Duet 3 SBC DCS has stopped
@dhusolo said in Duet 3 SBC DCS has stopped:
@CaLviNx again that's not a solution that's a work around
Anything that gets you printing is a solution
@CaLviNx said in Duet 3 SBC DCS has stopped:
Ihave already added the most helpful solution (you just don't like it)
I haven't said a thing about your solution. Yes you're correct it works in standalone. Great. We'd like to do some more testing to see what's going on in SBC mode with the new beta. If that disinterests you, find another thread.
@dhusolo
Did you downgrade the firmware on the duet 3 manually to 3.1.1 before downgrading the software on the Pi?
The connection between the two was changed significantly at beta 2 and a board running beta 2 or 3 can't connect to a lower version of DSF and vice versa. -
@jay_s_uk I can't remember 100% because I did a few different things in standalone and SBC. I think I used the erase jumpers and powered on the board.
It would be good if we could get beta 3 on there and see if it's working at all. It sounded like you lost communication between the duet and pi entirely when you tried to update to beta 3. Is that right?
@Phaedrux Correct. Just making sure I'm doing it right, Is there a different way to erase the firmware on the board besides the erase jumpers or would even using a different SD card do the trick?
Well you normally don't need to erase the firmware, but yes the jumper is the way to do that. Once erased you will need to use usb to flash a firmware again.
A different SD card won't help since the firmware is flashed to the board itself. The firmware bin file on the sd card is just there for storage during in place flashing.
What version is flashed to the duet right now?
What version is the Pi running?If you're completely back on 3.1.1 right now, are you on the unstable branch for apt-update? How did you originally try to update to the beta?
@Phaedrux I think I got it back to 3.1.1.
What's the command to verify version info including DWS and DWC?
From the gcode console send M122 and post the results please.
Additionally send M122 "DSF"
I haven't loaded my config file but I flashed Duet3Firmware_MB6HC.bin through Bossa. It looks like it's communicating with the RPI again.
M122
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 154604 Dynamic ram: 161360 of which 20 recycled Exception stack ram used: 236 Never used ram: 76996 Tasks: NETWORK(ready,1980) HEAT(blocked,1452) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(suspended,252) MAIN(running,5184) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:09:59 ago, cause: power up Last software reset at 2020-11-05 20:48, reason: User, spinning module LinuxInterface, available RAM 74612 bytes (slot 3) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 15.0, current 25.8, max 25.9 Supply voltage: min 0.2, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0 Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Date/time: 2020-11-08 14:26:06 Slowest loop: 2.36ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.03ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 0, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 12ms ago RX/TX seq numbers: 19460/19461 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 5.64 M122 DSF
m122 DSF === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 154604 Dynamic ram: 161360 of which 20 recycled Exception stack ram used: 236 Never used ram: 76996 Tasks: NETWORK(ready,1980) HEAT(blocked,1452) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(suspended,252) MAIN(running,4512) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:12:41 ago, cause: power up Last software reset at 2020-11-05 20:48, reason: User, spinning module LinuxInterface, available RAM 74612 bytes (slot 3) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 25.6, current 25.8, max 26.0 Supply voltage: min 0.3, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0 Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max not available Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max not available Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max not available Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max not available Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max not available Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max not available Date/time: 2020-11-08 14:28:49 Slowest loop: 1.97ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122 D0 S0 F0" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.03ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 0, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 12ms ago RX/TX seq numbers: 24793/24794 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.80 -
M122 DSF
I think the quotes around DSF are required. I'll admit I haven't used that command yet.
m122 "DSF" === Duet Control Server === Duet Control Server v3.1.1 Daemon: Finishing macro daemon.g, started by system > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.83 -
Regardless, I think you're on 3.1.1 across the board now.
but to your earlier question I tried updating to the beta following this and updating the source list to use unstable version
Would you be willing to test beta 3 once again?
Sure. Should I use the getting started link or manually flash? I've tried compiling the firmware myself but with no success which is why I used the instructions in the link
@dhusolo that should be all you need to follow to move over to the unstable branch.
There's no need to use the erase button to load the firmware as it will be updated as part of the upgrade process -
I thought i did it correct but I got this error
pi@duet3:~ $ sudo apt-get install duetsoftwareframework Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: duetcontrolserver duetruntime duetsd duettools duetwebcontrol duetwebserver reprapfirmware The following packages will be upgraded: duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware 8 upgraded, 0 newly installed, 0 to remove and 118 not upgraded. Need to get 34.0 MB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 3.2.0-beta3 [2,034 B] Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.1.0 [2,102 B] Get:3 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 3.2.0-beta3 [62.2 kB] Get:4 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 3.2.0-beta3 [226 kB] Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 3.2.0-beta3 [28.9 MB] Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 3.2.0-beta3 [83.9 kB] Get:7 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 3.2.0-beta3 [3,507 kB] Get:8 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 3.2.0-beta3-1 [1,260 kB] Fetched 34.0 MB in 19s (1,813 kB/s) Reading changelogs... Done (Reading database ... 79179 files and directories currently installed.) Preparing to unpack .../0-duetsoftwareframework_3.2.0-beta3_armhf.deb ... Unpacking duetsoftwareframework (3.2.0-beta3) over (3.1.1) ... Preparing to unpack .../1-duetsd_1.1.0_all.deb ... Unpacking duetsd (1.1.0) over (1.0.6) ... Preparing to unpack .../2-duettools_3.2.0-beta3_armhf.deb ... Unpacking duettools (3.2.0-beta3) over (3.1.1) ... Preparing to unpack .../3-duetcontrolserver_3.2.0-beta3_armhf.deb ... Unpacking duetcontrolserver (3.2.0-beta3) over (3.1.1) ... Preparing to unpack .../4-duetruntime_3.2.0-beta3_armhf.deb ... Unpacking duetruntime (3.2.0-beta3) over (3.1.1) ... Preparing to unpack .../5-duetwebserver_3.2.0-beta3_armhf.deb ... Unpacking duetwebserver (3.2.0-beta3) over (3.1.0) ... Preparing to unpack .../6-duetwebcontrol_3.2.0-beta3_all.deb ... Unpacking duetwebcontrol (3.2.0-beta3) over (3.1.1) ... Preparing to unpack .../7-reprapfirmware_3.2.0-beta3-1_all.deb ... Unpacking reprapfirmware (3.2.0-beta3-1) over (3.1.1-1) ... Setting up duetruntime (3.2.0-beta3) ... Setting up duetcontrolserver (3.2.0-beta3) ... Installing new version of config file /opt/dsf/conf/config.json ... Creating group dsf with gid 995. Creating user dsf (n/a) with uid 995 and gid 995. Setting up duettools (3.2.0-beta3) ... Setting up duetwebserver (3.2.0-beta3) ... Setting up duetsoftwareframework (3.2.0-beta3) ... To modify config files consider adding yourself to the dsf groupd: # usermod -a -G dsf <username> Setting up duetwebcontrol (3.2.0-beta3) ... Setting up duetsd (1.1.0) ... Setting up reprapfirmware (3.2.0-beta3-1) ... Sending update request to DCS... Error: Failed to send update request Unhandled exception. System.Threading.Tasks.TaskCanceledException: A task was canceled. at DuetAPIClient.BaseConnection.PerformCommand[T](BaseCommand command, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 188 at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 305 at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 84 at DuetControlServer.Program.<Main>(String[] args) -
@dhusolo
Are you still able to connect to the board via DWC?
If you can confirm the firmware version using 3.1.1
If it's still 3.1.1, send M997 B0
I would be interested to see if you get any errors reported -
@jay_s_uk
I had to start DCS and DWS manually but I was able to get to the web interface.M122 "DSF" === Duet Control Server === Duet Control Server v3.2.0-beta3 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.68 11/8/2020, 2:58:59 PM``` M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta3 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 122124 Dynamic ram: 137508 of which 0 recycled Never used RAM 132560, free system stack 185 words Tasks: Linux(ready,131) HEAT(blocked,362) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,66) MAIN(running,1300) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:09:17 ago, cause: software Last software reset details not available Error status: 0x00 MCU temperature: min 25.3, current 26.2, max 26.4 Supply voltage: min 0.3, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0 Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Date/time: 2020-11-08 14:58:59 Slowest loop: 743.08ms; fastest: 0.16ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages sent 0, send timeouts 0, longest wait 0ms for type 0, free CAN buffers 47 === SBC interface === State: 0, failed transfers: 1 Last transfer: 14ms ago RX/TX seq numbers: 17902/17903 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x20aa0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta3 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.56
