    Triple z axis bed tramming
    1.5k
      Please post your config.g and bed.g files, and confirm exactly what you are doing to try to accomplish "bed tramming".
      • mrenz999undefined
        mrenz999
        I am trying to get the 3 z motors to level themselves.
        ; bed.g
        ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
        ;M561 ; clear any bed transform
        ;G29 ; probe the bed and enable compensation
        G28 ; home
        ;M401 ; deploy Z probe
        G30 P0 X20 Y70 Z-99999 ; probe near an adjusting screw
        G30 P1 X20 Y400 Z-99999 ; probe near an adjusting screw
        G30 P2 X400 Y200 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
        ;M402 ; retract probe
        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
        M550 P"Duet 3" ; set printer name
        M669 K1 ; select CoreXY mode
        M569 P0.0 S0 ; physical drive 0.0 goes forwards
        M569 P0.2 S0 ; physical drive 0.2 goes forwards
        M569 P0.3 S0
        M569 P0.4 S1
        M569 P0.5 S1 ; physical drive 0.3 goes forwards
        M584 X0.0 Y0.1 Z0.2:3:4 E0.5 ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M203 X20000 Y20000 Z600 E3600.00 ; set maximum speeds (mm/min)
        M201 X3000 Y3000 Z100 E5000 ; set accelerations (mm/s^2)
        M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M671 X20:20:400 Y70:360:200 S0.5 ; leadscrews at rear left, front middle and rear right
        M208 X-20 Y-15 Z0 S1 ; set axis minima
        M208 X430 Y425 Z465 S0 ; set axis maxima
        M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
        M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
        ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
        ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
        ;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
        M557 X20:430 Y0:410 S20 ; define mesh grid
        Z-Probe
        M558 P8 C"^io7.out"
        G31 P500 X-20 Y0 Z7.7
        M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
        M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
        M143 H1 S300
        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
        M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
        M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
        M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
        M501
          @mrenz999 said in Triple z axis bed tramming:
          Is this the actual locations of your lead screws? Are they inside the printable area?
          Do you use your probe for homing Z in your homeall.g?
          I assume you've seen this? https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          • mrenz999undefined
            mrenz999
            @Phaedrux They are not inside the printable area. They are outside it by about 60mm to the outside.
              That's not what your M671 indicates.
              mrenz999undefined 1 Reply Last reply Reply Quote 0
              • mrenz999undefined
                mrenz999 @Phaedrux
                @Phaedrux M671 X-60:-60:485 Y110:365:240 S0.5 ; leadscrews at rear left, front middle and rear right
                Ok fixed that. It moves all the way back to the y endstop and it stops No error or anything. Just stops.
                  Are you using a right handed coordinate system with 0,0 in the front left? -X moves to the left, +X moves to the right, -Y moves to the front, +Y moves to the back?
                  Are the lead screw positions in your M671 relative to that 0,0 point in the front left?
                  Are your probe offsets correct relative to the nozzle? G31 P500 X-20 Y0 Z7.7
                  Are the points in the M671 in the same order as the motors are defined in M584?
                  Are the points defined in your bed.g trying to place the probe as close to the lead screws as possible?
                  • mrenz999undefined
                    mrenz999 @Phaedrux
                    @Phaedrux X is back right. Y is back. So Left for +Y and Forward for +X. Yes offsets are relative to the nozzle. The points in the bed.g are exactly where they are relative to the endstop 0's. The M671 motors are in the correct order.
                      Phaedrux Moderator @mrenz999
                      That's definitely a non standard arrangement and I can't tell with metal gymnastics alone if that's going to produce mirrored prints or not, or if it's just an odd rotation of a right hand coordinate system.
                      Can you post a photo of the printer looking down at it and explain where the endstops are?
                      Having a non-standard coordinate system is going to make for headaches like this.
                      Here's an example of a right handed setup.
                      left_right_hand.gif dbot axis.png Cartesian-coordinate-system.png Bed Area.png
                      • mrenz999undefined
                        mrenz999 @Phaedrux
                        @Phaedrux My other printer is the same from factory. The one I am working on now is a BLV MGN Cube. Not having issues with the prints other than getting the bed leveling handled. The front of the printer is open. So everything goes to the far right for 0,0.
                          The 0,0 point doesn't have to be where the endstops are located. The right handed coordinate system assumes you're looking at the printer from the front. It's fine to have the 0,0 position in a different position provided it's both axis that are flipped. If only one is flipped you'd get mirrored prints.
                          • mrenz999undefined
                            mrenz999 @Phaedrux
                            @Phaedrux Gotcha. So instead of front left 0,0 is back right on this one and the Zonestar M9Z3 that I have. The CR10sPro that I have is like what you are saying. 0,0 is front left.
                              Yeah back right is fine as long as you're orienting that in your brain. It's still a right handed coordinate system, it's just rotated 180 degrees.
                              The front left thing is mostly to match the way slicers and CAD software orient the origin and it helps to have a standardized way of talking about it with other people so that we're all on the same page. Instructions usually assume that coordinate system for instance.
                              The important thing is that where ever you've defined the 0,0 position, if you were standing at the printer such that that point is at the front left, then the motor movements should match what I originally described. -x to the left, etc.
                              Is that the case?
                              • mrenz999undefined
                                mrenz999 @Phaedrux
                                @Phaedrux yep. That is the case.
                                  Alright, so now with that in mind, lead screw positions in M671 correct, M208 axis limits correct, probe offset correct, motor order matches.. that leaves us with the points in bed.g and my original question.
                                  A good way to check would be to move your print head such that the probe is as close as possible to the first lead screw, then use that current head position as the point to probe, repeat for the other lead screws.
                                  • mrenz999undefined
                                    mrenz999 @Phaedrux
                                    @Phaedrux those are exact. I couldn’t probe them.
                                      Can you post your homeall?
                                      When you run G32 does it home correctly and then move to the first point?
                                      Does the probe work otherwise?
                                      mrenz999undefined 2 Replies Last reply Reply Quote 0
                                      • mrenz999undefined
                                        mrenz999 @Phaedrux
                                        @Phaedrux
                                        ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
                                        G91 ; relative positioning
                                        G1 H1 X-450 Y-450 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H1 X-450
                                        G1 H1 Y-450
                                        G1 H1 X-450 Y-450 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                        G1 X250 Y210 F9000 ; go to first bed probe point and home Z
                                        G30 ; probe the bed
                                        G1 H1 Z-465 F360
                                        G90
                                        G92 Z5
                                        Probe works. G32 command only goes near the 0,0 and then just stops.
                                        • mrenz999undefined
                                          mrenz999 @Phaedrux
                                          @Phaedrux found part of the issue. The z motors were not mapped correctly in the bed.g. Fixed that. Now it homes all. Then goes back the home x and y and tries to probe which is off the bed.
                                            G30 ; probe the bed
                                            G1 H1 Z-465 F360
                                            G90
                                            G92 Z5
                                            This is a problem. You're first using the probe to find Z0, but then you're also homing using an endstop, and then forcing the Z position to Z5. Remove those last 3 lines to maintain the probed Z position, otherwise you're bound to have an offset from where it thinks the bed is and where the bed actually is. Use the probe to home Z. That's what it's meant for.
                                            As I said before, jog your print head such that the probe is where you want it to probe, the XY coordinates of the head at that point is what you want to use in the bed.g points.
