Another Layer Shifting Issue
623
    Turbo
    I know there's a million posts on this topic already, but nothing has worked. In theory, there shouldn't be any reason for shifting. Belts have proper tension, motors getting proper current, motor is of quality brand (moons MS17HA2P4100 (1A rated current) (0.9 deg) x and y), jerk and accel settings are modest. I cant figure out why its skipping cause it never happens when I'm watching. I literally stared at a print going triple speed for an hour, as a stress test, and it printed without issue. I tried the same print at standard speeds, went to go eat for maybe 20 mins, and BOOM, layer shift. Its making me crazy. the motors get warm, but nowhere near concerning. Any thoughts on what i can do? Its primarily occurring on the x axis, but sometimes they y axis likes to join in on making me suffer. Where it shifts is random, with no indicator that a shift will occur.
    Setting posted below:
    M569 P2 S0 ; physical drive 2 goes backwards
    M92 X160.00 Y160.00 Z400.00 E390.00 ; set steps per mm (Currently 2x for 0.9 Steppers on X & Y)
    M566 X700.00 Y700.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z1200.00 E3000.00 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X700 Y700 Z700 E855 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
      Veti
      what board are you running?
      are you running in stealthchop2?
      undefined 1 Reply Last reply 6 Oct 2020, 05:06 Reply Quote 0
        Turbo @Veti
        @Veti duet 2 wifi. stealthchop enabled I thought stealthchop was just interpol. no idea if its enabled
        Spreadcycle is enabled
        10/5/2020, 10:10:29 PM m569 P3
        Drive 3 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknown
        10/5/2020, 10:10:27 PM m569 P2
        Drive 2 runs in reverse, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknown
        10/5/2020, 10:10:25 PM m569 P1
        Drive 1 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknown
        10/5/2020, 10:10:16 PM m569 P
        Drive 0 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknown
          Veti
          what kind of print is it?
          i had problems with some pla prints where the edges were curling up on overhangs.
          When the nozzle went across it, i got layer shifts.
            Turbo
            containers for a resistor box. simple squares with a divider in the middle. No curling to be seen.
              jay_s_uk
              just out of curiosity, what motors do you have? your currents seem a little low
              undefined 1 Reply Last reply 6 Oct 2020, 07:01 Reply Quote 0
                Turbo
                This post is deleted!
                  Turbo @jay_s_uk
                  @jay_s_uk original motor part is in og post
                  undefined 1 Reply Last reply 6 Oct 2020, 07:11 Reply Quote 0
                    luc
                    Hi .... it also happened to me in a previous printer, I also changed the power supply only to discover that it was a false contact in the motor cables. I changed them directly even if measuring them several times with the tester (at that moment) they were always ok.
                    Now, I don't know if this could also be your cause but if you think it appropriate you could try it.
                    undefined 1 Reply Last reply 6 Oct 2020, 07:09 Reply Quote 0
                      Turbo @luc
                      @luc false contact? I've tested continuity and everything is fine.Is a false contact something different?
                      undefined 1 Reply Last reply 6 Oct 2020, 07:19 Reply Quote 0
                        jay_s_uk @Turbo
                        @Turbo yep. missed that.
                        You could get away increasing the current by another 100ma to 800 for both X and Y.
                        Rule of thumb is about 80-85% of max current, so at the moment, you are running under that
                          luc @Turbo
                          @Turbo Listen ... I don't speak English well but I presented you my experience of my case where I wrote that I also did the continuity and isolation tests several times and they were always ok but your case is perhaps different.
                          undefined 1 Reply Last reply 6 Oct 2020, 17:12 Reply Quote 0
                            Turbo @luc
                            @luc Rereading that i see what you mean. I'll look into replacing the cables when i can get some connectors.
                              Bad bearing occasionally sticking? Wiring loom occasionally catching?
                              I'd say you should watch a print the whole way through to try and catch it in action to see what you can see.
                              undefined 1 Reply Last reply 7 Oct 2020, 16:53 Reply Quote 0
                                theruttmeister
                                Is it direct drive with no guide tube for the filament?
                                Isolate, substitute, verify.
                                undefined 1 Reply Last reply 7 Oct 2020, 16:51 Reply Quote 0
                                  Turbo @theruttmeister
                                  @theruttmeister it is direct drive with a guide tube
                                    Turbo @Phaedrux
                                    @Phaedrux no obvious friction occurring in the rods/bearings, they're also barely a few weeks old from mcmaster so i don't think they're bad. Swapped them just in case. Wiring loom is organized with cable chains, so no chance of that happening. Ive watched 3 1hr prints at 200% speed now with nothing happening. it really just hates me.
                                    5 out of 17
