    Bed mesh compensation not applied to all the tools
    1.4k
      Phaedrux Moderator @duetlover
      @sylvain said in Bed mesh compensation not applied to all the tools:
      As you can see I use G91 / G90 afteer T3 selection.
      Could this explain that after this bed compensation doesn't work ?
      I don't think so.
      I do think maybe there is a command to disable compensation in your tool changes, but I can't see the files to check.
      • duetloverundefined
        duetlover
        Here it is.
        Board: Duet 2 Ethernet (2Ethernet)
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
        tpost1.g tpost0.g tfree3.g tfree2.g tfree1.g tfree0.g tpre3.g tpre2.g tpre1.g tpre0.g tpost3.g tpost2.g
        I made severall tests again.
        I can see bed levelling on T2 (the fist tool used).
        When switched to T3, no bed levelling.
        Thanks !
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
          Do you get any errors if you send M98 P"config.g"?
          • sebkritikelundefined
            sebkritikel @duetlover
            Here it is.
            tpost1.g tpost0.g tfree3.g tfree2.g tfree1.g tfree0.g config.g tpre3.g tpre2.g tpre1.g tpre0.g tpost3.g tpost2.g
            Thanks !
            G29 S1 is commented out (turned off) in your tpost3.g (and your tpost2.g you just uploaded!!!) whereas it is not commented out (turned on) in your tpost1.g.
            In addition to that, like @Phaedrux said, some of your tfree files have G29 S2 still active. Going from T0 to some other tool, you are disabling mesh compensation via tfree0.g, but then because it is G29 S1 is commented out in T2 and T3 it wont turn back on.
            Large(ish?) IDEX - 6HC, 1HCL
            Stratasys Dimension 1200es to 6HC Conversion
              Tfree1 tfree0 still has
              ;mesh levelling off
              G29 S2
              And you've commented out all the G29 S1 to turn them on. Just remove all references to G29 in your tool files.
                duetlover
                @Phaedrux said in Bed mesh compensation not applied to all the tools:
                M98 P"config.g"?
                => no error
                I will test with all G29 commented.
                But as I told you I only use T2 and T3.
                How could G29 in T0 or T1 could affect my print ?
                All the more the print starts with T2 and bed levelling is active for this first tool.
                Keep you updated !
                  M98 P"config.g"?
                  => no error
                  Keep you updated !
                  How high (in millimeters) is the object you are printing when the printer changes from T2 to T3?
                    duetlover
                    The change to T3 is done at about 3 mm.
                    I also thought at M376 H15
                    but the bed levlling is stopped before.
                    Thanks
                      You have T-1 in your config to deselect all tools, so perhaps that's when the tfree files are getting called.
                      Removing all references should tell us.
                        duetlover
                        T-1 and ALL G29 commented => same results... 😞
                        If it could help, here is the part of gcode file when T3 is selected for the first time :
                        G1 X199.790 Y94.848 E0.0216
                        G1 X197.752 Y92.810 E0.1258
                        G1 X198.247 Y92.810 E0.0216
                        G1 X199.790 Y94.353 E0.0952
                        G1 X199.790 Y93.858 E0.0216
                        G1 X198.742 Y92.810 E0.0647
                        G1 X199.237 Y92.810 E0.0216
                        G1 X199.790 Y93.363 E0.0341
                        G1 X199.790 Y92.868 E0.0216
                        G1 X199.732 Y92.810 E0.0036
                        G1 E-4.0000 F4200
                        ; layer 7, Z = 2.167
                        T3
                        G91
                        G1 Z5 F600
                        G90
                        G1 X200.600 Y107.666
                        ; feature outer perimeter
                        ; tool H0.250 W0.010
                        G1 Z6.667 F120
                        G1 X99.205 Y91.805 F120
                        G1 Z1.917 F120
                        G1 X200.795 Y91.805 E0.1056 F300
                        G1 X200.795 Y108.195 E0.0170
                        G1 X99.205 Y108.195 E0.1056
                        G1 X99.205 Y91.805 E0.0170
                        When T2 is selected again after T3 bed levelling is running again.
                          G1 E-4.0000 F4200
                          T3
                          G91
                          G1 Z5 F600
                          G90
                          G1 Z6.667 F120
                          G1 Z1.917 F120
                          I do not know, I'm sorry. It looks OK to me.
                          Just conjecture, but G10 and the taper command couldn't possibly be causing this right? I see no reason for that to be the case...
                          G10 P3 X-0.5	Y36.7	Z-35.26				; T3
                          I recognize Z-35.26 is necessary.
                          @sylvain could you try commenting out M376 H15?
                            Phaedrux Moderator @sebkritikel
                            @sebkritikel said in Bed mesh compensation not applied to all the tools:
                            Worth a shot.
                            Also, are you sure you've got G29 S1 enabled somewhere else now? Should be in the slicer start gcode or start.g at least.
                              duetlover
                              Commenting M376 solved the issue !
                              Thanks !
                                Thanks !
                                Very interesting! @Phaedrux if this is truly the cause, I wouldn't say this is expected behavior correct? Expected behavior would be G10 tool offsets having no impacts on mesh taper?
                                  @sebkritikel I'll check with DC42 as I really have no idea.
                                  sebkritikelundefined 1 Reply Last reply Reply Quote 1
                                    sebkritikel @Phaedrux
                                    For what its worth, I just tested it on my machine and can confirm G10 Z offsets will interact with with taper values set via M376, similar to what slyvain is seeing.
                                    Duet2 Wifi+Duex5
                                    3.2-beta2 (2020-10-05b2)
                                    Set M376 H15
                                    With T0, with no offsets in G10, moved over built plate at Z=6mm. Could see ballscrews moving for compensation
                                    Put an artificial offset on T1 (IDEX) of G10 P1 Y.22 U.00 5 Z-20
                                    Selected T1, bed moved down to account for Z-20 offset. Still read 6mm.
                                    Moved T1 over build plate - no ballscrew/stepper movement for bed compensation.
                                    Homed all axes, reset T1 offsets to G10 P1 Y.22 U.00 5 Z.3
                                    Moved T1 over build plate (at Z=6mm), could see ballscrews/stepper moving for compensation.
                                      duetlover
                                      Happy to have contribute to find a bug 😉
                                        sebkritikel @sebkritikel
                                        Duet2 Wifi+Duex5
                                        Set M376 H15
                                        @dc42 this comment should summarize the thread, while tested on an IDEX machine, should be easy to verify on a toolchanger.
                                        • dcw259undefined
                                          dcw259
                                          I've had the same problem with mesh bed compensation and tapering.
                                          Tool offsets were around 6.5mm for T0 and T1 and 3mm for T2 and T3
                                          With M376 H5 (taper off until 5mm) I barely noticed any z adjustments on T2 and T3 and absolutely none on the first two tools.
                                          To confirm, I tried M376 H15 and can see z moving cleanly on all tools.
                                          As it seems, tools offsets is not a part of the calculation behind M376
                                          Hardware: Duet3 MB6HC + 2x Duet 3 EXP3HC
                                          Firmware: MB RRF3.1.1 + EXP RRF3.1.0
                                            @sylvain @sebkritikel @dcw259, I confirm that mesh compensation taper does not work properly when the tool has a Z offset.
                                            I can squeeze a fix into RRF 3.2 stable, but the fix needs to be tested first. Are any of you running RRF 3.2RC2 and would be open to running an internal build that includes a proposed fix?
