Another Layer Shifting Issue
623
    Turbo
    containers for a resistor box. simple squares with a divider in the middle. No curling to be seen.
      jay_s_uk
      just out of curiosity, what motors do you have? your currents seem a little low
      undefined 1 Reply Last reply 6 Oct 2020, 07:01 Reply Quote 0
        Turbo
        This post is deleted!
          Turbo @jay_s_uk
          @jay_s_uk original motor part is in og post
          undefined 1 Reply Last reply 6 Oct 2020, 07:11 Reply Quote 0
            luc
            Hi .... it also happened to me in a previous printer, I also changed the power supply only to discover that it was a false contact in the motor cables. I changed them directly even if measuring them several times with the tester (at that moment) they were always ok.
            Now, I don't know if this could also be your cause but if you think it appropriate you could try it.
            undefined 1 Reply Last reply 6 Oct 2020, 07:09 Reply Quote 0
              Turbo @luc
              @luc false contact? I've tested continuity and everything is fine.Is a false contact something different?
              undefined 1 Reply Last reply 6 Oct 2020, 07:19 Reply Quote 0
                jay_s_uk @Turbo
                @Turbo yep. missed that.
                You could get away increasing the current by another 100ma to 800 for both X and Y.
                Rule of thumb is about 80-85% of max current, so at the moment, you are running under that
                  luc @Turbo
                  @Turbo Listen ... I don't speak English well but I presented you my experience of my case where I wrote that I also did the continuity and isolation tests several times and they were always ok but your case is perhaps different.
                  undefined 1 Reply Last reply 6 Oct 2020, 17:12 Reply Quote 0
                    Turbo @luc
                    @luc Rereading that i see what you mean. I'll look into replacing the cables when i can get some connectors.
                      Bad bearing occasionally sticking? Wiring loom occasionally catching?
                      I'd say you should watch a print the whole way through to try and catch it in action to see what you can see.
                      undefined 1 Reply Last reply 7 Oct 2020, 16:53 Reply Quote 0
                        theruttmeister
                        Is it direct drive with no guide tube for the filament?
                        Isolate, substitute, verify.
                        undefined 1 Reply Last reply 7 Oct 2020, 16:51 Reply Quote 0
                          Turbo @theruttmeister
                          @theruttmeister it is direct drive with a guide tube
                            Turbo @Phaedrux
                            @Phaedrux no obvious friction occurring in the rods/bearings, they're also barely a few weeks old from mcmaster so i don't think they're bad. Swapped them just in case. Wiring loom is organized with cable chains, so no chance of that happening. Ive watched 3 1hr prints at 200% speed now with nothing happening. it really just hates me.
                            14 out of 17
