    Improving mesh bed compensation with M558 HX
    1.9k
    • peter247undefined
      peter247 @illy
      @sykb said in Improving mesh bed compensation with M558 HX:
      M558 P5 X0 Y0 Z1 I0 H5 A3 F120 T6000 S0.01 ; Set Z probe type
      Doesn't the H mean , after it as sensed the bed ( eg on the bltouch it's pushed the pin up ) , the height the probe/nozzle will raise .
      I've set my H to 2mm , with a H of 30mm it will raise by 30mm after each hit.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      • Vetiundefined
        Veti @illy
        M557 X67:270 Y75:265 S101.5:90 ; Define mesh grid
        depending on the quality of your bed that might not be enough. Try S10
        RRF 2.02.
        Please update to at least 2.0.5.1
        also post a picture of the final mesh bed
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @Veti
          @Veti
          You would know if S was too low , because you would get a error message saying so.
          • peter247undefined
            peter247 @illy
            @sykb
            Are you using a bltouch to home / mesh level / bed compensation ?
            • Vetiundefined
              Veti
              then try S15
              • illyundefined
                illy
                @Veti
                @peter247 I'm using probe to home Z
                peter247undefined deonholtundefined 2 Replies Last reply Reply Quote 0
                • peter247undefined
                  peter247 @illy
                  @sykb
                  Is your off set correct ?
                  G31 P600 X32.7 Y35 Z0.5 ; Set Z probe trigger
                  So this say your probe is 32.7mm to the right of the nozzle X axis and your probe is 35mm to the back of the nozzle Y axis , Correct ?
                  • Vetiundefined
                    Veti
                    @Veti said in Improving mesh bed compensation with M558 HX:
                    then try S15
                    you have not changed this. there are only 9 points in your mesh.
                      Phaedrux Moderator @illy
                      M564 S0 H0
                      G1 X33.5 Y27 Z15 F6000 ; go to first bed probe point and home Z
                      M564 S0 H1
                      You shouldn't have to be using M564 at all. I would suggest removing those. If something isn't working without them you've got other problems to solve.
                      What type of probe is this?
                      Increasing your grid density will give you a better idea of what the bed surface is actually like. When it's so sparse like you have there could be large variations in between the points that are not captured in the mesh and can't be compensated for.
                      You can try adding M558 A parameter to increase the repeatability of the probe.
                      • deonholtundefined
                        deonholt @illy
                        @sykb what settings do you use to tell the probing to only probe 9 points? I would like to have that as well. Mine is currently probing about 42 points and I have a glass bed.
                          Phaedrux Moderator @deonholt
                          @deonholt said in Improving mesh bed compensation with M558 HX:
                          In M557 you use either S or P parameters to tell it the spacing of the points, or the number of points. So if you want 9 points, use P3:3 which will probe a 3x3 grid.
                          deonholtundefined 2 Replies Last reply Reply Quote 1
                          • deonholtundefined
                            deonholt @Phaedrux
                            @Phaedrux said in Improving mesh bed compensation with M558 HX:
                            Great! Thank you so much.
                            • deonholtundefined
                              deonholt @Phaedrux
                              I tried this but it gave some error:
                              M557 P3:3 ; define mesh grid 3x3
                              I think I' missing something to tell it to save it. (I'm learning.)
                              fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                fcwilt @deonholt
                                You still have to include the X and Y min/max values.
                                  @deonholt When in doubt check the gcode wiki.
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
                                  https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Define_the_mesh_size_and_spacing
                                  • peter247undefined
                                    peter247 @Phaedrux
                                    @Phaedrux
                                    Not seen sykb on , But I can see lots of faults .
                                    Can't tell what printer he has , but to me the off sets or wrong , the homing files are wrong , and he is not probing the centre of the bed.
                                    • illyundefined
                                      illy
                                      Thank you everyone for your response and sorry for my slow response. I'll try all your suggests.
                                      @peter247 yes, the off set is correct. I can show you a picture.
                                      @Veti yes, I have not changed it. I just wanted to show you how it looks with 9 points. I'll update the firmware first to 2.05.1 and try with S10 or S15, as you suggested.
                                      @Phaedrux I've tried adding M558 A parameter in 2.02 and didn't get a better result. I'll try it again but in 2.05.1.
                                      I'm using an inductive sensor as probe. You can also see it on the picture above.
                                      @deonholt yes, you also have to define the X and Y min and max values, as @fcwilt said.
                                      • illyundefined
                                        illy
                                        @Veti I've tried S30 (49 points) in RRF 2.05.1 and this is the result:
                                        And then I did a test print but got the same result as before.
                                        @Phaedrux I've changed the code to S30 in the M557 command and to H10 A6 S0.01 in the M558 command, but there is still no improvement. I've also tried removing the M564 commands in the homing files, as you suggested, but after that I could not home Z at all and got an error report saying: Error: G0/G1: insufficient axes homed.
                                        And this the height map with the changed parameter:
                                        • peter247undefined
                                          peter247 @illy
                                          @sykb
                                          Your homing could be simpler :-
                                          This is mine !!!
                                          ; homeall.g
                                          ; called to home all axes
                                          G91               ; relative positioning
                                          G1 H2 Z5 F6000    ; lift Z relative to current position
                                          G1 H1 X 355 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 H1 Y 355 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                                          G90               ; absolute positioning
                                          G1 X220 Y175 F4000 ; Move probe to middle of bed 350 x 350
                                          G30
                                          I only do a single pass homing on X and Y , don't care if it is a fraction out.
                                          What is your printing area ? , and can the probe go to the edges of the printing area without hitting the sides or hitting the limits ?
                                          • illyundefined
                                            illy
                                            @peter247 250x210x325 mm. Yes, the probe can go outwards without hitting anything.
