    Extrusion Calibration?
    1.7k
      Can you get a better photo?
      • Chrissundefined
        Chriss @peter247
        @peter247 said in Extrusion Calibration?:
        Does your printer have auto / mash bed levelling and does it have a bltouch or micro switches for Z height ?
        There is a BLTouch in place.
        Do you own a pair of digital callipers ?
        At least 10, but most of them are analog, I hate the battery changing drill. I used a micrometer screw to measure the thickness: The numbers in circles are the number of the stripe, the other numbers are the thickness at this place. The order of 4 and 5 are wrong. 😞
        How do you levelling your bed ?
        What do you want to read?
        homez.g:
        M300 S500 P1000		; Beep
        G90
        G1 Y155 X155 F6000 ; go to first probe point
        M400
        G91               ; relative positioning
        ; Run 1
        M558 F250          ; Chriss - set the down speed
        G30
        ; Run 2
        M558 F60          ; Chriss - set the down speed
        G30
        M558 F350         ; Change the speed back
        The mesh:
        M557 X10:270 Y40:270 P10:10
        Zlevel:
        G30 P0 X0 Y155 Z-99999; probe near a leadscrew, half way along Y
        G30 P1 X250 Y155 Z-99999 S2 ;
        Hightmap:
        I used a feeler gauge at every screw in the corners to level the bed mechanically.
        It is hard to get scale on the print how big is it ?
        20x35mm ruffly
        Looking at your print the first layer looks like it is thicker in parts of the print by the edges.
        To me it looks like it is under extruding .
        I think that the the z offset is wrong. The first layer should have 0.20 from the slicer, but it is more in average over the complete bed. That is a bit strange. I will tune in the z-offset again and print the first layer one more time.
        Some more pictures:
        Back site:
        @Phaedrux Are they good enough?
        Cheers, Chriss
          Phaedrux Moderator @Chriss
          @Chriss said in Extrusion Calibration?:
          Yes. Confirms that it looks like the nozzle is too close in those areas.
          The image of your heightmap shows a bit of tilt front to back, raised in the front. I think you could probably level the bed a bit better.
          Chrissundefined 1 Reply Last reply Reply Quote 0
          • Chrissundefined
            Chriss @Phaedrux
            @Phaedrux
            Thanks...
            Let me repeat it: The roughness comes from over extrusion because the gab between the nozzle and the bed is to narrow.
            I will re level the bed and will print tiny batches of first layers. Lets see how they look than.
            Cheers, Chriss
              bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
              Here's a good quick bed level test print to verify mesh compensation is working well. Print once with it disabled and once with it enabled.
              • Chrissundefined
                Chriss @Phaedrux
                @Phaedrux
                Yes, I will. I will make sure that the mechanical part will do it's job too. 😉
                • Chrissundefined
                  Chriss
                  The HightMap looks like that now:
                  Very much the same warping which is not an surprise. The front right corner is a bit smoother now.
                  • Chrissundefined
                    Chriss
                    I have printed the "leveling_test" files. Once "normal" with the mesh compensation and once without it (G29 S2). I touched the lead screws from time to time so I was able to feel that the motors where rotating while the head was traveling when the mesh compensation was enabled. They did not rotate while the mesh compensation was off.
                    With:
                    Without:
                    I have some more pictures, but I do not want to spam here. 😉
                    The squares on the bed to look very good stick on the bed. I will print the big one again, lets see how that ends up now. 😉
                    Cheers, Chriss
                    peter247undefined 1 Reply Last reply Reply Quote 0
                    • peter247undefined
                      peter247 @Chriss
                      @Chriss
                      What is your printer a know type like a cr10 ?.
                      Have you tried printing on glass or a mirror ?
                      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                      • Chrissundefined
                        Chriss @peter247
                        @peter247
                        It is a cr10 pro v2.
                        No, I tried PEI, Pertinax, FR4 and I have a sheet of printbite on my RatRig CoreXY. But this one is still "under construction". I had no chance to tune it in toll now. The CR10 have still to much problems.
                        I'm not sure whether I want to try glas or not. I heard about enough problems there, too. And I think that the trend goes away of it, too.
                        Cheers, Chriss
                        • peter247undefined
                          peter247 @Chriss
                          @Chriss
                          Yes , another cr10s pro owner !!!!
                          Mine is a cr10s pro v1 , but with the bltouch upgrade .
                          Now I know your machine a little better , how is the gantry on Z is it level and is the uprights level.
                          Mine was a pig at first I had to take to gantry apart to get the z axis to run level.
                          Just a personal one !!!! did you fit the duet in the control box.
                          I use one of these :-
                          https://technologyoutlet.co.uk/collections/printer-parts-spares/products/carborundum-glass-plate?variant=32606698438735
                          • Chrissundefined
                            Chriss @peter247
                            @peter247
                            The portal was not optimal square and it was slightly bent to the back. I fixed that with some slices metal out of a beer can. 😉 But I would not bet that it is perfect now.
                            I printed a "holder", which are basically for "pins" on a rectangle:
                            I glued it right to the original mainboard and the expansion board to the place where the original mainboard was. That works very well. 😉
                            I do not need access to the USB and micro SD card, so that is no problem for me, I'm happy with the network access. I swapped to many floppies, harddisks, SD-Cards in my live, I'm more than happy that I do not have to do that any more. 😉
                            Hahaha... I ordered the same product a minute ago while you edited your post. 😉
                            Cheers, Chriss
                            • peter247undefined
                              peter247 @Chriss
                              @Chriss
                              Didn't the cr10s pro v2 come with one of these ?.
                              Or was it like the v1 a metal plate with a buildtakie clone sheet ?
                              • Chrissundefined
                                Chriss
                                I'm not sure whether it is getting better or not:
                                I will cut it again later and measure it again. I need to spend some attention to the paperwork for my accountant. 😞
                                Cheers, Chriss
                                • Chrissundefined
                                  Chriss @peter247
                                  It came with that plastic thingy glued on a alu plate, I guess to reach the same high as the carborundum plate. I tried to get that some month ago but I was not to get one of them. There where so hard soled out that even Creality in CN canceled my order after some month. 😉
                                  I ordered on from Amazon and I ordered a similar one from one of my preferred dealers here in Germany:
                                  https://www.3djake.de/3djake/glasplatte-mit-chem-beschichtung
                                  It seams to me that this is very much the same coating.
                                  Btw: I replaced the original heater and the metal plate with a fine routed 4mm aluminum plate. The original one was to close to a banana for me. And I wanted to switch to a 240V heater anyway.
                                  Cheers, Chriss
                                  • peter247undefined
                                    peter247 @Chriss
                                    @Chriss
                                    try the UK version :- https://www.3djake.uk/3djake/glass-plate-with-chemical-coating
                                    • Chrissundefined
                                      Chriss @peter247
                                      @peter247
                                      Hahaha... well, as a German.... 😉
                                      • Chrissundefined
                                        Chriss
                                        Hahahaha... they are from Austria! 🙂
                                        https://www.3djake.uk/info/our-group
                                        peter247undefined 2 Replies Last reply Reply Quote 0
                                        • peter247undefined
                                          peter247 @Chriss
                                          @Chriss
                                          I've ordered off them before , but thought they was Czech , but I think I was mixing that up with Fillamentum which is what I purchased.
                                          ( The niceshops group is an Austrian company )
                                          peter247undefined Chrissundefined 2 Replies Last reply Reply Quote 0
                                          • Vetiundefined
                                            Veti
                                            i am currently trying
                                            https://princore.de/collections/dauerdruckplatten-prinplate/products/prinplate-extreme-dauerdruckplatte-2mm-1
                                            and it sticks very well (only tested pla)
