last reply 29 Aug 2020, 13:28 Reply Quote 0
                  tracar @Veti
                  @Veti has been parted out long ago.
                  after reading up on this thermister stuff, i see what you are trying to get after.
                  i dont think i have the info, but can find out by using a temp probe . Or just ordering some from amazon that the values are known.
                    Veti
                    if you can establish the resistance at certain temperatures, then that would be perfect.
                    measure the resistance at something like 25, 120 and 240.
                    then use the https://configtool.reprapfirmware.org/Heaters click on the Beta value, select custom and enter those values.
                    It will calculate B and C for you. That would be more accurate as thermistors have variations that can lead to +/- 10 C.
                    Failing to do that you can buy a thermistor.
                    Preferable a Semitec 104-GT2.
                    I personally use a PT1000 (no daughter board necessary) for hotend and bed.
                      tracar
                      @Veti said in My corexy hbot configurations and build pictures:
                      i understand, even with my current setup, i notice, its always overshooting the temp around 10 degrees, but then adjusts it to where it needs to be.
                      undefined 1 Reply Last reply 29 Aug 2020, 15:02 Reply Quote 0
                        Veti @tracar
                        @tracar
                        that is an indication that you need to adjust the pid tuning.
                        see
                        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                        If during initial heating the temperature undershoots the target, reduce the A parameter. If it overshoots the target, increase the A parameter. Try increasing/decreasing it by 5% or 10%.
                        undefined 1 Reply Last reply 29 Aug 2020, 15:16 Reply Quote 0
                          tracar
                          so 3724.2 would be a good starting point
                            tracar @Veti
                            what about
                            M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
                            M303 ; report the auto-tune status or last result
                              Veti
                              yes and save those values in your config.g
                                tracar
                                the results of the M303 H1 S240
                                M307 H1 was used to get this info after the M303 H1 S240:
                                Heater 1 model: gain 869.9, time constant 308.4, dead time 3.1, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
                                Computed PID parameters for setpoint change: P20.7, I0.672, D44.3
                                Computed PID parameters for load change: P20.
                                does it auto save this info? or how and where do i add this
                                  mrehorstdmd
                                  Is it H-bot or corexy? AFAIK, it can't be both...
                                  undefined 2 Replies Last reply 29 Aug 2020, 15:37 Reply Quote 0
                                    tracar @mrehorstdmd
                                    @mrehorstdmd hbot
                                      tracar @mrehorstdmd
                                      @mrehorstdmd
                                      so after auto tuning and creating this :
                                      M307 H1 A869.9 C308.4 D3.1 V24.2 B0
                                      where in the config.g do i place it?
                                      what is the B0? for
                                      undefined 1 Reply Last reply 29 Aug 2020, 15:45 Reply Quote 0
                                        Veti @tracar
                                        after the
                                        M950 H1
                                        command
                                        B0 Disables Bang Bang and enables PID mode.
                                        undefined 1 Reply Last reply 29 Aug 2020, 15:48 Reply Quote 0
                                          tracar @Veti
                                          M950 H1
                                          im still on firmware version 2.03
                                          undefined 2 Replies Last reply 29 Aug 2020, 15:50 Reply Quote 0
                                          11 out of 32
