    New firmware bundle 3.2beta2
    Beta Firmware
    21
    49
    2.7k
    • GrodanBundefined
      GrodanB @dc42
      @dc42 said in New firmware bundle 3.2beta2:
      @GrodanB said in New firmware bundle 3.2beta2:
      Why?
      And just for my curiosity when does it affect the extrusion?
      So that adjusting the extrusion factor doesn't affect the retract or reprime length, or filament loading/unloading. The extrusion factor affects moves with simultaneous XY motion and extrusion.
      Ahh, ok I see... This could explain my improved print quality on my start and stops in RRF3.2...
      But that makes calibration harder then.
      Would it be possible to have some sort of "force/apply compensation" feature to use in the calibration?
      (I guess no slicer will use this...) Because I would like to make sure I applied the correct calibration.
      My workflow for a new filament is to do this controlled extrusion, check the error, enter the compensation, verify that the compensation is correct... if not start over until correct amount is extruded.
      For now I need to either use e-steps (so I can verify but then I guess I get back my start stop issues) or hope that I did not miscalculate and blindly use the value. I think I'll use the value blindly even if I'll risk that not seeing any mistake until the part is done.
      achrnundefined 1 Reply Last reply Reply Quote 0
      • GrodanBundefined
        GrodanB @dc42
        The bed temp reaches 85 and when the heater PT element reports 223.8 (reading the documentation this is the expected behaviour that now M701 call is done and M703 shall be run) my printer resets and all temperatures are set to 0 and tool 1 is set to inactive.
        If you can reproduce that, please run M122 immediately after the uncommanded reset and post the result here.
        Easy to reproduce but M122 seems to do nothing... Or I do something wrong...
        But I there is a failure message I previously missed... may be a hint at least.
        update... seemed I was to quick... resend M122 gave this:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet WiFi 1.0 or 1.01 + DueX5
        Board ID: 08DAM-999TL-MQ4SD-6J9F0-3S86T-14A7Y
        Used output buffers: 3 of 24 (24 max)
        Static ram: 24028
        Dynamic ram: 101188 of which 44 recycled
        Exception stack ram used: 264
        Never used ram: 5548
        Tasks: NETWORK(ready,139) HEAT(blocked,308) DUEX(blocked,36) MAIN(running,451) IDLE(ready,19)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:06:14 ago, cause: software
        Last software reset at 2020-10-08 10:07, reason: AssertionFailed, GCodes spinning, available RAM 5196, slot 0
        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN
        Stack: 0000059e 004716a8 00450849 00000008 ffffffff 20000e10 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4
        Error status: 0x04
        MCU temperature: min 22.5, current 23.0, max 23.3
        Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 0, standstill, SG min/max not available
        Driver 1: position 0, standstill, SG min/max not available
        Driver 2: position 0, standstill, SG min/max not available
        Driver 3: position 0, standstill, SG min/max not available
        Driver 4: position 0, standstill, SG min/max not available
        Driver 5: position 0, standstill, SG min/max not available
        Driver 6: position 0, standstill, SG min/max not available
        Driver 7: position 0, standstill, SG min/max not available
        Driver 8: position 0, standstill, SG min/max not available
        Driver 9: position 0, standstill, SG min/max not available
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2020-10-08 10:14:18
        Cache data hit count 620253408
        Slowest loop: 19.32ms; fastest: 0.17ms
        === Storage ===
        Free file entries: 10
        SD card 0 detected, interface speed: 12.0MBytes/sec
        SD card longest read time 1.4ms, write time 6.1ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
        === MainDDARing ===
        === AuxDDARing ===
        Heater 0 is on, I-accum = 0.0
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 201.84ms; fastest: 0.11ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.24beta2-05b1
        WiFi MAC address 5c:cf:7f:2b:e6:9b
        WiFi Vcc 3.31, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25184
        WiFi IP address 192.168.1.15
        WiFi signal strength -47dBm, reconnections 0, sleep mode modem
        Clock register 00002002
        Socket states: 0 4 0 0 0 0 0 0
        === DueX ===
        Read count 0, 0.00 reads/min
        TCundefined 1 Reply Last reply Reply Quote 0
          A Former User
          Is it not an idea to use the Mk1 eyeball while printing a small test piece to allow you to adjust the extrusion factor for that particular material on the fly ?
            T3P3Tony administrators @deckingman
            @deckingman the work on the can support for mini 5+ did not change the functionality on any of the expansion boards.
              A Former User @T3P3Tony
              @T3P3Tony said in New firmware bundle 3.2beta2:
              I think it should read :
              The work on the can support for mini 5+ has not removed any of the current limitations on any of the expansion boards.
              deckingmanundefined 1 Reply Last reply Reply Quote 1
                deckingman @A Former User
                @CaLviNx said in New firmware bundle 3.2beta2:
                Or perhaps the release notes should say
                "Supports Duet 3 Mini version 0.4 prototypes including limited CAN expansion" or "Supports Duet 3 Mini version 0.4 prototypes including CAN expansion (with limitations)." Either statement would be honest IMO.
                • oozeBotundefined
                  oozeBot @Nuramori
                  @Nuramori @dc42 - the homing issues have reappeared this morning on 3.2b2. This is with a Duet3/RPi and a toolboard. Here is the relevant section from my config that has worked without issue until 3.2b2:
                  G1 X130 Y130 F24000			; aligns BLTouch in center of build plate
                  G30	Z-99999				; sets z-height relative to print bed
                  M561					; clear any bed transforms
                  G30 P0 X20 Y150 Z-99999			; probe midway between front and rear belt on left side
                  G30 P1 X280 Y150 Z-99999 S2		; probe midway between front and rear belt on right side
                  Now, on 3.2b2, sometimes it only probes once during G30 Z-99999. Sometimes it doesn't probe at all, then moves to the next G30 and fails. Sometimes, it makes it this far, then goes to X0 Y0 and does a probe there? That isn't even in the code..
                  @dc42 - There is definitely something wrong here. Please tell me how I can assist with testing to provide you better details.. I can also start another thread for the issue.
                  • Stephen6309undefined
                    Stephen6309
                    @dc42 The BLTouch is doing a double tab on homing, like it does on G29 S0. Original BLTouch with a metal pin. It appears to be messing up the G31 offset. I change the offset and nothing changes. Also, when called in a macro: M117 and M118 to http, never displays the message, but it does when being called with M98. I use a macro to set the pla offset.
                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2-beta2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-10-05b2
                    Using a PI 4.
                    For emaple, I changed the offset from 2.5 to 2.8, and the first layer thickness never changes.
                    PLAOffset macro:
                    M118 P3 S"PLAOffset"
                    G31 P500 X0 Y-55 Z2.8 ; Set Z probe trigger value, offset and trigger height; increase to get closer
                    ; homeall.g
                    ; called to home all axes
                    M98 P"/sys/homex.g"
                    M98 P"/sys/homey.g"
                    M98 P"/sys/homez.g"
                    ; homex.g
                    ; called to home the X axis
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 21 2020 16:28:37 GMT-0400 (Eastern Daylight Time)
                    G91 ; relative positioning
                    G1 H1 X-450 F3000 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X5 F6000 ; go back a few mm
                    G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 H2 Z-5 F6000 ; lower Z again
                    G90 ; absolute positioning
                    ; homey.g
                    ; called to home the Y axis
                    G1 H1 Y-350 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 Y5 F6000 ; go back a few mm
                    G1 H1 Y-350 F360 ; move slowly to Y axis endstop once more (second pass)
                    ; homez.g
                    ; called to home the Z axis
                    G1 X200 Y200 F6000 ; go to first probe point
                    • TCundefined
                      TC @GrodanB
                      @GrodanB I have the exact same problem. Seems like the M701 causes a reboot no matter where it is used. Even when selecting a filament in DWC
                      Here is my diagnostics:
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta2 running on Duet Ethernet 1.02 or later + DueX5
                      Board ID: 08DGM-917NK-F2MSW-6JKDG-3S86T-KZ5ND
                      Used output buffers: 1 of 24 (13 max)
                      Static ram: 24028
                      Dynamic ram: 96364 of which 44 recycled
                      Exception stack ram used: 200
                      Never used ram: 10436
                      Tasks: NETWORK(ready,137) HEAT(blocked,308) DUEX(blocked,36) MAIN(running,445) IDLE(ready,19)
                      Owned mutexes:
                      Last reset 00:01:36 ago, cause: software
                      Last software reset at 2020-10-08 18:22, reason: AssertionFailed, GCodes spinning, available RAM 10436, slot 0
                      Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0x20004264 Task MAIN
                      Stack: 0000059e 004716a8 00450849 0000000d ffffffff 20000db0 4d454144 200032a8 ffffffff 00000000 20002eb4 a5a5a5a5 004508cb 200042b0 0045e98c 20007940 0044e14f 200042cc 00446049 2000329c 200042cc 00000001 200042d4 00000000 004460b3 000000c8 200042d4
                      Error status: 0x00
                      MCU temperature: min 34.4, current 35.2, max 35.4
                      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Date/time: 2020-10-08 18:24:23
                      Cache data hit count 187762902
                      Slowest loop: 11.53ms; fastest: 0.17ms
                      === Storage ===
                      SD card longest read time 3.4ms, write time 13.9ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 50.53ms; fastest: 0.02ms
                      Interface state active, link 100Mbps full duplex
                      === DueX ===
                      Read count 1, 0.62 reads/min
                      GrodanBundefined 1 Reply Last reply Reply Quote 0
                      • GrodanBundefined
                        GrodanB @TC
                        @TC
                        Yes, seems like the same assert as I have.
                        That gives me hope that this is possible to recreate at duet3d.
                        @dc42 If you need to run special firmware to get extended diagnosis or if there is a logfile or similar please just tell me and I test it for you. So far the failure rate for this is 100%.
                        Other than this the firmware works rock solid on my Cartesian printer.
                        Another thing, have looked in the setting up documentation and the M221 G-Code reference page. I find no note of the updated/changed behaviour. I guess this is then a minor "bug report" for the documentation.
                        • TCundefined
                          TC @GrodanB
                          @GrodanB Yes and I can confirm it is working in 3.2beta1
                          • Touchthebitumundefined
                            Touchthebitum
                            Hello
                            I just updated my firmware and I get this when I want to upload or modify my config.g file :
                            Operation failed (Reason: Access to the path '/opt/dsf/sd/sys/DuetWiFiServer-1.24beta2.bin' is denied.)
                            Here is the general info :
                            Board: Duet 3 MB6HC (MB6HC)
                            DSF Version: 3.2.0-beta2
                            Firmware: RepRapFirmware for Duet 3 MB6HC 3.2-beta2 (2020-10-05b2)
                            I made update and upgrade on my Raspberry Pi too.
                            Where am I wrong ?
                            Thanks
                            Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
                            BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
                            Touchthebitumundefined 1 Reply Last reply Reply Quote 0
                              For those of you experiencing an unexpected reboot when M701 or M702 is used, there is a binary for Duet WiFi/Ethernet to fix this at https://www.dropbox.com/s/5vhjjz4a28hu33g/Duet2CombinedFirmware.bin?dl=0.
                              OwenDundefined 1 Reply Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @dc42
                                This update has fixed the M701 crashes for me.
                                • achrnundefined
                                  achrn @GrodanB
                                  Isn't it just a case that at your 'check the error' stage, rather than (say) a G1 E100, you need a G1 X100 E100?
                                  • oliofundefined
                                    oliof
                                    On my independent triple axis CoreXY (a v-core pro), since upgrading to 3.2beta2, the second axis is being probed three times when doing fully automated bed leveling (it probed that point only once while on 3.2b1 and earlier). Probing completes successfully.
                                    Electronics is a duet3 v0.6 board with a toolboard and a duet3d mini IR sensor as z probe (connected to the toolboard).
                                    files:
                                    vcp-config.g
                                    vcp-homeall.g
                                    vcp_zzz.g
                                    versions:
                                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2-beta2 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-10-05b2
                                    Board TOOL1LC firmware 3.2beta (2020-09-14b1)
                                      Stephen6309
                                      I've changed to my genuine BLTouch 3.1, that I've been using on my Duet Ethernet w/3.11. The BLTouch 3.1 does not have that double tap.
                                      Looks like the genuine original BLTouch with metal pin doesn't work properly.
                                      Info provided here: https://forum.duet3d.com/post/183881
                                        Touchthebitum @Touchthebitum
                                        @Touchthebitum
                                        Impossible to go back. I can downgrade but I get "busy" message in DWC and sd access is denied.
                                        Is it a known issue or I missed something ?
                                        Here is my diagnostic log :
                                        RepRapFirmware for Duet 3 MB6HC version 3.2-beta2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                        Board ID: 08DJM-956L2-G43S8-6J9FJ-3S86S-983QD
                                        Used output buffers: 1 of 40 (14 max)
                                        Static ram: 157532
                                        Dynamic ram: 135804 of which 44 recycled
                                        Exception stack ram used: 272
                                        Never used ram: 99564
                                        Tasks: Linux(ready,36) HEAT(blocked,296) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,353) TMC(blocked,51) MAIN(running,1127) IDLE(ready,20)
                                        Owned mutexes: HTTP(MAIN)
                                        Last reset 00:07:20 ago, cause: software
                                        Last software reset at 2058-01-24 11:14, reason: HardFault imprec, none spinning, available RAM 187280, slot 2
                                        Software reset code 0x4072 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x0440f803 BFAR 0x00000000 SP 0x20418438 Task MAIN
                                        Stack: 0000004c 204184e4 204186ac 204186c4 20418518 204187ec 00416198 81000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                                        Error status: 0x00
                                        MCU temperature: min 30.5, current 31.0, max 31.3
                                        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                        Driver 0: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
                                        Driver 1: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
                                        Driver 2: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
                                        Driver 3: position 0, standstill, reads 64863, writes 18 timeouts 0, SG min/max 0/0
                                        Driver 4: position 0, standstill, reads 64863, writes 18 timeouts 0, SG min/max 0/0
                                        Driver 5: position 0, standstill, reads 64871, writes 11 timeouts 0, SG min/max 0/0
                                        Date/time: 2020-10-11 12:56:13
                                        Slowest loop: 147.69ms; fastest: 0.22ms
                                        === Storage ===
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Segments left: 0
                                        HTTP* is ready with "M122" in state(s) 0
                                        SBC is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        === CAN ===
                                        Messages sent 1729, send timeouts 1729, longest wait 0ms for type 0, free CAN buffers 48
                                        === SBC interface ===
                                        State: 0, failed transfers: 1
                                        Last transfer: 19ms ago
                                        RX/TX seq numbers: 13846/13847
                                        SPI underruns 0, overruns 0
                                        Number of disconnects: 0
                                        Buffer RX/TX: 0/0-0
                                        === Duet Control Server ===
                                        Duet Control Server v3.2.0-beta2
                                        Code buffer space: 4096
                                        Full transfers per second: 31.95
                                          Phaedrux Moderator @Touchthebitum
                                          @Touchthebitum How are you trying to downgrade?
                                            Touchthebitum @Phaedrux
                                            @Phaedrux
                                            I upload the previous firmware...
