    Stall detection with 2 motors
    858
    • noisettetbouundefined
      noisettetbou @Phaedrux
      @Phaedrux
      Thanks for the calculation. I've confused the units of torque.
      I've tried speeds up to 300 mm/s and differents current between 20 and 100% but nothing.
        When you say the motors rotate in opposite directions, what do you mean?
        Can you post a photo of the printer?
        noisettetbouundefined 1 Reply Last reply Reply Quote 0
          @Phaedrux
          That's a link to a photo of Y axis :
          https://photos.app.goo.gl/oeFLBnE1iaKtcJMNA
          The motors are biaxials and synchonysed by a shaft
          • oliofundefined
            oliof @noisettetbou
            @noisettetbou possibly crazy talk but could you disable one stepper for homing only? As they're synchronized by a shaft you should be able to live with that.
              noisettetbou @oliof
              @oliof
              It's a good idea. I've tried and it is the same problem.
              So 2 motors on same driver and the series wiring aren't the source of the problem.
              I'm trying to invert drivers.
                noisettetbou @noisettetbou
                I've tried to invert driver with X and always the problem. As if my Y motors aren't compatibles with the stall detection.
                Is it possible ? Crazy, no ?
                • oliofundefined
                  oliof
                  Oh two steppers on a single driver? I can see how that will be bothersome/impossible. Maybe if you drive each motor independently ...
                    noisettetbou @oliof
                    @oliof
                    It's no a problem if current is respected. I use two motors on same driver in X axis and no problem. And I done as you said for trying, so there is only one motor right now, and no good stall detection...
                      I think an endstop switch might be in your future.
                        @Phaedrux
                        I think too... 😢 but I would like to understand
                          Have you used the motor EMF calculator at reprapfirmware.org to verify that you have enough VIN voltage to drive 2 motors in series without loss of torque?
                          • oliofundefined
                            oliof
                            Difference between X and Y is often that Y moves more mass and there for needs better tuning. But I agree that an endstop likely will give you reliable results faster.
                              noisettetbou @dc42
                              @dc42 @Phaedrux @oliof
                              dc42 has reason. My voltage is enough for each axis but limit for all axis in the same time.
                              So i've decided to installing a Duex5.
