    Creating a new IDEX 3D Printer with Duet 2 WIFI
    My Duet controlled machine
    4.5k
    • DE-TechArtundefined
      DE-TechArt @sebkritikel
      @sebkritikel No, I was unable to run a full bed probing. I don't quite understand how I can run this. for a start, I think that four points will be enough -95 and 95
      sebkritikelundefined 1 Reply Last reply Reply Quote 0
        DE-TechArt @sergei
        @sergei I think on my example you and others can create your own project.
        • sebkritikelundefined
          sebkritikel @DE-TechArt
          @DE-TechArt said in Creating a new IDEX 3D Printer with Duet 2 WIFI:
          I think you will want a greater fidelity... but lets start with something that divides nicely into your bounds... For reference, on my IDEX machine I have "M557 X-220:160 Y-200:200 S20:25 ; define mesh grid" and many other times you will see folks with spacing of 20-25mm.
          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
          Simply put - what happens when you type and send G29 in the console? Can also click here:
          Have you corrected the additional Y-axis comments DC42 brought up? You have your X-axis, which is the T0 (left I assume) hotend. You have the U-axis, which is the T1 (right I assume) hotend. You have one Y-axis - that is driven by only one motor correct? Should be "M584 X0 Y1 U3 Z2 E5:6 ; set drive mapping " correct?
          Happy to help!
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
          DE-TechArtundefined 1 Reply Last reply Reply Quote 0
            @sebkritikel Thank you for the tips. as I said, without your help I cannot cope.
            G31 P700 X0 Y0 U0 Z0
            M557 X-98:98 Y-98:98 S20:25 ; Define mesh grid
            I changed the G-code and now the mesh bed probes are working. all that remains is to adjust the speed and acceleration.
            The next problem is getting the printer to work in parallel and mirrored.
            it is not clear to me where in cura should I indicate T1 T2 and T3?
            Just in the starter G-Code? I think it's not very convenient to edit the parameters of the 3d printer every time
              DE-TechArt
              I also changed set drive mapping
              and added at the end Homeall.g and homez.g
              G29 S1
                For standard dual extrusion, this is how I use Cura
                The start GCODE is very important for me. Cura is not a perfect software, and has some quirks. Before the start GCODE, Cura actually calls the tool for the start of the print, see below - T0 is called before my start script
                In my homeall.g, I actually need to deselect the current tool using T-1 P0, otherwise if I'm printing with T1, T2, etc, Cura tricks my machine into trying to Z probe with the wrong tool(s). I added the ;Ext_Sel line into my start GCODE, and then use the Post Processing Plugin to manually select the proper starting tool.
                For specifically duplication and mirror modes, I have a SECOND post processing script to change all mentions of T0 or T1 to T2. This one is silly, but I do it instead of creating another tool/extruder in Cura. I slice it for T0 (typically), do my first search and replace script to change ;Ext_Sel to T2 (to specify the tool after my G28 in start GCODE), and then a second search and replace script to change T0 anywhere else to T2 (specifically the FIRST tool mention created by Cura before the start gcode is made, the section in blue from the notepad file a few pictures up).
                If not using T2, it must say ";T2" instead of "T2" - or T3 for mirror, etc.
                I think there are better ways of doing some of that... unfortunately the Duet board and firmware is much smarter and more configurable than Cura....
                  sebkritikel
                  I think a better option is to create a third "extruder" in Cura through the "Machine Settings" window, and selecting a sufficient X or Y nozzle offset to split the bed in half or so, leaving space for the Duet firmware to map the movement to the U-axis.
                  I have not tried this yet, but I think this would be much easier. An important note - my T2 offset is different than yours, I did not offset the X axis, and instead only offset the U axis. This suggestion with Cura might not work with how you have offset the X and U axis - more investigation needed.
                  M563 P2 D0:1 H1:2 X0:3						; tool 2 uses both extruders and hot end heaters, maps X to both X and U
                  G10 P2 X0 Y0 U-263.5 S0 R0    				; set tool offsets and temperatures for tool 2
                  Strike that, I hadn't actually selected T2 (Extruder 3) as the print tool. By adding Extruder 3 it split the buildplate for T0/T1, not just T2. When you select T2, it actually makes the entire print surface unusable - wtf Cura.
                    sebkritikel
                    Getting closer, but still not quite right. Some funky stuff going on in the background w/Cura.
                    With "Origin at Center" the previously entered X offset applies starting at the origin... but only if tools T0 and T1 (extruder 1 and 2 in cura) are disabled. Whatever you enter - such as 100mm, is for only one direction, therefore the overall width would be 2x (200 mm for example).
                    However, any combination of having T0, T1 active, with T2 both active as well disabled, results in the right hand side available build surface being truncated by whatever the X offset is set to (loss of 100mm. If the offset was -100mm, it happens to the left side of the bed, as expected). I don't understand the reasoning why... If T2 is disabled, why is the offset being applied? Is Cura really assuming that T2 will always travel during printing (a single gantry/print head), and thus must limit that offset amount? I think that is shortsighted... but perhaps the alternative is as well. I just tried expanding the machine X total print width from 450mm to 650mm in Cura (double the X offset in T2) which solves the T0, T1, T2 combo issue, but then that totally messes up the T2 only print area. Stumped for now........
                      @sebkritikel This is a rather complicated method. I do not think that a beginner and an ordinary consumer can handle it.
                      And why are you against bcn3d Cura? it was designed specifically for IDEX printer
                        DE-TechArt @dc42
                        @dc42 the developers of Duer3D and RepRap were able to create such complex software and nevertheless do not have detailed instructions for setting up an IDEX printer, the process of slicing, extruder selection, initial and final GCode, Slicer selection and much more are not described. Perhaps I missed something and such an instance exists?
                          DE-TechArt @dc42
                          @dc42 I also have one question. I am going to use Duet equipment in my invention and further replicate it, can I get support from the software developers in my printer settings?
                            droftarts administrators @DE-TechArt
                            Have you read https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian#Section_Configuring_tools and the section on tool changing after? If so, what do you think is missing?
                            Generally our documentation covers setting up the Duet to work as transparently as possible with slicing software. However, setting up the slicing software is beyond our control, with so many options, though we will try to support you to get it working. With Duet customers building a huge range of exotic and wildly different machines, we are not able to create documentation for every conceivable permutation.
                              Cura is complex software, and has the capacity to create machine profiles for your customers to use. Have you tried creating a machine profile, extruder profiles, and print settings to match the capabilities of your machine? You can post on their forums for help potentially on creating Cura profiles for mirror/duplication mode, as that is more specific to Cura than Duet.
                              https://github.com/Ultimaker/Cura/wiki/Adding-new-machine-profiles-to-Cura
                              https://github.com/Ultimaker/Cura/wiki/Definition-Files-Explained
                              Example: https://github.com/Ultimaker/Cura/blob/master/resources/definitions/ultimaker_original.def.json
                              For my IDEX machine, I have been (slowly) creating the appropriate Cura definition files, and hope to one day make it seamlessly work with mirror and duplication modes, but I am not there yet.
                              The Duet electronics hardware, RepRapFirmware, and community here are excellent at creating machines with intricate macros, amazing kinematics - but some effort is on the individual 3D printer designer to put all of the final touches in place.
                              You can certainly experiment with the BCN3D Cura, but keep in mind a few things.
                              1. It is a "fork" of a much older version of Ultimaker Cura
                              2. It is designed for use with their custom version of the Marlin Firmware, not RepRapFirmware
                              https://github.com/BCN3D
                              https://github.com/BCN3D/Marlin
                              https://github.com/BCN3D/BCN3DSigmax-Firmware
                              Here is the start of a GCODE file made by BCN3D Cura for mirror mode. Marlin GCODE
                              ;FLAVOR:Marlin
                              ;TIME:8871
                              ;Filament used: 1.69044m
                              ;Layer height: 0.15
                              ;Extruders used: T0 0.4 T1 0.4
                              ;BCN3D_FIXES
                              ;Generated with Cura_SteamEngine 2.1.5
                              T0
                              M190 S60
                              M104 S190
                              M104 T1 S190 ;Fixed T1 temperature
                              M109 S190
                              M109 T1 S190 ;Fixed T1 temperature
                              M82 ;absolute extrusion mode
                              ;Sigma ProGen 2.2.0 (Build 14CJ1301)
                              ;BCN3D Fixes applied
                              ; - Fix start GCode
                              ; - Fix Acceleration/Jerk commands
                              ; - Z Hop At Layer Change
                              G21          ;metric values
                              G90          ;absolute positioning
                              M204 S600 ;set default acceleration
                              M205 X12.5 Y12.5 ;set default jerk
                              M107         ;start with the fan off
                              G28 X0 Y0    ;move X/Y to min endstops
                              G28 Z0       ;move Z to min endstops
                              G1 Z5 F200   ;safety Z axis movement
                              T1           ;switch to the right extruder
                              G92 E0       ;zero the extruded length
                              G1 F47.4 E15 ;extrude 15mm of feed stock
                              G92 E0
                              G4 P2000     ;stabilize hotend's pressure
                              T0           ;switch to the left extruder
                              G92 E0
                              M605 S6      ;enable mirror mode
                              M92 E510.9
                              M500
                              G4 P1
                              G4 P2
                              G4 P3
                              ;LAYER_COUNT:80
                              ;LAYER:0
                              M107
                              M204 S1175
                              M205 X9.38 Y9.38
                              G0 F3600 X31.809 Y179.29 Z0.2
                              M204 S470
                              ;TYPE:WALL-OUTER
                              Is how the BCN3D printers know to switch to Mirror or duplication mode, however that is a custom command created by BCN3D, and not used in any other printer.
                              As far as additional hardware help - happy to be of assistance, however I do not know exactly how items like your fans are wired, what steps you have tried to troubleshoot problem areas, etc.
                                DE-TechArt @droftarts
                                @droftarts Well, of course I read this article but unfortunately it is for software 2.0 I'm using new software RRF3.0. also in this article it is not specified how to deal with g-code processing, that is, which slicer to use and how to configure it for an idex 3D printer.
                                Before I ask something I have been studying these questions for a long time on my own, but unfortunately it takes a lot of time and the answer is not always found.
                                  @sebkritikel I understand you well, the cura slicer is constantly updated and new features appear in it. Unfortunately, this method is not entirely convenient for ordinary consumers. the bcn3d slicer is much better for these purposes, since in it you can directly see the process of creating a duplicate and mirror copy.
                                  Unfortunately, the bcn3d technical support did not provide me with a solution for my printer, they offered me to use the Marlin software with which I do not agree at the moment as I want to use the duet motherboard.
                                  I even managed to fix the work of this slicer to some extent. when choosing duplicate mode it adds M605 S5 when choosing mirror M605 S6. using post processing - find and replace I was able to fix it on T2 or T3.
                                  As for the kinematics, everything works perfectly when selecting 1 extruder (command T0) the first extruder is running, the heater turns on, the cooling turns on and the process continues. when extruder 2 (T1) is selected, 2 extruders are used and everything works fine too.
                                  but the following problems arose. when you select the duplicate or mirror mode, only one extruder heats up - left, but both extruders come in motion.
                                  Most likely I made a mistake somewhere in the tools. Although I did absolutely as stated in the description.
                                    DE-TechArt
                                    ; Divers
                                    ;M564 H0
                                    m80 ; Power ON
                                    M550 P"DE-TechArt IDEX V1" ; set printer name
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P0 S0 ; physical drive 0
                                    M569 P1 S1 ; physical drive 1
                                    M569 P2 S1 ; physical drive 2
                                    M569 P3 S1 ; physical drive 3
                                    M569 P5 S1 ; physical drive 4
                                    M569 P6 S1 ; physical drive 5
                                    M350 X16 Y16 U16 Z16 E16:16 I1 ; configure microstepping with interpolation
                                    M92 X100 Y100 U100 Z1200 E970:970 ; Set steps per mm
                                    M566 X620 Y620 U620 Z80 E500:500 P1 ; Set maximum instantaneous speed changes (mm/min)
                                    M203 X12000 Y12000 U12000 Z1700 E3600:3600 ; Set maximum speeds (mm/min)
                                    M201 X1900 Y1900 U1900 Z150 E800:800 ; Set accelerations (mm/s^2)
                                    M906 X850 Y850 U850 Z600 E300:300 I20 ; Set motor currents (mA) and motor idle factor in per cent
                                    M208 X115 Y115 U115 Z295 ; Set axis maxima
                                    M208 S1 X-115 Y-115 U-115 Z0 ; Set axis minimum
                                    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                                    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                                    M574 U2 S1 P"!e0stop" ; configure active-high endstop for low end on U via pin ustop
                                    M558 P1 C"!^zprobe.in" H8 F6500 T5000 ; Set Z probe type to inverted, unfiltered piezo and the dive height + speeds
                                    G31 P900 X0 Y0 U0 Z-0.82
                                    M557 X-58:58 Y-58:58 S40:40 ; Define mesh grid
                                    M308 S0 P"e5temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
                                    M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin duex.e2temp
                                    M950 H1 C"duex.pwm1" T1 ; create nozzle heater output on duex.pwm1 and map it to sensor 1
                                    M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
                                    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                                    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                    M950 F0 C"duex.fan8" Q500 ; create fan 0 on pin duex.fan8 and set its frequency
                                    M106 P0 S0 H-1 C"Blower X"; set fan 0 value. Thermostatic control is turned off
                                    M950 F1 C"duex.fan7" Q500 ; create fan 1 on pin duex.fan7 and set its frequency
                                    M106 P1 S0 H1 T45 C"Fan X" ; set fan 1 value. Thermostatic control is turned on
                                    M950 F2 C"fan0" Q500 ; create fan 2 on pin fan0 and set its frequency
                                    M106 P2 S0 H-1 C"Blower U"; set fan 1 value. Thermostatic control is turned off
                                    M950 F3 C"fan1" Q500 ; create fan 3 on pin fan1 and set its frequency
                                    M106 P3 S0 H2 T45 C"Fan U" ; set fan 3 value. Thermostatic control is turned on
                                    M950 F4 C"duex.fan5" Q500 ; create fan 4 on pin duex.fan6 and set its frequency
                                    M106 P4 S1 H-1 C"LED" ; set fan 4 value. Thermostatic control is turned off
                                    M950 F5 C"duex.fan6" Q500 ; create fan 4 on pin duex.fan6 and set its frequency
                                    M106 P5 S1 H-1 C"LED" ; set fan 4 value. Thermostatic control is turned off
                                    M563 P0 D0 H1 X0 F1 S"X" ; define tool X tool 0 uses extruder 1, heater 1 and fan 1
                                    G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 axis offsets
                                    M563 P1 D1 H2 X3 F3 S"U" ; define tool U tool 1 uses extruder 1, heater 2 and fan 3
                                    G10 P1 X0 Y0 U0 Z0 S0 R0 ; set tool 1 axis offsets
                                    M563 P2 D0:1 H1:2 X0:3 F1:3 S"XU-Copy" ; define tool X+U copy mode
                                    G10 P2 X0 Y0 U-113 S0 R0 ; set tool offsets and temperatures
                                    M567 P2 E1:1 ; set mix ratio 100% on both extruders
                                    M563 P3 D0:1 H1:2 X0:3 F1:3 S"XU-Mirror" ; define tool X+U mirror mode
                                    G10 P3 X5 Y0 U-5 S0 R0 ; set tool offsets and temperatures
                                    M567 P3 E1:1 ; set mix ratio 100% on both extruders
                                    ; CPU temp calibration
                                    M912 P0 S-11
                                    ; Automatic power saving
                                    M911 S22 R23 P"M913 X0 Y0 U800 G91 M83 G1 Z3 E-1 F1000" ; Set voltage thresholds and actions to run on power loss
                                    ; tfree0.g
                                    M83 ; relative extruder movement
                                    M106 S0 ; turn off our print cooling fan
                                    G91 ; relative axis movement
                                    G1 Z3 F500 ; up 3mm
                                    G90 ; absolute axis movement
                                    ;tfree1.g:
                                    G1 Z3 F500 ; up 3mm
                                    G1 H1 X-120 F5000
                                    ;tfree2.g:
                                    G1 E-2 F3600 ; retract 2mm
                                    G1 Z3 F500 ; up 3mm
                                    ;tfree3.g:
                                    G1 Z3 F500 ; up 3mm
                                    G28 X U ; home the X and U carriages
                                    M579 U1
                                    ; tpost0.g
                                    M106 R2 ; restore print cooling fan speed
                                    M116 P0 ; wait for tool 0 heaters to reach operating temperature
                                    G1 E2 F3600 ; extrude 2mm
                                    ;tpost1.g:
                                    M116 P1 ; wait for tool 1 heaters to reach operating temperature
                                    ;tpost2.g:
                                    M116 P2 ; wait for tool 2 heaters to reach operating temperature
                                    M567 P2 E1:1 ; set tool mix ratio
                                    M568 P2 S1 ; turn on mixing
                                    G1 E2 F3600 ; extrude 2mm from both extruders
                                    ;tpost3.g:
                                    M579 U-1
                                      @sebkritikel, as I understand it you have configured RRF to make X0 Y0 the centre of the bed, which is good. Have you also configured Cura so that it knows that X0 Y0 is the centre of the printable area?
                                      DE-TechArtundefined sebkritikelundefined 3 Replies Last reply Reply Quote 0
                                        DE-TechArt @dc42
                                        @dc42 Yes, I adjusted the center of the bed everywhere.
                                          DE-TechArt @dc42
                                          In these settings, I selected the correct value and both extruders take their desired position.
                                            Your tool offsets for T2 and T3 are wrong. You should have equal but opposite X and U offsets in the G10 commands. For example if the lower limit printable by the X tool is -150 then the X offset should be half of that, so -75. Likewise the U offset should be half the maximum positive printable U value, which in this example would be half of +150.
