unusual/unnerving noises + error codes
if i try and home all i get the same weird shaking on the X and Y axis the Z doesnt move and i eventually get this error message
G28
Error: G0/G1: insufficient axes homed -
i would suggest looking at your wiring for the x axis motor then.
My guess is you have some of the cables mixed up.
I would suggest reading this https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors -
@jay_s_uk So after following the link i can confirm that all motors are connected correctly now and sound alot better. Now to the end stops + Probe.
Obviously at the moment i still cant home the axis (X and Y) because the end stops seem to not be working. Ive done some reading and found that M574 give a status, which is below. However when putting the gcode in it send a message saying 'Response too long see console'
m574
Endstop configuration:
X: low end motor stall (any motor)
Y: low end motor stall (any motor)
Z: low end Z probeany ideas?
can you post your latest config.g?
That response seems to indicate that you're trying to use stall detection rather than an actual endstop -
@PR1OR said in unusual/unnerving noises + error codes:
And if you go to the console do you see the result?
How do you have the endstops wired? The two wires from the endstops should be connected to the outer two pins of the board connector. Doesn't really matter which wire goes where.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37#s119
 @Phaedrux said in unusual/unnerving noises + error codes:
so that was the result :s
Below is a picture of the wiring, ive been using dupont wire until ive made sure they are wired correctly. but from what you are saying the seem to be fine. The LEDs are on (green, i read somewhere they should be red but i assume this was an old/new board) when the the endstop switch isnt pressed. When it is it turns off. So i found from wiring diagram that the LEDs didnt correspond to the plugs like it does in the diagram
just had a thought and checked the axis limits as the ender 3 pro has a bigger print area. i have now updated that but still having issues
could it be something to do with the gcodes for the end stops?
Like the changing S to H?
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
M574 Z1 S2 ; set endstops controlled by probe -
M574 X1 Y1 S3 ; set endstops controlled by motor stall detectionS3 is stall detection. Try S1.
@Phaedrux updated to S1 and i got this
G28
Error: Failed to enable endstops -
however i played with it a little and S2 works but it only moves each axis by a couple of mm before stoping
but it does say its homed which i think is getting somewhere
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopTry that instead
It looks like you had stall detection for homing selected in the configurator so it didn't have any endstop switches defined.
From what i seen in the video im wondering are you sure the z stepper is wired correctly
It sounds like one of the steppers is not paired properly y moves then x .... does it start the noise before it hits the x stop?? If so you wont know the z is correct untill it hits the x stop if the shaking starts then ...when you hit the xstop i would say the z stepper is causing the problem with the strpper fighting itself... i noticed that the x gantry didnt start down. It might be the video. Or just meill watch it again
What i do is start homming then manualy trip the limit to see if it in fact work.. just cause the led goes out doent mean the g code responded
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopPerfect thank you!! this has worked!! i can now home my X and Y axis
is there anything for the Z probe though?
i get this as a return when homing all
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failed -
So it was as Phaedrux had said above the code wasnt correct. Once id checked/sorted the wiring out it was only happening when both X and Y got to the end stop
If you're still having problems with the probe please post your config.g.
@Phaedrux
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 15 2020 08:55:40 GMT+0100 (British Summer Time); General preferences
M550 P"Duet 2 Wifi" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X400 Y400 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
;M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
;M574 Z1 S2 ; set endstops controlled by probe; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop; Z-Probe
M307 H64 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H2.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X-31 Y0 Z0.6 ; set Z probe trigger value, offset and trigger height
M557 X20:215 Y20:215 S20 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 1
M106 P2 S1 I0 F500 H0:1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
ok we'll have to convert more of your config.g over to use RRF3 syntax.
If you send M98 P"config.g" what errors do you get?
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: in file macro line 44: M307: parameter 'H' too high
Error: Missing Z probe pin name(s)
Error: Invalid Z probe index
Error: M305 has been replaced by M308 and M950 in RepRapFirmware 3
Error: Heater 0 does not exist
Error: Heater 1 does not exist
Error: Fan number 0 not found
Error: Fan number 1 not found
Error: Fan number 2 not found
