    Duet 3 Mini 5+ : Initial announcement
    288
    31.1k
      T3P3Tony administrators @Veti
      @Veti soft launch, invite only presales, artificially inflated prices on the grey market..... its all planned!
      Vetiundefined 1 Reply Last reply Reply Quote 2
      • Vetiundefined
        Veti @T3P3Tony
        @T3P3Tony
        i will write the ebay bots
        • cabal2000undefined
          cabal2000 @Veti
          @Veti How do I get an invite to the pre-order?
          • Vetiundefined
            Veti @cabal2000
            @cabal2000
            it will be announced on the forum, once its available. that would be my guess
            • nikschaundefined
              nikscha
              Oh boi I am super excited!
              • I don't want to be that guy but will there be an easy way to drive DotStars/Neopixels?
                (Edit: I just checked the overview of duet electronics and "up to 60 Neopixels" will be supported by the Mini, no Dotstars though. My guess is they will be controlled using the 12864 display's Neopixel backlight pin?)
              • I'm also a huge fan of the smart effector, but as mentioned earlier, it would only make sense to offer a version upgraded with CAN if there's a lightweight stepper motor to go with it:
                The Flex3Drive G5 has an option to be driven by a tiny tiny Nema 8 stepper!
              Stay in school
                I've written a page on using NeoPixel and DotStar LEDs, see https://duet3d.dozuki.com/Wiki/Neopixel_and_DotStar_LEDs. Note the need for an external 5V supply when using them with the Duet 3 Mini. The interface works separately from the NeoPixel LEDs on some 12864 displays.
                The reason we don't support DotStar on the Duet 3 Mini is that we ran out of pins. DotStar needs two, but NeoPixel needs just one. In principle you could connect a DotStar LED to the daughter board connector, but you would probably need to level-shift the signals to 5V.
                • gmedlicottundefined
                  gmedlicott
                  DC42/Tony: Can you post the hole mounting dimensions for the Duet 3 Mini 5+? Better yet, a STEP file of the board?! I'm working on an electrical box for the ExoSlide/ExoCube printer, and would like to be able to mount this new board once available.
                    Tony will provide a STEP file in due course. Overall dimensions and mounting holes are as for the Duet 2 series. The biggest difference is that the board has been reversed so that if the stepper motor outputs are at the bottom, the power input is on the left, and the SD card, USB and network connectors are on the left. We've done this so that a Raspberry Pi can be positioned next to the Duet and connected without running the cable over or under the Duet or the Pi.
                    • weed2allundefined
                      weed2all
                      So any news on when the new board will be avaliable ...i'm planing a new build and love to get the new board with this build!thank you!
                      https://www.thingiverse.com/weed2all/designs
                        We will have a limited number of pre-production boards next month. Full production and general availability will be Q1 next year.
                        Dougal1957undefined weed2allundefined 2 Replies Last reply Reply Quote 0
                        • Dougal1957undefined
                          Dougal1957 @dc42
                          @dc42 said in Duet 3 Mini 5+ : Initial announcement:
                          David as with the Duet3 6HC will the mini come with a SD Card setup for SBC use?
                          Can't wait to get my hands on one to replace the Wifi in the Delta.
                          Regards Doug
                            Yes, in theory it will work with exactly the same SD card because newer boards will ship with a config that simply points directly to the configurator and has no default config
                              Dougal1957 @T3P3Tony
                              @T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
                              I was thinking more for the PI tony not standalone? Although it won't be hard to generate one from scratch
                              • weed2allundefined
                                weed2all @dc42
                                @dc42 how to sign for a pre production board?
                                  T3P3Tony administrators @Dougal1957
                                  @Dougal1957 yep, the SD cards should be dual boot, both stand alone and Pi
                                    T3P3Tony administrators @weed2all
                                    @weed2all we will be supplying them via resellers and directly through the website
                                    • Dan1990undefined
                                      Dan1990
                                      Is there any estimation in terms of releasing? or still before x-mas?
                                      jbarrosundefined 1 Reply Last reply Reply Quote 0
                                      • jbarrosundefined
                                        jbarros @Dan1990
                                        @Dan1990 this was yesterday:
                                          Just to clarify, we expect to have almost 300 pre-production boards early in December, so there should be enough for those who want to try them. We are hopeful that these boards will pass the relevant CE approval tests, but we can't guarantee this because so far we have only run some of these tests (the ones most likely to fail) and on a previous PCB revision. That's why we are calling them pre-production boards. If the boards do pass CE testing then we will be able to do the first production run in January.
                                          Chrissundefined 1 Reply Last reply Reply Quote 2
                                          • poohzazaundefined
                                            poohzaza
                                            nice where can i sing up for preorder
