How to change bed heater fault parameters?
1.1k
    Phantom329
    I just finished a new printer and am working on configuring the firmware. I try to set my bed to 60C but it faults saying that it is not rising quickly enough. I have a 300^2mm and it does start to heat before faulting so I expect Duet is assuming a smaller bed. How can I change the fault value?
    Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
      PID tune the heaters to give the firmware an idea of their performance characteristics.
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
      M303 H0 S60 to tune
      M500 to save it
      M501 at the end of config.g to load saved values at boot
      undefined 2 Replies Last reply 25 Sept 2020, 02:14 Reply Quote 0
        Phantom329 @Phaedrux
        @Phaedrux Thanks I'll do that
          @Phaedrux So I did the auto tune but now my bed makes a really loud noise from the PWM. I enabled bang-bang with M307 H0 B1 but it gave a warning. It was still warm at the time I sent the command, idk if that has anything to do with it. I'm re-tuning it now.
          Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 244C
            Tune the bed from room temp for best results.
            Best not to use bang-bang at all.
            That warning is letting you know how hot the model predicts the bed could reach if it failed in a powered on state with no control.
            Can you share an example of the really loud noise? Where is it coming from?
            Also please share your config.g and the results of M122 and M98 P"config.g" so we can get a better idea of what's going on.
            undefined 1 Reply Last reply 26 Sept 2020, 13:58 Reply Quote 0
              jay_s_uk
              You can also adjust the WM frequency using 'Q' in the M950 gcode.
              Some MOSFETs etc can be noisy at certain frequencies
              undefined 1 Reply Last reply 25 Sept 2020, 07:07 Reply Quote 1
                I was hoping he had one of those beds that picks up radio stations...
                  BoA @jay_s_uk
                  @jay_s_uk I always thought MOSFETs are noisy only when magic smoke escapes from them 😉
                    jay_s_uk
                    i have an external mosfet on one of my printers (18A 12v heated bed) and it sometimes screams like its being murdered for no reason
                    undefined 1 Reply Last reply 25 Sept 2020, 07:31 Reply Quote 0
                      BoA @jay_s_uk
                      @jay_s_uk Is there any inductor around mosfet? I would rather expect wires to actually make noises not the mosfet. That is weird.
                        @Phaedrux bang-bang did solve the problem of the noise. I could tell the noise was related to be bed because it was only makeing it when the bed was hovering at the set temp, which is when PWM would be used. The noise comes from the actual bed itself and not Duet which is pretty odd. Here is a short vid (turn up the sound) https://drive.google.com/file/d/1iEl3BVpyKjvRqt8IHO-OAdeKiDSx-9hg/view?usp=sharing
                        This is the bed I have https://www.aliexpress.com/i/4000311964727.html?spm=2114.12057483.0.0.14b5133eaIrF4D
                        Also here is the output of M122 and M98
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-9T6BU-FG3S8-6J9F2-3SN6L-9ULVG
                        Used output buffers: 7 of 24 (7 max)
                        Static ram: 27980
                        Dynamic ram: 93912 of which 108 recycled
                        Exception stack ram used: 264
                        Never used ram: 8808
                        Tasks: NETWORK(blocked,636) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:02:27 ago, cause: power up
                        Last software reset at 2020-09-24 07:40, reason: User, spinning module GCodes, available RAM 8504 bytes (slot 1)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                        Error status: 0
                        MCU temperature: min 13.6, current 22.2, max 22.4
                        Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                        Date/time: 2020-09-26 09:56:09
                        Cache data hit count 244309824
                        Slowest loop: 1.42ms; fastest: 0.13ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 9.8ms, write time 0.0ms, max retries 0
                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                        === AuxDDARing ===
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is assembling a command in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 15.24ms; fastest: 0.00ms
                        Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is active
                        WiFi firmware version 1.21RC2
                        WiFi MAC address bc:dd:c2:08:78:0b
                        WiFi Vcc 3.39, reset reason Unknown
                        WiFi flash size 4194304, free heap 15240
                        WiFi IP address 192.168.1.245
                        WiFi signal strength -63dBm, reconnections 0, sleep mode modem
                        Socket states: 4 4 0 0 0 0 0 0
                        M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                        Error: Pin 'fan1' is not free
                        Error: Fan number 2 not found
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 201C
                          BoA
                          Looks like magnetic bed.
                          Current going through the heater wires + magnets = essentially speaker 😄
                          I remember reading some posts that prusa actually implemented some fancy method of switching that eliminates that.
                          https://blog.prusaprinters.org/dev-diary-2-how-we-made-the-heatbed-silent_30946/
                          undefined 1 Reply Last reply 26 Sept 2020, 16:44 Reply Quote 0
                            Phantom329 @BoA
                            @BoA It sounds like they were hearing a click or chirp sound. Its hard to hear in my video but I hear a constant tone which most likely correlates directly to the switching frequency. I can hear it change frequency as it tries to keep the bed temp steady.
                            undefined 1 Reply Last reply 26 Sept 2020, 17:02 Reply Quote 0
                              BoA @Phantom329
                              @Phantom329 It is the same sound (I had prusa with their board). And frequency is constant in PWM.
                                You can alter the PWM frequency for the bed in the M950 command that creates the heater.
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                                Post your config.g. it looks like you have a fan misconfigured as well.
                                undefined 1 Reply Last reply 26 Sept 2020, 23:57 Reply Quote 0
                                  @Phaedrux I fixed the fan, just had an extra one defined. Here is config.g and config-override.g. What should I set the PWM to? Btw thanks for helping me, I've learned a ton from troubleshooting this.
                                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 24 2020 07:39:49 GMT-0400 (Eastern Daylight Time)
                                  M550 P"Phantom Cube" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P2 S0 ; physical drive 2 goes backwards
                                  M92 X200.00 Y200.00 Z400.00 E418.00 ; set steps per mm
                                  M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X18000.00 Y18000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)
                                  M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X350 Y310 Z310 S0 ; set axis maxima
                                  M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                                  M558 P1 C"zprobe.in" H20 F240 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                  G31 P25 X0 Y-15 Z13.5 ; set Z probe trigger value, offset and trigger height
                                  M557 X40:300 Y20:280 S65 ; define mesh grid
                                  M143 H0 S100 ; set temperature limit for heater 0 to 100C
                                  T0 ; select first tool
                                  ; config-override.g file generated in response to M500 at 2020-09-24 23:36
                                  ; Heater model parameters
                                  M307 H0 A176.4 C339.5 D7.2 S1.00 V23.8 B1
                                  M307 H1 A297.7 C97.1 D6.5 S1.00 V24.0 B0
                                  ; Workplace coordinates
                                  G10 L2 P1 X0.00 Y0.00 Z0.00
                                  G10 L2 P2 X0.00 Y0.00 Z0.00
                                  G10 L2 P3 X0.00 Y0.00 Z0.00
                                  G10 L2 P4 X0.00 Y0.00 Z0.00
                                  G10 L2 P5 X0.00 Y0.00 Z0.00
                                  G10 L2 P6 X0.00 Y0.00 Z0.00
                                  G10 L2 P7 X0.00 Y0.00 Z0.00
                                  G10 L2 P8 X0.00 Y0.00 Z0.00
                                  G10 L2 P9 X0.00 Y0.00 Z0.00
                                    @Phantom329 said in How to change bed heater fault parameters?:
                                    Try adding Q10 to the end of that. Then you can experiment with different values to see how it changes. You can actually do that in real time by sending M950 H0 Q# in the gcode console while the bed heater is running. Once you find a frequency that works well you can change the config.g to make it take effect at startup.
                                    undefined 1 Reply Last reply 27 Sept 2020, 17:37 Reply Quote 0
                                      @Phaedrux I tried changing the Hz from 1 to 1000 but no difference at all. I took a better video and also noted that the bed actually vibrates. It starts at around 55C and sometimes momentarily stops when above 60C (set at 60C) but immediately stops when I turn off the bed heat.
                                      https://drive.google.com/file/d/1k6DX-6bAaiALDYou7UZGFRZKjEFxABVc/view?usp=sharing
                                      8 out of 18
