    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
    • Dougal1957undefined
      Dougal1957 @dc42
      @dc42 said in Duet 3 Mini 5+ : Initial announcement:
      We will have a limited number of pre-production boards next month. Full production and general availability will be Q1 next year.
      David as with the Duet3 6HC will the mini come with a SD Card setup for SBC use?
      Can't wait to get my hands on one to replace the Wifi in the Delta.
      Regards Doug
        T3P3Tony administrators
        Yes, in theory it will work with exactly the same SD card because newer boards will ship with a config that simply points directly to the configurator and has no default config
          Dougal1957 @T3P3Tony
          @T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
          I was thinking more for the PI tony not standalone? Although it won't be hard to generate one from scratch
          • weed2allundefined
            weed2all @dc42
            @dc42 how to sign for a pre production board?
            https://www.thingiverse.com/weed2all/designs
              T3P3Tony administrators @Dougal1957
              @Dougal1957 yep, the SD cards should be dual boot, both stand alone and Pi
                T3P3Tony administrators @weed2all
                @weed2all we will be supplying them via resellers and directly through the website
                • Dan1990undefined
                  Dan1990
                  Is there any estimation in terms of releasing? or still before x-mas?
                  jbarrosundefined 1 Reply Last reply Reply Quote 0
                  • jbarrosundefined
                    jbarros @Dan1990
                    @Dan1990 this was yesterday:
                      Just to clarify, we expect to have almost 300 pre-production boards early in December, so there should be enough for those who want to try them. We are hopeful that these boards will pass the relevant CE approval tests, but we can't guarantee this because so far we have only run some of these tests (the ones most likely to fail) and on a previous PCB revision. That's why we are calling them pre-production boards. If the boards do pass CE testing then we will be able to do the first production run in January.
                      Chrissundefined 1 Reply Last reply Reply Quote 2
                      • poohzazaundefined
                        poohzaza
                        nice where can i sing up for preorder
                          T3P3Tony administrators @poohzaza
                          @poohzaza we won't be running a pre-order for those. They will be for sale our website and hopefully some resellers as well.
                          • piperswundefined
                            pipersw
                            You sell on your website ? I see you don't sell anything, everything is out of stock with Covid
                              @pipersw right now yes, we will let people what the plan is when we get closer to the release of the mini 5+
                              weed2allundefined 1 Reply Last reply Reply Quote 1
                              • Richard Fundefined
                                Richard F
                                better start saving my pennies the perfect board for me , and people wanting to upgrade ender 3s type printers, they should sell well
                                • weed2allundefined
                                  weed2all @T3P3Tony
                                  @T3P3Tony awsome...tag my name here when the boards are ready to be sell!...as im constantly check the forum...
                                    Richard F
                                    ps i hope you add a 12v reg for the fans
                                    Vetiundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    • Vetiundefined
                                      Veti @Richard F
                                      @Richard-F said in Duet 3 Mini 5+ : Initial announcement:
                                      you can see the jumpers above the fan connectors
                                      vin or 12v
                                      Richard Fundefined 1 Reply Last reply Reply Quote 0
                                        Richard F @Veti
                                        @Veti great ;}
                                          The 12V fan output is also listed here https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics
                                            A Former User @Richard F
                                            Someone evidently didn't look at the specs before posting....
                                            Richard Fundefined 1 Reply Last reply Reply Quote -3
