RepRapFirmware 3.2 planned improvements
99
6.3k
    arhi @dc42
    Support G5
    Does this involve maybe also G15 / G16 ? (I don't know if any slicer know how to use them, I only used them when I wrote code manually on my old milling machine)
      DaveA
      Maybe I'm just more confused than normal but I don't understand the versioning system.
      Is 3.1.0, soon to be 3.1.1, not the latest stable release? If so, why is the next version going to be 3.02?
      ? undefined 2 Replies Last reply 17 May 2020, 14:36 Reply Quote 0
        A Former User @DaveA
        @DaveA understandable confusion; the current 3.1.0 was supposed to be 3.01 until about the day it was released, presumably what would be 3.02 will be 3.2.0.
          dc42 administrators @DaveA
          @DaveA said in RepRapFirmware 3.02 planned improvements:
          The next stable release, not counting patch releases such as 3.1.1, will now be called be 3.2.0. I have changed the title of this thread.
            garyd9
            I'm hoping requests for 3.2 will also be entertained: Extend M409 to allow multiple keys to be requested.
            For example, assume something embedded that wants to determine how much time is probably left in a print (using the simulated time) would need to request job.file.simulatedTime as well as job.duration. Having to request the entire 'job' key to 3 levels deep can result in a large buffer. Having to make 2 M409 requests doubles the time needed to get the information.
            On the other hand, if M409 supported multiple keys, the request and response could be simplified:
            M409 K"job.duration","job.file.simulatedTime"
            (For discussion, I've also started a new thread: https://forum.duet3d.com/topic/16450/m409-multiple-keys-at-once)
              oliof
              Regarding line item 48: According to Marlin docs, UBL does support loading an existing mesh and applying 3-point or grid based tilt adjustment.
                jay_s_uk
                Is the spreadsheet in the first post still being maintained?
                Does the equivalent exist for 3.3?
                undefined 1 Reply Last reply 14 Sept 2020, 15:45 Reply Quote 0
                  dc42 administrators @jay_s_uk
                  @jay_s_uk said in RepRapFirmware 3.2 planned improvements:
                  Many of the items that were planned for 3.2 have been deferred to 3.3. You can see what's implemented in 3.2 in the RRF3 whatsnew file.
                  ? 1 Reply Last reply 14 Sept 2020, 20:12 Reply Quote 0
                    A Former User @dc42
                    @dc42 said in RepRapFirmware 3.2 planned improvements:
                    why the continual push back ?
                      It's hardly a continual push back. The 3.2 release includes nearly 40 improvements, not counting bug fixes.
                      ? 1 Reply Last reply 14 Sept 2020, 20:19 Reply Quote 0
                        A Former User @dc42
                        let me re-phrase then : why the push back ?
                        undefined 1 Reply Last reply 14 Sept 2020, 20:21 Reply Quote 0
                          Phaedrux Moderator @A Former User
                          @CaLviNx Market conditions?
                          ? 1 Reply Last reply 14 Sept 2020, 20:24 Reply Quote 0
                            A Former User @Phaedrux
                            @Phaedrux said in RepRapFirmware 3.2 planned improvements:
                            which means what exactly ?
                            I think there is more than a few users waiting on functionality fixes (which in my opinion should have be a priority) which would allow the correct use of pre-purchased equipment to be used/maintained properly/easily
                              In short, there is a global shortage of 2660 drivers used in the duet 2 (turns out they are used in ventilators) and the Maestro is discontinued, so work on the mini5+ was pulled forward.
                              3.2 beta is in the works, so things are coming. We all appreciate the patience.
                              ? 1 Reply Last reply 14 Sept 2020, 21:18 Reply Quote 1
                                jens55
                                Could we gat a URL that lists the likely changes for 3.2?
                                I know DC42 said "You can see what's implemented in 3.2 in the RRF3 whatsnew file." but I have not been able to find that file .... 😞
                                oozeBotundefined 1 Reply Last reply 14 Sept 2020, 20:43 Reply Quote 0
                                • oozeBotundefined
                                  oozeBot @jens55
                                  @jens55
                                  https://github.com/Duet3D/RepRapFirmware/commit/ed1bb2a1924fea6308ee024d4142ed243d6358cb
                                  0 dc42 committed 13 Sept 2020, 10:04 to Duet3D/RepRapFirmware
                                  Update WHATS_NEW_RRF3.md
                                    deckingman
                                    Two questions.
                                    From the 3.2. planned improvements link it says - quote
                                    "[Duet 3 expansion and tool boards] Increased performance, in particular the maximum step rate is higher than before"
                                    I'm a bit fed up of asking the question because I've asked it multiple time over the last 12 months and never yet had an answer but I'll try one more time so here goes.....
                                    Question 1. What is the maximum step pulse frequency for expansion and tool boards now, and what will it be?
                                    There remains a long list of limitations for expansion boards which I have been trying to use for over a year. https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                                    Some of the fixes have been pushed back to being planned for release 3.3.0 now while some don't have any planned release number assigned to them. So .....
                                    Question 2. What is the likely release date for 3.3.0 and for those items on the list of limitations which are not planned to be fixed in 3.3.0, is there any plan to fix them and if so when, or will they be permanent limitations?
                                    wilrikerundefined 1 Reply Last reply 15 Sept 2020, 08:47 Reply Quote 1
                                      do people have a lot of choice ?
                                      undefined 1 Reply Last reply 14 Sept 2020, 21:34 Reply Quote 0
                                        A Former User
                                        Looking at the link
                                        Firmware Limitations
                                        I notice it is always very quickly updated with the firmware revision number in which you advise they will be rectified
                                        The cynical among us would say maybe its time to remove the number to save yourselves the extra work of having to update that number on such a regular basis...
                                          @CaLviNx said in RepRapFirmware 3.2 planned improvements:
                                          ¯\_(ツ)_/¯
