    Triangular wave and print area
    1.9k
    • Leblondundefined
      Leblond
      good morning to all of you, I think I am in the right section.
      I'm here asking you for help with a print bed calibration problem, it's a bit of a pain to find I assume it's a mechanical problem. My printer is a tronxy X5SA Pro with electronics reconverted with duet 2 wifi, volume 330x330mm composed of BLTouch V3.1 as a probe and 3mm glass as a print bed, I have had it for a long time and it is two months now that I try in every way but to no avail, having noticed that the carriage where the extruder is attached was not very loose so I disassembled all the upper deck X / Y I cleaned them and I looked at the eccentrics and fixing them, now the skates seem to slide linearly on the tracks.
      The problem believed by the X / Y axes has not been solved, I pass to the second hypothesis "Axis Z" the printing table is quite rigid "modification made some time ago by replacing linear bearings with metal ones" and is synchronized by a GT2 6mm belt, I have no wobble problems, I also included the gearbox of the 2 motors "I also included the hardware as a problem" that control the screws and I cleaned everything with the WD40. I made sure once everything was mounted to oil the screws and freehand I made sure that the Z plane ran freely, but this doesn't seem to work either, I arrived at all this after trying to probe the print plane
      both hot and cold without changes in the survey, I tested without glass, on bare and raw aluminum, I also tried various survey speeds but the results are all negative, I am attaching photos and configuration of my system, I hope that some of you are able to solve the problem.
      I forgot: I tried to probe with various meshes, 60x60 and 40x40 no graphic visual problems, but at the time of printing some points seem to be high with tragic consequences on the final print. 20x20 here we begin to graphically see a triangular wave (which is the mangy problem in question).
      I remain at your disposal, thank you in advance.
      Photo below: 20x20 at 90 degrees celsius.
      Photo below: 20x20 at room temperature.
      Under the configuration files and the board diagnostics.
      retractprobe.txt homez.txt homey.txt homex.txt homeall.txt diagnostic.txt deployprobe.txt Config.txt Bed.txt
      peter247undefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        first check if the problem is your probe
        https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output
        also decrease the probing speed to F120
        • Leblondundefined
          Leblond
          thanks for the help, now I check, and for the diving speed as I had already written they do not change, I have already tried at 120, at 250 I have never had problems, but anyway I will try and I will give you the results
          • Leblondundefined
            Leblond
            ok i tried and this is the result on 4 points, but how can it help me to know this?
            25/10/2020, 19:19:17 G32 bed probe heights: 0.195 0.190 0.190 0.190 0.188 0.188 0.192 0.190 0.190 0.000, mean 0.171, deviation from mean 0.057
            25/10/2020, 19:18:48 G32 bed probe heights: 0.202 0.202 0.200 0.200 0.198 0.198 0.200 0.200 0.195 0.000, mean 0.179, deviation from mean 0.060
            25/10/2020, 19:18:20 G32 bed probe heights: 0.188 0.185 0.180 0.185 0.178 0.178 0.183 0.180 0.183 0.000, mean 0.164, deviation from mean 0.055
            25/10/2020, 19:17:52 G32 bed probe heights: 0.198 0.195 0.198 0.192 0.192 0.198 0.198 0.198 0.192 0.000, mean 0.176, deviation from mean 0.059
            • Vetiundefined
              Veti
              the last measurement is very odd.
              did you copy the macro correctly?
              • Leblondundefined
                Leblond
                I created the macro M48.g in sys, then I created a macro where it indicates the coordinates and calls M48, but it doesn't work for me, instead of dwelling on a precise point it goes diagonally, I read that a G30 with parameter P wants the coordinates, so I created one with the coordinates and it works, I'll post the macro
                • Leblondundefined
                  Leblond
                  new 1.txt
                  • Vetiundefined
                    Veti
                    G30 P9 X165 Y30 Z- 9999
                    there is a space to much after the Z-
                    • Leblondundefined
                      Leblond
                      ok, I'll call you hawkeye, correct and take the test again
                      • Leblondundefined
                        Leblond
                        25/10/2020, 19:37:22 G32 bed probe heights: 0.190 0.198 0.195 0.195 0.192 0.192 0.190 0.195 0.188 0.192, mean 0.193, deviation from mean 0.003
                        25/10/2020, 19:36:52 G32 bed probe heights: 0.195 0.195 0.192 0.202 0.212 0.208 0.205 0.200 0.200 0.198, mean 0.201, deviation from mean 0.006
                        25/10/2020, 19:36:22 G32 bed probe heights: 0.188 0.178 0.178 0.178 0.178 0.178 0.173 0.178 0.183 0.180, mean 0.179, deviation from mean 0.004
                        25/10/2020, 19:35:52 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
                        G32 bed probe heights: 0.190 0.192 0.192 0.195 0.190 0.185 0.190 0.188 0.188 0.190, mean 0.190, deviation from mean 0.003
                        • Vetiundefined
                          Veti
                          ok that looks good.
                          now do the test again, grab the hotend carriage and turn on clockwise and anticlockwise between probes. dont force it but do it gently.
                          after that do it again trying to rotate it forwards and backwards.
                          • Leblondundefined
                            Leblond
                            in practice I take the trolley and manually try to move it and then I do the tests again, did I understand correctly?
                            • Vetiundefined
                              Veti @Leblond
                              @Leblond
                              yes. we are looking for backlash in the assembly. movement could cause the assembly to rotate and cause the result you are seeing.
                              • Leblondundefined
                                Leblond
                                25/10/2020, 19:57:24 G32 bed probe heights: 0.192 0.195 0.190 0.192 0.192 0.192 0.190 0.190 0.190 0.190, mean 0.191, deviation from mean 0.002
                                25/10/2020, 19:56:50 G32 bed probe heights: 0.183 0.185 0.180 0.185 0.185 0.183 0.183 0.183 0.185 0.183, mean 0.183, deviation from mean 0.002
                                25/10/2020, 19:56:17 G32 bed probe heights: 0.168 0.168 0.168 0.173 0.170 0.165 0.170 0.170 0.170 0.170, mean 0.169, deviation from mean 0.002
                                25/10/2020, 19:55:43 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
                                G32 bed probe heights: 0.183 0.185 0.183 0.185 0.185 0.185 0.183 0.185 0.185 0.183, mean 0.184, deviation from mean 0.001
                                • Vetiundefined
                                  Veti
                                  there are default values from the configurator.
                                  a quick google shows the motors seem to be 1,68 A motors
                                  so you are running way to little current. try 1300
                                  • Leblondundefined
                                    Leblond
                                    The motors are Quimat Nema 17 Stepper Motor 1.7 A 0.59 Nm 84 oz.in 47mm
                                    • Vetiundefined
                                      Veti @Leblond
                                      @Leblond said in Triangular wave and print area:
                                      1.7 A
                                      so running them at 75% rounding to nearest 100 is 1300.
                                      • Leblondundefined
                                        Leblond
                                        ok I took them to 1.3 and I'm doing the test again later
                                        • Leblondundefined
                                          Leblond
                                          25/10/2020, 20:56:11 G32 bed probe heights: 0.198 0.195 0.195 0.198 0.195 0.200 0.195 0.200 0.192 0.195, mean 0.196, deviation from mean 0.002
                                          25/10/2020, 20:55:37 G32 bed probe heights: 0.183 0.180 0.180 0.183 0.183 0.183 0.183 0.180 0.180 0.183, mean 0.181, deviation from mean 0.001
                                          25/10/2020, 20:55:04 G32 bed probe heights: 0.183 0.178 0.173 0.170 0.178 0.173 0.173 0.178 0.178 0.173, mean 0.175, deviation from mean 0.004
                                          25/10/2020, 20:54:31 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
                                          G32 bed probe heights: 0.195 0.192 0.192 0.195 0.192 0.195 0.195 0.195 0.188 0.195, mean 0.194, deviation from mean 0.002
                                          • Leblondundefined
                                            Leblond
                                            I'm retrying cold-meshing the plate to see if we've made any improvements
